Old 04-30-2018, 10:09 AM   #1
speedygonzales
speedygonzales's Avatar
Strange HVAC operation..... If you need to replace connectors this may help
For those who don't want to read the whole thing here is a summary:
Either your blower motor only comes on high speed or you have to beat on the controller to make it blow (usually at high speed only)
The blower connector could be bad on the back of the controller
Using the part number for the connector, google a replacement.
You can add a second supply wire so the entire supply current is not on just one pin.
Now for the details.
If you own a 96 – 2000 with a HVAC controller that looks like this:
http://s1371.photobucket.com/user/St...tml?sort=3&o=1
Pay attention. Connectors of all sorts are getting weak or corroded and high resistance is the result. When high(er) current is involved, high resistance equates to high heat. Melting will occur.
Here is a photo of the fan connector on the rear of the controller
http://s1371.photobucket.com/user/St...tml?sort=3&o=2
Here is the harness connector
http://s1371.photobucket.com/user/St...tml?sort=3&o=5
Another view
http://s1371.photobucket.com/user/St...9rncn.jpg.html
So the symptom is you either have to hit the controller to make the fan come on or it usually only runs on high.
Yeah I know everyone will say it’s the blower resistor. NOPE not in several cases. You know the controller is having problems when you have to beat on it. Don’t be fooled by thinking because the blower only runs in high the resistor is shot if you have to hit the controller to get it to come on. Address the problem with the controller first. Chances are good the resistor is fine. If you just replace the resistor first, you are probably throwing money away.
In my case the power coming to the controller was the problem. The black wire got so hot it melted the connector.
Here is the replacement connector and it’s pins. It uses pigtails that have to be soldered in.
http://s1371.photobucket.com/user/St...ndsdr.jpg.html
Sorry it's small
Here’s the lowest cost alternate you can find.
https://www.ebay.com/itm/New-8-Way-F...72.m2749.l2649
Now you can be proactive so this won’t happen to you. You can add a second supply wire so the entire current isn’t going into only one pin. Look at the connector back picture and you’ll see the orange and black wires. There are 2 blank connections unused. If you get the connector kit, splice another pin into the supply line and place the other pin on the far end of the row where the orange wire is opposite the green wire. Look at photo of the burned backside connector on the controller.
If you look at the controller in your vehicle you will see 2 pins are connected together. It’s hard to tell from that photo but there is a unburned pin on the bottom left. Then the melted pin next to it. Then a blank spot next space over to the right. Then a pin on the far right bottom location connected to the burned pin.
The factory chose not to connect to the far right pin, instead only using the second one on the left. I chose to tie into the same wire (black) bringing the second connection to the far right pin. This will alleviate the entire current to the fan motor from going through only one pin. Which obviously is on the hairy edge of disaster.
If in the future you are searching for connectors, you will need the GM part number for them. Fortunately the part numbers are in the factory service manual.
Part number for this connector is 15306189 and you may notice that it’s used in several locations throughout the vehicle.
One last note: These controllers are going up in cost every day. The more reasonable ones are $100 now. The longer you wait to address this issue, the more you're going to pay.
Also, there are several ways to get GM metri-pack connectors. There are kits that contain several. They are expensive.
Don't forget to use google once you have the part number for the connector. I don't usually use Ebay but in this case the least expensive was there.
Incidentally this same connector through the local auto parts stores ran anywhere from about $35 to $180. Yeah I thought I had a bad connection when I asked the guy "did you just allow the words one hundred and eighty bucks to come to out of your mouth"?
99 Z71 (98 body style)
Pride and joy
speedygonzales is offline   Reply With Quote
Old 11-18-2018, 10:30 AM   #2
hatzie
Moderator
hatzie's Avatar
Re: Strange HVAC operation..... If you need to replace connectors this may help
If you have the Delphi connector number, and not just the part number for the repair pigtail, there are several sources in the electronics world for GM-Delphi connector tooling, raw terminals, and empty connector shells.
They range from big multinational outfits like Mouser, DigiKey, and Newark Electronics to the medium size US outfits like Waytek and DelCity to the small Mom-N-Pop websites like The Electrical Depot
1959 M35A2 LDT465-1D SOLD
1967 Dodge W200 B383, NP420/NP201 SOLD
1969 Dodge Polara 500 B383, A833 SOLD
1972 Ford F250 FE390, NP435/NP205 SOLD
1976 Chevy K20, 6.5L, NV4500/NP208 SOLD
1986 M1008 CUCV SOLD
2000 GMC C2500, TD6.5L, NV4500
2005 Chevy Silverado LS 2500HD 6.0L 4L80E/NP263
2009 Impala SS LS4 V8
RTFM... GM Parts Books, GM Schematics, GM service manuals, and GM training materials...Please include at least the year and model in your threads. It'll be easier to answer your questions.
And please let us know if and how your repairs were successful.
burned wires, connectors wiring, metri-pack
