Old 12-14-2017, 04:34 PM   #1
51Chevy3100
Steering column/shaft issue - Guidance Needed
Hey guys, I have an issue with my steering on my 1987 Chevy V30 4x4. I switched from the rag joint style to the u joint style shaft (jeep conversion) awhile back. I recently took my body lift off so I took the shaft out because I couldn't get it to adjust to the new ride height.
I know I need to get it moving and have a plan for that but my concern is that the "D" part on the intermediate shaft (I believe that's what it is) where it goes into the column thru the firewall moves in and out and I know it should stay in place. What do I need to replace to get it right? Bearing?
This picture is not of mine, just a reference of what I'm talking about. My truck doesn't have the part that the retainer clip goes thru or anything...the shaft just goes in the column and has side to side and in and out play.
1951 3100 Patina "Under Construction"
Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=636116
87 V30 1 ton Mud Truck
51Chevy3100 is offline   Reply With Quote
Old 12-23-2017, 03:55 PM   #2
Pontiac1976
Pontiac1976's Avatar
Re: Steering column/shaft issue - Guidance Needed
Bearing lower may going. shaft may be loose. broken parts in side.
It maybe time to take the steering wheel off check what going on in it.
http://bowtieguy.proboards.com/threa...r-repair-renew
this may help
1977 REG cab Long Bed with a 1984 Front Clip, 82 305 .60 over 9.0.1 flat top pistons, 4bbl, TH350, w/84 SS-intake & cam , w/ 1977 big block rad, 1975 gear box, 1984 master w/ metric fittings top & SAE fitting @ portion block, 1975 3.42 gear open diff. Duel 77-87 Factory air cleaner, duel inlet from rad support . Down sized 9' to new 8' Steel flat bed
Was a 77 454 w/308 gear. Taken out 550 lbs. up front with motor clip change.
Pontiac1976 is offline   Reply With Quote
Old 01-11-2018, 10:53 PM   #3
51Chevy3100
this may help
Thanks for the reply! I robbed some parts from another steering column. Turns out my lower bearing and plastic retainer were completely gone. I just didn't know what was missing because I didn't know what was supposed to be there. Always learning something!
Copyright ©2000 - 2018, vBulletin Solutions Inc.
