Closed Thread
Old 02-07-2011, 08:36 PM   #1
70BLAZERX2
has anyone put a tach cluster from a 94 into a non tach 94?
Mine is a 94 no tach..but i want the tach dash cluster in it..
And can the V8 cluster be switched to V6 ?
Just checking to see if anyone has done this before.
70BLAZERX2 is offline
Old 02-07-2011, 09:17 PM   #2
dishow
dishow's Avatar
Re: has anyone put a tach cluster from a 94 into a non tach 94?
i sold a guy a tach dash out of a 93 with a 350. he was putting it in a 94 4.3. called me to say eveything hooked up and worked great,cause i told him if it didnt,bring it back. thats all i can say about it.anyone else?
90 Chevy 454 ss
dishow is offline
Old 02-07-2011, 11:27 PM   #3
ChevyTech
Originally Posted by 70BLAZERX2 View Post
...And can the V8 cluster be switched to V6 ?
It can be done but to make the tachometer accurate you have the swap out a part on the circuit board.
Capacitor (C103) if different.
A V8 uses a .002475uf (2475 pf).
The V6 uses a .0033uf (3300pf).
I had a link about this topic, but it no longer works.
ChevyTech is offline
Old 02-08-2011, 05:34 PM   #4
70BLAZERX2
Ok..i will get me a cluster and get it in there.
Old 03-22-2011, 07:10 PM   #5
70BLAZERX2
I got a cluster out of a 94 truck with tach and it was a 350 truck
Where is the diode i have to change?
Old 03-22-2011, 07:18 PM   #6
70BLAZERX2
another pic of small board
Old 03-23-2011, 08:40 PM   #7
bpeters5814
bpeters5814's Avatar
Not to thread jack, but if you're swapping a non-tach cluster with a tach cluster, is it just plug and play? My trucks got a 350, if that helps.
bpeters5814 is offline
Old 03-24-2011, 12:18 AM   #8
seth is usdm
seth is usdm's Avatar
yea more info the better. if someone could chime in with a list. for instance the newer style like that with tack for my moonie style...
1979 chevy blazer 2wd drop spindles shackles new paint wheels tires custom one of badges cut on waterjet brakes exhaust carpet 2" cowl hood window seals misc weather seals door panels crate 350 w/ 67k turbo 350 3.08 rear end gear ratio FOR SALE!
http://67-72chevytrucks.com/vboard/c...ct=4838&cat=13
seth is usdm is offline
Old 03-26-2011, 09:03 PM   #9
70BLAZERX2
I have a 94 with the 4.3 V6 and this tach cluster is a 94 with 350 w/tach cluster..I want to add the tach to the V6 truck...I know the tach will be off if i just plug it in...I want to fix it while its out.
Closed Thread
