Old 01-19-2019, 02:26 PM   #1
WyattTX
Is there a permanent fix for the split AC system in GMT800s?
In my 2004 2500 HD 4x4, the one side of the cab blows cold air, and the other doesn't. It has done this 2 times before, and it was fixed with a new actuator motor both times. I'm getting tired of this. Can I just eliminate the blend door entirely, and just not have a split system (assuming that's all that's blocking the air flow.)? All I want is the same air temperature, and pressure coming out of all the vents. I couldn't care less about having a split system. I just want cold AC. I'll be honest I dont know how these HVAC boxes are set up, so I would appreciate some input before I make the situation worse. Thanks.
WyattTX is offline   Reply With Quote
Old 01-19-2019, 05:41 PM   #2
hatzie
Moderator
hatzie's Avatar
Re: Is there a permanent fix for the split AC system in GMT800s?
Usually it's stripped gears in the actuators. My Gen 8 Impala has the same issue.
If you're killing actuators fairly often you might want to look into how hard it is to move that blend door. The linkage may be worn or have dirt or mice or some other obstruction keeping the door from moving freely.
1959 M35A2 LDT465-1D SOLD
1967 Dodge W200 B383, NP420/NP201 SOLD
1969 Dodge Polara 500 B383, A833 SOLD
1972 Ford F250 FE390, NP435/NP205 SOLD
1976 Chevy K20, 6.5L, NV4500/NP208 SOLD
1986 M1008 CUCV SOLD
2000 GMC C2500, TD6.5L, NV4500
2005 Chevy Silverado LS 2500HD 6.0L 4L80E/NP263
2009 Impala SS LS4 V8
RTFM... GM Parts Books, GM Schematics, GM service manuals, and GM training materials...Please include at least the year and model in your threads. It'll be easier to answer your questions.
And please let us know if and how your repairs were successful.
Old 01-20-2019, 03:10 PM   #3
WyattTX
Thanks I'll be sure to inspect that.
Old 01-21-2019, 09:23 AM   #4
homemade87
When you installed a new actuator did you do a recalibrate process . If no it could be why they are not lasting . It may be trying to go past its perimeters and damaging the unit . It has to learn the limits . It is odd that 2 has failed . As said above , be sure there is no obstruction .
Just google up a recalibration process and try that first . If no help it mat require another .
I don't know how to eliminate any of the functions but this may help solve the problem .
homemade87 is offline   Reply With Quote
