Old 06-08-2019, 06:27 PM   #1
mister.freeze
mister.freeze's Avatar
'71 trailing arm questions
I have a '71 longbed that was made into a trailer. From the get-go, it was bouncy as a trampoline. I put some Monroe Gas Magnum shocks off a Suburban on, thinking the heavier truck had stiffer shocks. They weren't any better. Could have been bad to begin with as the Suburban was just sitting around. My Blazer has a 3/4 ton suspension kit on it, and when I replaced the Pro Comp shocks on it with Bilstien's I warrantied out the Pro Comps and put a new pair on the trailer. Still just a bouncy house on wheels. What gives? The original coil springs are on there, is that the problem? I wouldn't think so. Is it just too light? I wouldn't think that would be the problem either. Thoughts? Thanks in advance.
'72 K5, known as 'the Fox.'
mister.freeze is offline   Reply With Quote
Old 06-08-2019, 07:19 PM   #2
Grumpy old man
Grumpy old man's Avatar
Re: '71 trailing arm questions
Does it trail straight ? I would load a few hundred lbs in it as far forward as possible and see how it acts ? Are the tires balanced ? pick a point on each side of the axle and measure to the hitch and see if it measures the same ,Sometime home built trailers can be a little off center and wander
Grumpy old man is online now   Reply With Quote
Old 06-08-2019, 08:32 PM   #3
mister.freeze
It pulls and tracks just fine. The problem is when crawling around inside it or loading it. It's like it has no shocks at all!
Old 06-08-2019, 09:34 PM   #4
saxart
saxart's Avatar
My truck was the same way (coil springs) even with new shocks. It didn't get better until I did the shock relocation kit. Now it's like a modern truck . The relocation kit has the shocks shooting toward the back, rather than the center of the truck. Much better geometry. No more bouncy-bouncy...
Meet "Old Roy": http://67-72chevytrucks.com/vboard/s...d.php?t=707801
saxart is offline   Reply With Quote
Old 06-10-2019, 11:32 AM   #5
mister.freeze
surely these things didn't bounce like that new. Is it a spring problem more than a shock problem? Is there a 3/4 ton coil spring?
Old 06-10-2019, 03:29 PM   #6
layinrocker65
layinrocker65's Avatar
It’s still a weight problem too. With no added weight, it’s always going to be bouncy
53 GMC 2.5 ton COE
70 Chevy C10 LWB 350/465(soon to be 6.0/4L80e)
74 Chevy C10 SWB 5.3/4L80e
91 GMC Syclone 370/4L80e PT88 AWD
92 GMC Typhoon 6.0/4L80e twin 65s AWD
07 RCLB Sierra Duramax
15 Chevy SS 6.2/TR6060 LSA blower
layinrocker65 is offline   Reply With Quote
Old 06-10-2019, 04:24 PM   #7
saxart
saxart's Avatar
Now that you mention it, I did a spring replacement when I did the shock relocation kit, so I don't know if it was the shock relocation or the new springs that fixed it. My original springs were 3/4 ton springs that were horrendously worn out from the owner hauling literally TONS of material in the bed over the years, so it could have been that they were worn out.
I agree with others that it will tow a lot better if you had a couple of hundred pounds in the back of it.
Old 06-10-2019, 05:54 PM   #8
mister.freeze
I guess I just had more faith in what shocks can do.
Would it be worthwhile to convert to leaf springs?
Could I do both, like the old squarebody HeavyHalf?
Any stock-height springs laying around?
Old 06-11-2019, 01:38 PM   #9
demian5
demian5's Avatar
Hey like 60-62 does from the factory!
"Work hard, use your vacation days."
1970 C15 GMC Long Bed
1986 C20 Scottsdale (grandpa truck)
1964 Impala SS
1959 Austin Healey 100-6 BN6
Instagram: C10sofOC
demian5 is online now   Reply With Quote
Old 06-12-2019, 07:24 PM   #10
Sparky dave
You think it needs the suspension? If it’s like a pogo stick it’s surely got to be a dampening issue
Sparky dave is offline   Reply With Quote
Old 06-13-2019, 08:24 AM   #11
mister.freeze
That was my thinking. I guess there's a big difference in when I'm loading and unloading vs going down the road. I'll have to drag it around and have the kids watch it. Maybe its just bouncing on the big tires when empty. I plan to camp in it and they way it rolls around on the suspension is no good. If anybody swapped out some c20 springs to lower theirs I'd be interested...
Copyright ©2000 - 2019, vBulletin Solutions Inc.
