Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Electrical
Old 12-30-2011, 06:39 PM   #51
john_p
Re: 'cigar lighter' kill switch?
i moved the wire from the key and ran it to one side of a horn button.. mounted the horn button in the bottom of the lighter, after gutting it.. turn the key to own, press the lighter in to engage the starter.. the now vacant post on the key went to the horn relay..
thought that was very clever back in the 60's. of course i showed every one i knew..
john_p is offline   Reply With Quote
Old 12-30-2011, 06:48 PM   #52
john_p
you can put a relay in series with anything on the truck.. that object would have to be on for the truck start.. if you wanted to get fancy, truck would not start without the lights on first, or the radio..
as long as the coil of the relay is in series, and the hot wire to the ignition switch runs through normally closed contacts of the relay.. with a few more tricks, you could get a lot fancier.. i usually use horn relays for junk like that..
Old 12-30-2011, 11:57 PM   #53
rayfinseats
All you have to do is put a on/off switch somewhere and run the HEI wire through it. Just hide it really good. Be creative. All a switch does is break the circuit.
rayfinseats is offline   Reply With Quote
Old 01-01-2012, 01:37 AM   #54
john_p
without cutting a wire, you can remove and fuse,, connect a wire to both sides of the fuse holder.. add an inline fuse and run that to your switch
Old 01-01-2012, 01:40 AM   #55
john_p
a two position push button works in the bottom of the lighter.. push on, push off
