Old 01-12-2018, 03:20 PM   #1
sick472
sick472's Avatar
'76 350 into an '85 3/4 ton 4x4
I have my old '76 2wd that has a GM 350 crate motor with 70K miles on it and my '85 3/4 ton 4x4 is burning a lot of oil (like a quart every 1000 miles. maybe more). The '76 is almost see-through due to rust. Both are automatics and AC trucks. Neither have any real power to speak of. The '85 has an edelbrock intake and Holley carb with unknown heads and is a 350 ci as well.
My questions...what should I be aware of if I chose to swap the motor from the '76 into the '85? Would it be straight forward or will I have to make mods?
I'd love for this to be a one weekend chore should I pull the trigger.
Thanks in advance!
Ride On,
Sick472
sick472 is offline   Reply With Quote
Old 01-12-2018, 03:25 PM   #2
natedogg
natedogg's Avatar
Re: '76 350 into an '85 3/4 ton 4x4
This will be a easy swap. All the pulleys and brackets from your 85 will swap over to the 350 out of the 76. You and a buddy should be able to do this in a weekend.
1985 C10 Silverado swb
1984 GMC C1500 Sierra Classic swb
1981 C10 Cheyenne swb (sport mirrors)
1985 C10 Custom Deluxe swb
1987 GMC R1500 Sierra Classic swb
1986 C10 Silverado swb (sport mirrors)
1984 C10 Custom Deluxe swb
1987 R10 Silverado lwb
natedogg is offline   Reply With Quote
Old 01-12-2018, 07:40 PM   #3
MikeB
MikeB's Avatar
Should be a piece of cake, especially if you're going to use the intake and carb off the 85's current engine. But there's always some little issues to iron out. Seems like 85 engines had passenger side dipstick, whereas 74 had drivers side. But that shouldn't be any big deal. I would transfer any parts like intake manifold, oil & temp senders, and kick-down cable bracket while both engines are out. And that's also the time to make sure the 74's starter will bolt to the 84's electrical connectors.
Mike
82 C10 Custom Deluxe SWB -- original paint, 355/TH350, Vortec heads, GM RamJet 350 roller cam
69 C10 LWB -- Bought in 1989, now my son's
Retired as a factory automation products salesman.
Worked part-time over the years for an engine builder and a classic car repair shop.
Member here since 2000. This is the very first car or truck forum I joined!
MikeB is offline   Reply With Quote
Old 01-16-2018, 09:38 AM   #4
sick472
sick472's Avatar
Thanks for the encouragement folks!
I guess it's time to just wait for the old 85 engine to expire or use so much oil that I can't take it anymore. I think it is constantly leaking by the valve seals as I never see any oil smoke or leaks big enough to compare to the oil loss. The spark plugs need to be freshened-up/changed every year or so (5000 miles) because of oil fouling. Compression is from 170 to 200 psi and the pcv valve has been changed. There is no coolant loss either. Anyhow, this may be something for a different thread. Thanks again!
Ride On,
Sick472
Old 01-16-2018, 01:44 PM   #5
Junqueboi
Junqueboi's Avatar
If the dipstick is on a different side, you may have to swap out exhaust manifolds...which means your exhaust pipes will no longer fit -> trip (tow?) to muffler $hop. I think a lot of the crate engines had dipstick provisions on both sides though. You'll just have to check I guess.
Jel
Junqueboi is offline   Reply With Quote
Copyright ©2000 - 2018, vBulletin Solutions Inc.
