Old 01-10-2018, 09:20 PM   #1
C series suspension/engine crossmember questions
I'm trying to find out what C series front suspension/engine crossmembers will interchange, all I'm wanting to know about is the crossmember none of the suspension components. Are they the same from a c10, c20, or c30?
I maybe swapping a 69 c10 over to disc brakes and I have everything from the controls arms out from a 78 c10 that is in good shape. Just trying to find out what crossmembers from 73-87 are the same or what I need to look for when I go to buy one. I used the 78 crossmember I had replacing the rusted one in my 86 GMC.
flatbed82 is offline   Reply With Quote
Old 01-11-2018, 11:11 AM   #2
SCOTI's Avatar
Re: C series suspension/engine crossmember questions
Upper a-arm studs are larger on C20's/30's.
73-87 x-members might require a couple of holes to be opened up/re-drilled when used on pre 73 chassis.
Motor mount stands can/do vary in height between 6x-72's & 73-87's.
Brake line mounting tabs are in different locations.
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
Building a small, high rpm engine
with the perfect bore, stroke and rod ratio is very impressive...
like a highly skilled Morrocan sword fighter with a Damascus Steel Scimitar.
Cubic inches is like Indiana Jones with a cheap pistol....
Powered by vBulletin® Version 3.8.7
Copyright ©2000 - 2018, vBulletin Solutions, Inc.
Copyright 1997-2013
