Old 10-31-2006, 09:45 AM   #1
el curioso
el curioso's Avatar
73+ booster on a 72 ??
can a booster from a 73 be used on a 72 chevy C-10 or does it have to be from a 72??
1969 Chevy C-10 350/700r4
el curioso is offline   Reply With Quote
Old 10-31-2006, 03:31 PM   #2
Aarons72s
Re: 73+ booster on a 72 ??
Yes they can, have herd about it and seen it a couple of times on the board. Here is a bump for you.
Aaron
Aarons72s is offline   Reply With Quote
Old 10-31-2006, 06:44 PM   #3
qksilver
Been working on that swap between many other things. A few new holes need to be drilled in the mounting bracket, you will have to fab the rod between the pedal and booster, plus remember to drill a hole 1 1/4 down from the manual hole on the brake pedal for P/B. That way the leverage is correct.
No I don't have pictures but line stuff up and it is really obvious what needs to be done
qksilver is offline   Reply With Quote
Old 10-31-2006, 07:11 PM   #4
zden
i swapped in a booster and aluminum master cylinder from an '82 into my '72. all i had to do was drill 2 top holes in the bracket. the rod fit just fine that came on the booster. the only thing i had to change was the plastic tube that seals to the firewall since i already had power brakes i used the tube from my old booster. got the booster and master cylinder at o'rielly's for about $100 bucks. hope this helps
1966 Chevrolet Suburban
1955 Chevrolet Bel Air
zden is offline   Reply With Quote
Old 10-31-2006, 08:56 PM   #5
Brad
Out of the carpool lane.
Brad's Avatar
Here's one for sale, lol. Ready to bolt on and go. I had this on my 67 and it works great with no problems!
http://67-72chevytrucks.com/vboard/s...d.php?t=214044
1968 C-10 SWB, 5.7 Vortec/700R4/3.73 posi, Torch Red
1968 Camaro, 250/Powerglide, all original (No, I'm not gonna drop a 350 in it!...Jeez!)
2000 Honda VFR in the faster yellow!
2008 Husqvarna TE-610
1967 C-10 SWB 'Six Appeal'-Gone but not forgotten...
Brad is offline   Reply With Quote
Old 11-01-2006, 09:22 PM   #6
qksilver
You did what i had to do!
