07-17-2010, 01:05 AM | #1 |
Home Made obd scanner ??
on my 1991 crew cab (square body like a suburban) it is running like a diesel and the check engine light is on, I remember someone telling me that on safari's up to 1995 you could use a short piece of wire to jump the connectors where you would normally plug in a scan tool and then the engine light would flash xx many times slowly and then xx many times quickly ( like morse code almost) which would give you a code # (for example 2 long then 3 short for # 23)
I assume this works on the trucks too but i dont remember the exact spots to "jump" Also if any one has a link to how to decipher the codes E.G. code 23 bad ign coil, that would be much appreciated
1991 V3500 350TBI/4l80/205 D60/14bff - Crew long 1987 IrocZ-28 525 horse/567 Lb Tq 383 1976 K30 on 39.5s One wheel drive thanks to a np203 and some K5's lol |
07-17-2010, 01:16 AM | #2 |
gets board easy.......
Re: Home Made obd scanner ??
stick a paperclip in the A and B terminal on your OBD connector under the steering wheel,
while looking at it, A will be the upper right, and B will be the one just next to it, to the left, turn key on, and start counting the enging light Last edited by 63chevyll; 07-17-2010 at 01:16 AM. |
07-17-2010, 01:54 AM | #3 |
Thanks You
do you happen to know where to find out what the codes correspond to (other than in those chilton manuals i cant find mine right now)
07-17-2010, 01:58 AM | #4 |
if you post the codes we can help you out,
ill be outa town this weekend, but post them anyway |
07-17-2010, 02:11 AM | #5 | |
In the Forgotten far North.
Each code will flash 3 times before moving on to the next code. First and last code to flash will be code 12 which will be *(pause)** (long pause) *(pause)** (long pause) *(pause)** a bit of a longer pause will happen before the next trouble code will flash, again 3 times. Once all trouble codes have flashed it will flash code 12 again. It'll continue to do this as long as you have the key turned on and the paperclip plugged into terminals A & B. Heres a listing of the codes I found online for ya. GM OBD-1 Diagnostic Trouble Codes For 1995-previous model year EFI-equipped GM vehicles. NOTE: Some codes not supported on all models, consult your specific vehicle's service manual for the correct trouble code list and description for your application. DTC - 12 No distributor reference pulse (diagnostic test active) DTC - 13 Oxygen sensor circuit open or no activity DTC - 13 Left bank O2 sensor circuit open or no activity DTC - 14 Engine coolant temp sensor error (high temp indicated) DTC - 15 Engine coolant temp sensor error (low temp indicated) DTC - 16 System voltage too low DTC - 17 Camshaft position sensor error DTC - 21 Throttle Position sensor error (signal high) DTC - 22 Throttle position sensor error (signal low) DTC - 23 Intake air temp sensor error (low temp indicated) DTC - 24 Vehicle speed sensor error (open circuit or no activity) DTC - 25 Intake air temp sensor error (high temp indicated) DTC - 26 Quad Driver Module (QDM A) error DTC - 28 Auto transmission range pressure switch error DTC - 31 Wastegate solenoid circuit error DTC - 31 Gear Position Switch (PRNDL) error DTC - 32 EGR system failure DTC - 33 MAP sensor circuit error (signal high indicating low vacuum) DTC - 34 MAP sensor circuit error (signal low indicating high vacuum) DTC - 35 IAC problem or idle error DTC - 36 MAF sensor error DTC - 36 24x Crankshaft position sensor circuit error DTC - 36 4T60-E Shifting Error DTC - 37 TCC brake switch circuit error DTC - 38 TCC brake switch circuit error DTC - 39 Clutch switch circuit error DTC - 39 TCC error DTC - 41 Ignition control error DTC - 41 MEM-CAL error DTC - 41 C³I Cam Sensor Signal error DTC - 42 Ignition bypass circuit error DTC - 43 Knock sensor error DTC - 44 Oxygen sensor error (lean condition indicated) DTC - 44 Left bank O2 sensor error (lean condition indicated) DTC - 45 Oxygen sensor error (rich condition indicated) DTC - 45 Left bank O2 sensor error (rich condition indicated) DTC - 46 Pass-Key II (VATS) system error - circuit out of freq range DTC - 47 UART (serial data) circuit error DTC - 51 PROM error DTC - 51 Incorrect MEM-CAL DTC - 52 Fuel cal-pak incorrect or missing DTC - 53 System voltage too high DTC - 53 Digital EGR Valve solenoid 1 error DTC - 54 Fuel pump circuit low voltage DTC - 54 Digital EGR Valve solenoid 2 error DTC - 55 ECM error DTC - 55 Digital EGR Valve solenoid 3 error DTC - 56 Quad Driver Module (QDM B) error DTC - 57 Boost Control error DTC - 58 Trans fluid temp sensor circuit error (low voltage) DTC - 58 VATS system error DTC - 59 Trans fluid temp sensor circuit error (high voltage) DTC - 61 A/C system performance DTC - 63 Right bank O2 sensor circuit error DTC - 63 MAP sensor circuit signal voltage high (low vacuum indicated) DTC - 64 Right bank O2 sensor lean exhaust indicated DTC - 64 MAP sensor circuit signal voltage low (high vacuum indicated) DTC - 65 Right bank O2 sensor rich exhaust indicated DTC - 66 A/C pressure sensor circuit error (low pressure indicated) DTC - 67 A/C pressure sensor circuit error DTC - 68 A/C clutch relay circuit error (shorted to ground) DTC - 69 A/C clutch relay circuit error (open circuit indicated) DTC - 69 A/C high pressure switch error DTC - 70 A/C pressure sensor circuit error (high pressure indicated) DTC - 71 A/C evaporator temp sensor circuit error (low temp indicated) DTC - 72 VSS signal circuit error DTC - 73 A/C evaporator temp sensor circuit error (high temp indicated) DTC - 75 Digital EGR solenoid #1 circuit error DTC - 76 Digital EGR solenoid #2 circuit error DTC - 77 Digital EGR solenoid #3 circuit error DTC - 79 Transmission fluid overtemp DTC - 80 Transmission component slipping DTC - 82 3x Crankshaft position sensor circuit error DTC - 85 PROM error DTC - 86 A/D error DTC - 87 EEPROM error (flash memory error) DTC - 90 TCC error DTC - 93 Transmission pressure control solenoid circuit error DTC - 96 Transmission system voltage low DTC - 98 Invalid PCM program DTC - 99 Invalid PCM program
1987 R3500 CREW CAB DUALLY (BIG RED)Acquired 06/12/2015 1990 chevy suburban V2500 5.7L My cluster Mods-Nov 2007 overhead console Stereo install Round 2 Aug 2009 Heated/turn signal mirror upgrade |
07-17-2010, 02:30 AM | #6 |
The internet really is a valuable tool, Thank you very much
I nominate this thread for a sticky so that these codes/procedures will be easily located by all
07-17-2010, 10:05 AM | #7 | |
Still plays with trucks
I had one where the circuit board broke free of the case and was in limp home mode that wouldn't flash a code 12.
miSSed opportunity - ground up creation of an AWD 1994 454 SS that never was http://67-72chevytrucks.com/vboard/s...d.php?t=795577 69 C10 shortbed stepside 400 small block - built like what a super sport truck could have been 69 K20 lwb TBI 350 4L60E NP208 14-bolt Dana-44 w/disc 68 Camaro SS / RS 500hp 439 inch roller cam big block 4L80E 79 Malibu TPI 350 4L60 w/ Z28 steering & sway bars |
07-17-2010, 10:22 AM | #8 |
I tried the paperclip method on my 91burb and couldn't figure it out so I went to the auto parts store and they will do diagnostics test for free.
07-17-2010, 10:26 AM | #9 |
Good info, guys.
Do I also understand correctly that you can't do this on a '96 and up vehicle (specifically a '97 Suburban) because of more stringent OBD requirements? K
Chevrolet Flint Assembly 1979-1986 GM Full Size Truck Engineering 1986 - 2019 Intro from an Old Assembly Guy: http://67-72chevytrucks.com/vboard/s...d.php?t=342926 My Pontiac story: http://forums.maxperformanceinc.com/...d.php?t=560524 Chevelle intro: http://www.superchevy.com/features/s...hevy-chevelle/ |
07-17-2010, 10:29 AM | #10 |
Correct if I'm wrong but I think it only works on OBD1 plugs as the 95 and newer trucks have a completely different plug OBD2
07-17-2010, 10:36 AM | #11 |
Here is a website for obd-codes http://www.obd-codes.com/faq/read-gm...codes-free.php
07-17-2010, 01:48 PM | #12 |
paper clip only on 95 AND OLDER, 96 and newer needs a scanner
