Old 12-02-2017, 12:41 PM   #1
Mmo
72 blazer park brake to drum
I'm stuck?!
Bought all new park brake cables, mounts, pedal assembly from LMC. Everything they have for a new park brake install I bought. also all new rear drum brake hardware, shoes, springs clips. Everything I could see.
But, missing a lever that connects the park brake cable that goes inside the drum to the shoes themselves. Appears to be called a toggle lever elsewhere. I have the horizontal bar and the adjuster hardware. LMC just doesn't seem to show this missing part for left and right. May need a spring with it too.
Anybody know what I'm talking about?
Mmo is offline   Reply With Quote
Old 12-02-2017, 12:47 PM   #2
jjzepplin
jjzepplin's Avatar
Re: 72 blazer park brake to drum
Yeah. It has a spring on one side and hits both shoes above the axle. I think it is called an equalizer.
70 swb 4x4 406sbc 700r4 203/205 d60/14blt locker yadda yadda http://67-72chevytrucks.com/vboard/s...88#post6935688 Yeller
72 Blazer 2wd conversion project "No Daggum Money" http://67-72chevytrucks.com/vboard/s...d.php?t=550804 LS1-T56 3.73 LSD super budget build
Blanco-2014 Sierra SWB https://67-72chevytrucks.com/vboard/...d.php?t=810350
jjzepplin is offline   Reply With Quote
Old 12-02-2017, 10:31 PM   #3
Spf79
Spf79's Avatar
Been here before, I found that you will probably have to go to a wrecking yard for that part. The spring is available through Dorman parts. Sorry man. ;(
Full top blazer or bust....
Spf79 is offline   Reply With Quote
Old 12-04-2017, 10:43 AM   #4
Mmo
thanks for answering
LMC doesn't seem to have. i found it at bills truck stop, and they're apparently shipping it to me. the park brake lever and spring.
Old 12-04-2017, 02:15 PM   #5
6768chevylover
6768chevylover's Avatar
Take it off your old brakes your replacing. I cleaned mine and put it back on.. Don't know anyone that sells that bracket except bone yards.
6768chevylover is offline   Reply With Quote
Old 12-05-2017, 03:54 PM   #6
Mmo
thanks, but this is an entire new install as previous owner had the entire park brake system removed. i finally found the last park brake bits from bills truck stop, and they were delivered to my house today.
so one less hurdle. not easy to install. and can't yet see where the cables mount to the frame.
cheers
