Old 11-08-2018, 12:56 PM   #1
stomper
Junior Member
stomper's Avatar
73-80 Side trim adhesive clips
What are you all doing to replace/restore the side trim clips that have the adhesive? I haven't found the clips available from parts suppliers. Do I have to restore what I've got? i.e remove the old adhesive pad and attach a new pad to the plastic clip?
"I was patina when patina wasn't cool."
'73 P10 StepVan 4.8l LS / 4l60e 7 foot floor (short one)
'83 K30 SRW Silverado Factory 454 / T400 / NP205 loaded
'99 C5 Roadster Z51 6spd 170k mi Daily
'61 Bel Air Bubbletop V8 Seamist Turquoise 3rd owner
'86 GMC SWB 350 700r
Past Notable Rigs
'85 K10 Silverado Red / Charcoal
'86 K20 Suburban 6" lift and 35's
'72 K5 CST Tilt Tach Air. Original paint, Med Bronze / Saddle
'71 C10 Cheyenne Short Box, Hugger Orange Saddle Buckets, 350 / 700r 3.73 posi
'68 C10 Stepper, UC Davis truck, 250 / 4 spd
'83 K10 W/T Mahogony 305 / 700r posi
'68 Camaro RS 43k mi 327 California car
'78 GMC Short Box Sierra Classic Heavy Hauler 350 / 350 AC Cruise
'67 Biscayne 2dr 396
'83 GMC SWB 6cyl NP440 4spd OD 65k mi CA truck
stomper is offline   Reply With Quote
Old 11-08-2018, 03:51 PM   #2
75C10
Re: 73-80 Side trim adhesive clips
When I purchased my repro side moldings along with extra clips I found the adhesive tape was poor and required replacing. And the clips didnt fit the moldings quite the same. So off to Pick your Part and gather up GM clips and clean them and then apply new fresh two sided adhesive and then the molding stayed attached. I also reused the GM metal clips as the repros were not good. And I am being kind with my comments.
75C10 is offline   Reply With Quote
Old 11-11-2018, 11:53 AM   #3
stanski
Re-using the original pads with new 3M tape is better than the crappy ones that are supplied with the new repop trim. But, my preference for better adhesion and for getting the trim tight to the body without those ugly air gaps is to put a pea sized dab of urethane windshield sealer on the trim then tape the trim tightly against the body and leave overnight. It works great. If you need to remove the trim down the road, slide a thin steel putty knife against the sealer and a few taps with a hammer and it cuts right through.
stanski is offline   Reply With Quote
Old 11-11-2018, 01:25 PM   #4
stomper
Junior Member
stomper's Avatar
Thanks for sharing your tip! This sounds excellent.
Past Notable Rigs
Old 01-04-2019, 12:39 PM   #5
CDN Sharky
What kind of tape did you use to hold the trim on the truck?
CDN Sharky is offline   Reply With Quote
Old 01-06-2019, 10:10 AM   #6
stanski
Just used masking tape to hold the trim tight to the body till the urethane cures.
Thread Tools
Display Modes
Copyright ©2000 - 2019, vBulletin Solutions Inc.
