10-06-2018, 10:07 PM | #1 |
Can a heater core be installed updise down? Effects?
The heater core on our 70 Blazer has the 3/4" outlet on the bottom and 5/8" on top.
IIRC, the 3/4 goes to water pump and 5/8 goes to the intake, with the hoses crossing over. Will it hurt anything if the 3/4 heater core is on the bottom, and I run it to the water pump? It's my understanding is that if you switched the intake and water pump fittings, the heater wouldn't get hot. Thanks in advance. Wes
1970 2WD K5 1968 Camaro Conv 1967 Chevy SWB 1964 Malibu SS 1957 Corvette Pics www.picturetrail.com/wesmigletz |
10-06-2018, 11:22 PM | #2 |
Re: Can a heater core be installed updise down? Effects?
I may be wrong but my understanding is the hoses are different sizes to make it unlikely they would be switched during manufacturing. The idea is to have the inlet on the bottom and the outlet on the top to allow the air to vent out of the core and not get trapped.
Thanks to Bob and Jeanie and everyone else at Superior Performance for all their great help. RIP Bob Parks. 1967 Burban the WMB,1991 S(stink)-10 Blazer,1969 GTO, 1970 Javelin, 1952 F2 Ford 4X4, 29 Model A, 72 Firebird. 85 Alfa Romeo If it breaks I didn't want it in the first place The WMB repair thread http://67-72chevytrucks.com/vboard/s...d.php?t=698377 |
10-13-2018, 06:12 AM | #3 | |
Still plays with trucks
Your assumption about the heater not getting hot if you switched the source fitting locations is correct to a point. You can run the supply through the 5/8" line at the bottom of the blower housing from the water pump and the return from the top out the 3/4" side back into the intake and have the heater work close to correctly in your case. It just won't have the designed in back pressure that slows the flow down to let the water lose its heat through the heater core as efficiently. You will have to decide if this loss of performance is acceptably offset by the time & labor of going through the process of pulling the blower housing to flip the heater core so it is in the correct orientation to make the heater work as intended. As to where the supply line needs to come from I would stick with the water pump just above the lower radiator hose outlet where the factory put it as that is the hottest water source. Sometimes there isn't a spot for a fitting there on new water pumps like the Edelbrock aluminum one I have and you have to compromise with an alternative location. Square body trucks dump the 5/8" line back into the radiator directly just above the transmission cooler top fitting so you can pick any spot on the engine to pull the 3/4" supply line from if your radiator has that fitting and the heater will still work, just not as well if you pick the wrong place. You want the water before it has gone through the radiator but after it has gone through the engine so it is as hot as it gets and heats up as quickly possible for the cold days when the heater and defroster are needed the most.
miSSed opportunity - ground up creation of an AWD 1994 454 SS that never was http://67-72chevytrucks.com/vboard/s...d.php?t=795577 69 C10 shortbed stepside 400 small block - built like what a super sport truck could have been 69 K20 lwb TBI 350 4L60E NP208 14-bolt Dana-44 w/disc 68 Camaro SS / RS 500hp 439 inch roller cam big block 4L80E 79 Malibu TPI 350 4L60 w/ Z28 steering & sway bars |
10-13-2018, 11:52 AM | #4 |
There’s one thing incorrect I see in your post 68TT.
The line at the water pump is a suction line, not a pressure line. Just sayin’! |
10-13-2018, 04:53 PM | #5 |
Thanks for the feedback. I'm still confused.
As long as I keep the 5/8" in the intake, and the 3/4" in the water pump, It will still work? My Blazer is still in TX and I'm working in CA for now, and only get home for a weekend at a time, and have very little time to work on it. If it will work good, I will leave it alone. If it won't heat the Blazer up enough for a North Texas winter, I will correct the heater core orientation. Thanks again, Wes
10-13-2018, 05:23 PM | #6 |
You want the hoses to run from the intake to the bottom of the core, from the top of the core back to the pump.
You can leave your core alone and swap the hose barbs on the intake and water pump so they match the sizes on your core. The barb fittings should interchange but if they don’t you can get ones that do fit. Here’s some examples of barb fittings in different sizes. https://www.smpbuyersguide.com/4seas...-guide/757.php |
10-13-2018, 06:29 PM | #7 | |
