06-08-2023, 12:57 AM | #1 |
Coolant Overflow Bottle
What is the best factory appearing radiator overflow bottle anyone has come up with? I figure there must be some GM car or truck that used one that fits well and looks right in a '67-'72.
1967 GMC CM-2500 Camper Cruiser, 351E V-6, NP 435 4 speed, Dana 60, and factory A/C. 2012 GMC K-3500 WT regular cab, 6.0L Vortec, 6L90. |
06-08-2023, 03:13 AM | #2 |
Location: Falls City, Nebraska "100 Miles From Nowhere"
Re: Coolant Overflow Bottle
I use this washer bottle and bracket. I simply run a 5/16" or 1/4" hose from the radiator filler neck barb to the bottle. Use a 16 PSI Lever lock radiator cap and your radiator stays full and drip free. Bottle should be about half full when the engine is up to temp. https://www.lmctruck.com/1967-72-che...per-and-washer The bracket, bottle and cap, and enough hose to plumb it. LMC has the bottles backordered but Classic Parts has them. One of the venders here will surely have these as well... https://www.classicparts.com/Misc-Wi.../products/294/
Michael of the clan Hill, "Two Seventy Two's" 71 1-ton Dually 350 4-Speed 71 C/50 Grain Truck, 350 Split-Axle 4-Speed 02 3/4 ton Express 14 Indian Chief Vintage 1952 Ford 8N, "Only Ford Allowed On The Property" "Be American, Buy American" |
06-08-2023, 05:04 AM | #3 |
I have one for a late '70s Nova.[?] It's an OER part. Got it from Jeg's. Kind of a teardrop shape, but it tucks perfectly inside the passenger/side fender, next to the battery box.
Sorry I can't recall P/Ns, and my pix are trapped on my old computer. The only drawback was that I had to pull the battery carrier to mount it. It's suspended by a single bolt thru the pass/side fender, just aft of the fusible link terminal. Most of the weight is borne by the inside fender skirt.
06-08-2023, 06:38 AM | #4 |
On my '71 4x4 I used a factory mount bracket and W/S washer bottle like is found on the driver's side and mounted it to the passenger side just aft of the battery. Use a 16 lb. closed system cap with the safety release lever and some clear vinyl tubing. Keep it at about 1/3 full when cool, works well and looks as if it is a factory install.
1971 Chevy 1/2T 4x4 LWB 350 V-8 Was sm465-now 350TH/np205 Tilt, Tach, Towhooks Original Truck AM/FM Wellington, Ks |
06-08-2023, 07:23 AM | #5 |
1967 C10 Step side 1968 C10 Step side 1970 Chevrolet K/5 Blazer 1972 Chevrolet K/5 Blazer ............. |
06-08-2023, 10:19 AM | #6 |
I used the washer bottle and bracket as well. It looks like it belongs there. I used an S-10 washer bottle with a pump for the windshield washer.
I have sworn upon the altar of God, eternal hostility against every form of tyranny over the mind of man. - Thomas Jefferson |
06-08-2023, 10:36 AM | #7 |
This is a $11 Dorman "coolant recovery" tank (read it is like a modern closed system vs "overflow")
I used a spacer to match the offset from core support on one of the 2 attachment screws. The hole for the hose from radiator is already in the core support. Coolant recovery tanks require a "closed system" cap. You fill radiator completely up vs leaving them 3" low for coolant expansion. As coolant heats up it expands into the "recovery" tank and when the motor cools, it is drawn back into radiator. The hose from radiator goes into the bottom of the tank vs the top of a "overflow" only tank so it can be drawn back into radiator, like a modern cooling system. https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1 The tank noted that would fit inside PS fender is for a 75 Nova ($45 on Summit). I have one in my 67 Camaro. My 72 C10 has the vapor canister in that area so I elected to go Dorman route on the truck |
06-08-2023, 11:21 AM | #8 |
The hose on an overflow tank goes to within 1/2" of the bottom of the tank. It works the same way. Manufacturers have built them like that for years. Modern cooling systems on most vehicles incorporate the tank into the cooling system (it's under pressure), so there is technically no recovery tank.
06-08-2023, 12:55 PM | #9 |
Thanks! I will look into the Nova bottle. Saw on the web some use a G body bottle, it's curved on the bottom and fits on the right inner fender too.
06-08-2023, 12:59 PM | #10 |
This is the 75 Nova tank I put in my 67 Camaro. It should also work on a C10 unless you still have EVAP canister installed
06-08-2023, 05:42 PM | #11 |
I bought another windshield washer tank for a '72 right off the parts board here. I mounted it on the core support same as in post #6. Works great, and looks like it was meant to be there.
1972 Chevy C-10, SWB, Fleet, 350/350, PS, PB, all stock, Survivor. |
09-06-2023, 05:44 PM | #12 | |
Never mind, I found them. But is it really 4.25" wide (front to back)?
Mike 1969 C10 LWB -- owned for 34 years. 350/TH350, 3.08 posi, 1st Gen Vintage Air, AAW wiring harness, 5-lug conversion, 1985 spindles and brakes. 1982 C10 SWB -- sold 1981 C10 Silverado LWB -- sold, but wish I still had it! 1969 C10 (not the current one) that I bought in the early 1980s. Paid $1200; sold for $1500 a few years later. Just a hint at the appreciation that was coming. Retired as a factory automation products salesman. Worked part-time over the years for an engine builder and a classic car repair shop. Member here for 23 years! This is the very first car/truck Internet forum I joined. I still used a dial-up modem back then! Last edited by MikeB; 09-06-2023 at 05:59 PM. |
09-06-2023, 06:52 PM | #13 |
Some impressive and functional mounting ideas here.
The tucked away Nova one in particular. I used an aftermarket windshield washer tank. Works well.
Sam 1972 C10 LWB 2020 Z71 Tahoe |
09-06-2023, 07:13 PM | #14 | |
09-06-2023, 08:11 PM | #15 | |
https://www.oerparts.com/product/all...ts/551448.html
Die with memories, not dreams. Not to brag, but I don't need alcohol to make really bad decisions. 1969 GMC Short Step Side |
09-06-2023, 08:26 PM | #16 | |
But, Yeah, that's it. Looks like they went up another $5 in price. But I got mine from Jegs. I had the Nova puke tank installed on my '68 C/10 Stepside, but the 292 runs so cool, I didn't need it, so I moved it over to my '71 GMC Jimmy K/1500 w/ a 350. Still working out the bugs. The Radiator shop repaired my 4 core copper/brass radiator OK, but they ignored my instruction to clock the filler neck relief outlet to the rear at 6'o'clock.
Every 25 years I like to rebuild that 292, whether it needs it or not. Last edited by '68OrangeSunshine; 09-06-2023 at 08:34 PM. |
09-06-2023, 08:46 PM | #17 | |
09-06-2023, 08:50 PM | #18 | |
My old Batt Box was corroded thru, so I had to replace it anyway.
09-07-2023, 09:00 AM | #19 |
A member used a '90's GM van tank
The 1972 OEM tank:
1970 K/5 Blazer CST 4WD, Bronze, 93k ACT. miles, 350, 4 speed, positraction, 16.5" x 8.25" wheel option, tilt, tach, vacuum, AM/FM, manual throttle...Dad ordered and purchased new 4/70. Currently frame off restoration in progress... 1972 Cheyenne Super 20 2WD, DK Blue/White, 90K ACT. miles, 402, TH400, 4.10 open, tilt, tach, vacuum, A/C, AM/FM, manual throttle.. A mostly original paint never rusted Texas survivor... 2017 Sierra 1500 SLT 4WD, Black, 41k miles, 5.3, 6L80E, 3.42 LS, 20" polished wheels, everything but moonroof and 6.2... 2019 Canyon SLT 4WD, White, 60k miles, 3.6, 8L45, 3.23 LS, 18" wheels |
09-07-2023, 10:05 AM | #20 |
I have electrical stuff mounted in two of those areas, and A/C hard lines in another, but you all have given me some ideas.
Mike 1969 C10 LWB -- owned for 34 years. 350/TH350, 3.08 posi, 1st Gen Vintage Air, AAW wiring harness, 5-lug conversion, 1985 spindles and brakes. 1982 C10 SWB -- sold 1981 C10 Silverado LWB -- sold, but wish I still had it! 1969 C10 (not the current one) that I bought in the early 1980s. Paid $1200; sold for $1500 a few years later. Just a hint at the appreciation that was coming. Retired as a factory automation products salesman. Worked part-time over the years for an engine builder and a classic car repair shop. Member here for 23 years! This is the very first car/truck Internet forum I joined. I still used a dial-up modem back then! Last edited by MikeB; 09-07-2023 at 10:16 AM. |
09-07-2023, 01:05 PM | #21 | |
If you see my pic I used a spacer to absorb the gap for the PS hold down screw to core support. |
09-07-2023, 08:49 PM | #22 |
Mine.
09-09-2023, 01:20 AM | #23 |
my set up on '72 C10 with 350 from the Atlanta plant
'72 C10 Cheyenne SWB North Carolina truck for 50 years, 72k original miles, Medium/Hawaiian Blue, 3 owners - one for 40 years, garaged kept, original: sheetmetal, undercarriage, moldings, glass * * * New - engine rebuild at 65k in 2015, one repaint in 2010, new front bumper, houndstooth seat, carpet, 8 inch rally wheels on 275-60R-15, LED lighting. - Semper Paratus! |
09-09-2023, 12:29 PM | #24 |
Someone needs to repop that 994230 kit!
