Old 01-24-2019, 09:35 PM   #1
traut811
Whose good at identifying 67-71 and 72 doors?
..... Without seeing the dimple lol.
I made the trip to check out my other cab I was going to use for a build to make sure it was solid, but ....... Completely forgot to look what year doors it had. I didn't get a picture of the inside panel to see if the dimple was under the vent window. These terrible pictures of the edge are all I've got. They're uncut, solid, and never been patched, and I was going to order everything that goes inside them tonight so I could just replace everything on my 67 (cut for speakers and inners need rebuilt). I can try to leave work early again tomorrow, but I'm impatient. Can anyone tell anything from these holes for how the panels attach??
traut811 is offline   Reply With Quote
Old 01-24-2019, 09:44 PM   #2
flashed
Re: Whose good at identifying 67-71 and 72 doors?
I cant tell.
flashed is offline   Reply With Quote
Old 01-24-2019, 09:56 PM   #3
traut811
Originally Posted by flashed View Post
I cant tell.
I even was trying to talk myself into (or out of) a decision based on how far the shaft stuck out, as I think 72 had thicker panels.
Old 01-24-2019, 10:17 PM   #4
Grumpy old man
Grumpy old man's Avatar
longer shafts on door and window handles , screw hole on upper panel below vent window ,that picture above is a reproduction door going by the waves in the sheet metal and no triangle in the lower rear door corner
Old 01-25-2019, 06:45 PM   #5
traut811
Grumpy long time no talk, sir! Hope all has been well
Alright I just went to check them out again.
Only the passenger side had screw hole under the vent window. Do I have two different year's doors here?
I'm unsure now if I should use my 67 rust free doors with huge hacked holes for speakers or these which are really nice, possibly reproduction though.
Old 01-25-2019, 07:04 PM   #6
Grumpy old man
You should just send me those 67 doors with the big ol nasty speaker holes ...
if you have rust free 67 doors use them .
Old 01-25-2019, 07:33 PM   #7
flashed
That 72 door is quite hard to come by ,at least in my area .
Old 01-25-2019, 08:15 PM   #8
traut811
Lol! Someone cut for a 6x9. It's covered with a carpeted lower panel now.
Do you guys think I have different year's doors??
My 67 doors are solid as can be, the cuts just bother me
Old 01-25-2019, 08:17 PM   #9
flashed
You can patch the cuts easier than finding doors and yes you have different year doors .
Old 01-25-2019, 08:21 PM   #10
Grumpy old man
https://www.classicindustries.com/product/t70154.html
http://67-72chevytrucks.com/vboard/s...d.php?t=735663
Old 01-25-2019, 08:38 PM   #11
jocko
jocko's Avatar
Yes, the one with the screw on the interior side under the vent window is a 72 and the other is pre-72.
OOPS, sorry - missed your post flashed.
Old 01-26-2019, 12:38 AM   #12
traut811
Thank you guys very much.
I'm going to run the 67 doors then, and probably just patch the bottom portion when I buy new guts for the insides of them.
Eventually I'll just sell the other cab.
