Old 12-10-2018, 09:33 PM   #1
saddletramp
72 Sierra Grande Help
Evening Guys im replacing my inner rockers and outer rockers i found that both rockers on my truck were replaced and done poorly i need some measurements from one of you guys from the top of the drip rail to the top of the outer rocker , and if one of you guys have a truck your working on with the outer rocker off i need thise same measurements that would be Awsome also Many Thanks .
saddletramp is offline   Reply With Quote
Old 12-10-2018, 09:56 PM   #2
rjs53
Re: 72 Sierra Grande Help
Are your cab corners gone? Did you cut the original out already? I replaced mine but did it in steps so lined the outer rocker with the cab corner and took some measurements off the front so I would know where it went in relation to the original. Tacked it in place then put the door onto make sure it looked right. I'm sure someone on here measured though.
2003 Dodge 2500
1969 C10
2014 Camaro SS/RS/1LE
rjs53 is offline   Reply With Quote
Old 12-10-2018, 10:10 PM   #3
saddletramp
Thanks for the response half of my cab corners are gone so it worked out good cause ive had to replace my rear cab support,s that gave me alot of room to cut and weld the new ones
Old 12-10-2018, 11:33 PM   #4
LockDoc
The Older Generation
LockDoc's Avatar
I have a Cheyenne Super with the drivers side outer rocker off and the passengers side on. I can get a measurement in the morning if you don't get anything before that.....
LockDoc
Leon
Old 12-11-2018, 06:18 AM   #5
saddletramp
Morning Sir that would be great if you can do that for me i really appreciate that if you could i need the center of the drip rail and on both ends with the outer rocker on and outer rocker off over the years some one did some crazy repairs Thank You very much . Saddletramp
Old 12-11-2018, 11:46 AM   #6
LockDoc
LockDoc's Avatar
OK, the side with the rocker on measures 47 1/4" - 47 1/2" & 47 3/4" starting at the back, measuring from the top edge of the drip rail to the inside lip that sits next to the outer edge of the floor & 50" - 50 1/4" & 50 1/2" from the top edge of the drip rail to the outside edge of the rocker where you would check the door gap.
The side without the outer rocker on measures 48 1/4 - 48 1/2/ - 48 3/4 starting from the back, measuring from the top edge of the drip rail to the top of the original inner rocker. Let me know if you need anything else or more clarification on this.
LockDoc
Leon
Old 12-11-2018, 03:19 PM   #7
saddletramp
Afternoon Doc what you sent me is perfect, when i got this truck it was in bad shape the roof was bad so i found a donor roof off a 72 ,with cab lights ,im not sure if im keeping them on it plus it has been in a wreck on the passenger side corner and these rooker,s are such a mess my front and back windows fit good these measurements you gave me are perfect Im just trying to save a American piece of iron from the crusher Thank you very much for your help i might call on you again .Saddletramp
Old 12-12-2018, 12:26 AM   #8
LockDoc
LockDoc's Avatar
Good deal. Keep us updated on your progress.
LockDoc
Leon
