Old 01-20-2012, 12:56 AM   #1
willett
Another Day, Another Dollar
willett's Avatar
anybody running a PTO winch?
I eventually want to toss a PTO on my '78.
I would like to see some photos first though!
-78 K20 Cheyenne 454 long box, 4" lift, 35" MT's, '84 cab, '80 box
"its hip to be square"
willett is offline   Reply With Quote
Old 01-20-2012, 09:43 AM   #2
Re: anybody running a PTO winch?
No,I had a truck with one,and want to put one in my truck some day. Something about a V8 powered winch is just something I love.
Old 01-20-2012, 10:01 AM   #3
madcow75
madcow75's Avatar
I would like the setup myself. Some info and pics would be nice if someone is running the pto setup.
madcow75 is offline   Reply With Quote
Old 01-20-2012, 11:15 AM   #4
V30 mongo
If you want to install a front mounted PTO driven winch on your 78 GM truck first off, is a manual SM465 or a auto? The auto has no PTO provisions. Only the SM 465 has PTO outlets. If so a Chelsea Model 340 or a 352 reversible PTO unit will fit up on the drivers side with the proper input gear installed. The oil filter on the V8 engine will have to be remote located because to shaft to the winch need that space. The winch unit must have a drivers side input. The front bumper and winch mounting must be custom made as no factory made units exist. The shift linkage for the PTO unit also had to be custom made. Is this a lot of work and bother? Sure is! Would I do it again? I think I am too old and worn out now. Does the winch and truck still run? Yes it does, and it still can make any electric winch look like the little toy junk that it is......
V30 mongo is offline   Reply With Quote
Old 01-20-2012, 11:51 AM   #5
RastaRobb
RastaRobb's Avatar
Some of the old Willy's wagons and trucks came with a PTO. Like having a tractor you drive everywhere. They would run a winch on the front, or anything off the back. Pretty slick.
RastaRobb is offline   Reply With Quote
Old 01-20-2012, 12:29 PM   #6
72lb4x4
I think a PTO can be had for the NP205. Not so sure about an NP203 since 78 is around the full time TC time.
72lb4x4 is offline   Reply With Quote
Old 01-21-2012, 10:50 AM   #7
NP 205s have a pto provision. But an automatic with NP208 or NP203 does not.
Old 01-21-2012, 12:57 PM   #8
flyingtim01
willett, my '71 K20 has a PTO driven Braden LU-2. Depending on which wrap, cable size, rpm, etc, it is generally considered to be a 10-12,000 lb winch. The setup on my truck looks very similar to some of the setups I've seen on Dodge trucks from the late 50s and 60s, though I haven't seen any GM trucks with this winch and bumper on it. The Dodge literature from that time calls it an 8,000 lbs winch, I'm sure for liability reasons. The truck has an SM465 and NP205, and the reversible PTO is mounted on the transmission. You can see the custom lever and bracket bolted to the floor next to the shifter.
I'll get some pictures of the driveshaft for you as soon as its out of the snow, but here are some shots from when I first got the truck last spring and started cleaning it up:
I know yours is a '78, so I'm not sure how close the driveshafts would be to what I have in the '71, but I don't imagine they'd be far apart. FWIW, my 350 has the standard length oil filter on it and clears the driveshaft fine. They also make a shorty filter that you could use if space is tight.
That all being said, if someone can identify what model PTO it is that I have, I'd be eternally grateful. Never been able to nail down exactly what it is.
flyingtim01 is offline   Reply With Quote
Old 01-22-2012, 01:35 AM   #9
OrrieG
OrrieG's Avatar
Had one in a jeep M38A1 in the 60's. Loved it because the winch rpm was synced to the transmission speed. Also didn't have to worry about running the batteries down.
Old 01-22-2012, 05:21 PM   #10
freakshow108
freakshow108's Avatar
I had one on the 71 3/4 ton I'm building but I have removed it, it was ran off of the np205 in the truck, and was operated by a pull cable inside the truck. I can get you some picks if you are still interested.
freakshow108 is offline   Reply With Quote
Old 01-23-2012, 12:20 AM   #11
Dooley
Dooley's Avatar
This pic tells of the 203 Full Time transfer case operation and that the "N" position can be used with pto operation.
Dooley is offline   Reply With Quote
Old 01-23-2012, 09:15 AM   #12
Oh ok. I never knew that. I thought I heard they didn't have a PTO provision. I always steered clear of anything with a 203 in it,so know nothing about them.
Old 01-23-2012, 10:56 AM   #13
tanman722001
tanman722001's Avatar
I Wish the one on the back of my car hauler was pto driven.
1991 GMC K2500 4X4 350/auto
1991 Chevy S10 ext cab.
1990 Chevy S10
1993 Chevy S10 Blazer 4dr 4.3 Vortex/Auto
tanman722001 is offline   Reply With Quote
Old 01-23-2012, 02:16 PM   #14
V30 mongo
Flyingtim01 That PTO unit looks like a Muncie RG series. It looks like it is mounted inverted from the parts breakdown. There should be a small plate attaches with four bolts on the end of the case. It is there to check gear backlash. I know it is not a Chelsea because both reversible units from them have a large six bolt cover on the side.
