76 Blazer LS swap
Just finished up a Blazer LS3/4L65E swap. thought I would share some pics of the build and maybe help others out if they are looking to do the same feel free to ask questions.
Re: 76 Blazer LS swap
went ahead and installed a new heater core and evaporator so hopefully they don't have to be changed again. I will be using Hooker Blackheart swap headers and engine mounts on this build
Very nice headers
Are you going to run the A/C system? How did you hook up the gas pedal? DBW or DBC ? What are you doing for the engine harness? Making your own fuel system in the tank?
1973 K5, full vert, 6" BDS lift, 35 Mickey T MTs 1984 K10, 8" lift on 35s 2004 3/4 4wd, 33s Toyo Mts, Long Tube headers, 3K multidisk 80e, tons of miles 2011 Yukon XL | Bone stock 2013 Audi Q5 |
#5 | |
I will run DBW, I will post pics of the pedal soon the engine/trans will be controlled by a Holley Terminator EFI system in-tank 255lph pump with a corvette regulator/filter |
looking forward to see how that low mount works out!
Trans cooler mounted along with the A/C condenser, Earls Ultra-Pro oil cooler
Fuel system build using a Holley 12-914 fuel pump on the factory blazer EFI tank |
Nice truck
87 k5 silverado 4x4 350 38k stock 77 k5 Cheyenne 2wd 5.3 4l60e project |
