Old 02-10-2021, 01:07 AM   #476
Low Elco
Re: 57 Chevy Wagon - Californa Dreamin'
Fellers, if you think this thing is cool in pictures, it's AWESOME in person. I thought it was cool when it was a beater! Truly a gorgeous piece. Thanks again for saving my skin (again).
Low Elco is offline   Reply With Quote
Old 02-10-2021, 01:56 AM   #477
sduckworth13
sduckworth13's Avatar
I have been lucky enough to see it in person and it really does look phenomenal. I can’t wait to see it all together.
Scott
sduckworth13 is offline   Reply With Quote
Old 02-10-2021, 04:27 PM   #478
Vic1947
Vic1947's Avatar
Hey, Chip. Glad to be of assistance; in return you did me a solid with the coil covers so, many thanks for that!
Thanks, Scott, I'm still hacking away at it.
Took a big step forward on the wiring. The Dakota Digital module is mounted with all the feed wires (except the cruise light) in place. Now I can connect the CAT5 cable to the dash and get it installed. Pretty sure when I do, I'll discover something I forgot and have to take it back out. Seems to be the way it goes.
I found out after the fact that the glove box door stop arm won't let the door close. Hits one of the Vintage Air ducts and refuses to go any further. So I took it off entirely and will do without it. No harm in doing so, just can't use the door as a shelf when it's open. We'll have the console for storage and cup holders anyway.
Victor
57 Chevy Wagon - California Dreamin'
Crusty Rusty Leaky Squeaky 67 Consigned 4/2019 Shipped somewhere across the pond
Silver Streaker "Mecum'd" 4/2013 Gone to Texas
Maybelline - my '57 Ford 2dr Sedan "Mecum'd" 3/2016 Destination unknown
Vic1947 is offline   Reply With Quote
Old 02-11-2021, 04:06 PM   #479
Vic1947
Vic1947's Avatar
The right side duct coming out of the evaporator is right in the way of the glove box arm. I get within about 3/4" of the door being closed and it hits the duct. Didn't want to punch a hole in it so I figured I'd do without and just be careful. However, another forum member suggested using a cable. So I decided to go that route. I believe it will be safer with a travel limiter.
I picked up the stops at AutoZone and already had some 1/16" aircraft cable so it was just a matter of modifying the existing arm and closing up the rectangular hole in the dash. The end at the glove box door is held captive and the cable moves thru the hole very easily - not even any need for a retractor. I put a little piece of shrink tubing over the cable end next to the stop to keep any sharp edges from puncturing the plastic duct tubing. Works nice and smooth and closes correctly.
Victor
Old 02-14-2021, 06:45 PM   #480
Vic1947
Vic1947's Avatar
A bit more progress on the wiring front. The instrument cluster is in and the NAV/HVAC control/speaker enclosure is too. The console would be done also but for receiving incorrect cables from an eBay seller. Had to reorder, so it will be a few days before I can plug in connections for the parking brake, speakers and etc. l sure hope I didn't screw up anything. All circuits are fused but my BIL Rick says fuses are only there as a last resort to keep everything from burning to the ground ...maybe. Probably would be wise at this point to double check everything. I have a reoccurring case of CRS so perhaps even a written checklist.
Victor
Old 02-14-2021, 07:35 PM   #481
Ol Blue K20
truck of four colors!
Ol Blue K20's Avatar
Very nice progress Vic. Looking good!.......
Dale
XNGH ECV Sam Brannan 1004
Ol Blue K20 is online now   Reply With Quote
Old 02-17-2021, 07:32 PM   #482
Vic1947
Vic1947's Avatar
Thanks, Dale!
While waiting on some parts I figured I'd hook up the mechanical throttle body linkage. I picked up a Lokar throttle cable and pedal assembly quite awhile back and had installed the pedal before it went off to upholstery. When I got it back, I could tell the pedal didn't have enough travel due to the newly installed carpet and pad. The fix was to use some 1/2 x 5/8 x 2" aluminum blocks to space it up off the floor. Of course, this caused issues with the arm that goes thru the floor and actuates the throttle cable, so I had to machine an extension for it. I was worried that the additional arc would create too much travel but that turned out not to be the case.
In fact, after hooking it all up and adjusting till I was blue in the face, I still don't have the travel I need. With the cable adjusted to where it just returns to idle, I only have about 90% of WOT. When you read up on it, apparently that's a common problem with this setup. Typically, the advice is to make sure there's no slack in the cable, but if I over do it, the throttle blade won't return all the way to idle. There are all sorts of suggestions as you might imagine - up to and including chucking the cable and going full mechanical. Not an option for me.
Not sure if it will be an issue. I know with carbs, you prefer full open butterflies, but often a partially open secondary works nearly as well as full open. Don't know if it's a big deal with EFI. But I would feel better if the throttle blade opened completely.
Victor
Old 02-17-2021, 07:56 PM   #483
mongocanfly
mongocanfly's Avatar
Could making your pedal extension a little longer solve the issue?....
Mongo...aka Greg
2013 GMC Z71..daily driver
Old 02-17-2021, 08:28 PM   #484
Vic1947
Vic1947's Avatar
I'm sure that would help, Greg. The issue is the alignment between the cable housing and the clevis that attaches to the arm. If I make the arm longer, I'd need to increase the thickness of the blocks under the pedal to keep everything lined up. Not that I couldn't - just that it took me awhile to machine all the parts in the first place. Very specific hole sizes, spacing and metric threads to boot.
OK, I know, I know... metric stuff is probably the root cause.
Victor
Old 02-17-2021, 08:37 PM   #485
mongocanfly
Is this the piece you made?
Mongo...aka Greg
Old 02-17-2021, 08:39 PM   #486
mongocanfly
I know youd have to "adj" the cable bracket to keep it inline, but I was thinking if this piece were a little longer it would increase your pedal ratio without affecting pedal travel
Mongo...aka Greg
Old 02-18-2021, 12:36 PM   #487
Vic1947
Vic1947's Avatar
I agree it would increase the travel. However, I did read a suggestion on a Corvette forum I may try first. You can disassemble the pedal and reposition the splines to change the angle of the pedal. The net result of that is the top edge of the pedal is a bit further back which increases the distance to the carpet. Right now, the carpet is the limiting factor. The built in stop isn't in play because the angle of the arm relative to the pedal isn't quite right.
I need to sit down on a milk carton and see how the pedal feels, though. Don't want to get into a situation where your right foot is at an awkward angle when driving. Will keep you posted.
Victor
Old 02-18-2021, 05:09 PM   #488
Vic1947
Vic1947's Avatar
Latest news...
I removed the pedal assembly and took out the two screws holding the spline'd pillow block. Rotated the splines slightly and reinserted the shaft into the block then reinstalled the screws. As you can see from the before and after photos, the angle between the arm and the pedal increased from around 88 to 97 degrees. With the pedal back in place, this tipped the upper edge back away from the carpet relative to where it sat originally. The pedal angle doesn't seem awkward when sitting in the driving position.
The end result of this geometry experiment is that I now have full throttle opening with no compromise at idle. I will say this though - the pedal action seems a bit lazy. I have to push thru more of an arc to get WOT than I expected. Time will tell if it turns out to be a drive-ability issue.
Victor
Old 02-19-2021, 03:56 PM   #489
Vic1947
Vic1947's Avatar
After reviewing the throttle situation, I determined a possible cause for the lazy pedal action was the hole position in the throttle arm I was using. If I moved the cable stop to the second hole, it would give me a quicker throttle as well as reducing the amount of travel needed for WOT. So I relocated the cable stop this morning to the second hole in the throttle arm and tested the throttle action. I could tell it was quicker with shorter travel as well. However, it still felt somewhat lazy. As you can see in the photos below, the Teflon lined, braided steel hose from Lokar had collapsed with only slight tension applied. It's not really meant for this purpose in the first place, so I shouldn't be surprised. As the result, the Lokar braided steel throttle cable has a new home in the trash bin.
The FITech setup came with an OEM throttle cable, but the ends were not at all what I needed. It was, however, the right length and diameter, so I set about cannibalizing the Lokar ends and transferring them to the sturdier OEM cable. It's a plastic covered, spring wound assembly with a PTFE liner meant for this application. All back together and tested, it operates smoothly and quickly. After several days of dinking around with it, I think I finally have a long term solution.
Victor
Old 02-19-2021, 04:06 PM   #490
mongocanfly
Nice "fix"..!!!!
Mongo...aka Greg
Old 02-19-2021, 11:05 PM   #491
Ol Blue K20
Genious!!
Dale
Old 02-25-2021, 05:32 PM   #492
Vic1947
Vic1947's Avatar
Transported the inner fenderwells, coil covers and grille bar to Hot Rod Express for paint. After considerable deliberation, I decided to go ahead and paint the grille bar in the body color. The spray chrome just wasn't working for me. They offered to try to respray the chrome but I told them "once bitten, twice shy." Wish I'd known they had the ability to do spray chrome before sending the piece to the shop on the east coast. Might have turned out nicer and cost less. Looking forward to getting the parts back so I can get busy installing components like the cruise control, brake vacuum pump, m/c and brake booster, etc. Right now, I'm having to switch among things to do because of a lack of planning.
I machined a billet mount for the fuel regulator, only to find I didn't have the AN fittings I needed to complete the fuel line plumbing. Same for the power steering. I called Roadster Shop to find out what pump pressure would be suitable for the rack and pinion they install on their chassis. They said they go by flow rate and not pressure and sent me a list of parts they recommend for their setup. So the Borgeson pressure kit I purchased was set aside to be replaced by a fitting with a specific orifice size - that I had to order, of course.
I did get the console finalized after getting the RCA cables I needed. It meets my need for an installation that doesn't look entirely homemade like some of my past efforts.
Victor
Old 02-26-2021, 09:15 AM   #493
Ol Blue K20
Coming together nicely. Sucks about the grill bar, but should be nice painted body color.
Dale
Old 03-03-2021, 06:48 PM   #494
Vic1947
Vic1947's Avatar
That's what I'm hoping too, Dale. I've done this long enough to know I have a hard time looking the other way and saying, "Well, I'm not really happy with that, but it will be okay, I guess."
Been working on odds and ends. Built a small enclosure to house the fan relays and the transformer that drives the CCFL rings for my parking lights. Hides a bit of the ugly. Will probably mount it down under the fans somewhere you won't see it anyway, but it was a fun thing to do. Also machined a mount for the oil catch can. I had one on a previous LS3 build and the shop that built my current engine recommends running one. But like everything I touch these days, I'm short some fittings so I'll have to turn my attention to other stuff while I wait on USPS. I have the weatherstrip on the driver door. Wasn't real happy with the technique I used although it turned out pretty decent. Now trying the method Danchuk recommends for their seals on the passenger side.
Victor
Old 03-03-2021, 08:51 PM   #495
mongocanfly
All looks good Vic...what'd you make the relay cover out of?...
Mongo...aka Greg
Old 03-03-2021, 10:28 PM   #496
Ol Blue K20
X2, it looks good!
Dale
Old 03-04-2021, 10:01 AM   #497
Vic1947
Vic1947's Avatar
Thanks, Greg, but I can't take credit for the enclosure. Found it on eBay and stuffed it with my components. The body and lid are made from extruded aluminum and appear to be powder coated. For the princely sum of $10.50 there's no way to justify making one.
X2, it looks good!
Thanks, Dale.
Victor
Copyright ©2000 - 2021, vBulletin Solutions Inc.
Copyright 1997-2020 67-72chevytrucks.com
