08-22-2018, 07:38 AM | #1 |
wtb shifting rods from a 67-72 3 speed
I am needing a set of shifting rods from a 67-72 c10 with the 3 speed on the column price shipped to 72560 Thanks
http://67-72chevytrucks.com/vboard/s...d.php?t=548705 |
08-22-2018, 08:11 AM | #2 |
Re: wtb shifting rods from a 67-72 3 speed
i will ship you a set for $50 total. They are from a 6 cyl truck saginaw transmission.
08-22-2018, 08:26 AM | #3 |
6 cyl. or V8 ?
08-22-2018, 08:58 AM | #4 |
08-22-2018, 09:40 AM | #5 |
The rods that shoveldug has should work for you.
08-22-2018, 05:02 PM | #6 |
Do you have paypal
Posted via Mobile Device |
08-22-2018, 10:57 PM | #7 |
If nothing works out I have a bunch of the rods. But they are all mixed up and I'd need help sorting out what is what
08-23-2018, 06:18 AM | #8 |
Yes I do. It is dwl65101@yahoo.com I also sent you a PM
08-23-2018, 07:31 AM | #9 |
Ok money sent Thanks
09-01-2018, 07:44 PM | #10 |
Just a heads up the shifting rods from a 67-69 chevy truck will not fit a 65 with a 68 3 speed transmission
09-01-2018, 08:33 PM | #11 |
Those were 67-72 6cyl rods for 3spd, correct? And you are saying those will not work on a '65 with V8 and 3spd. So have you tried 60-66 V8 rods for 3spd? Is the engine mounted in the 6cyl position (dist. back into the firewall) or the V8 position?
09-01-2018, 09:10 PM | #12 |
They will not work on my truck. I have a 350 with a 68 3 speed. The truck is a 65. The rods are too short and will not clear the firewall and the clutch z bar. I was under the truck a while trying everything to make them work. I have not tried the 60-66 v8 rods. I think the engine is in the 6 position but not sure. The original bell housing was in the truck when I got it bolted to the factory cross member right behind the engine.
09-02-2018, 10:45 AM | #13 |
Are the engine frame stands in the front or rear holes? How much room between the distributor and firewall?
09-02-2018, 09:08 PM | #14 |
The back holes but like I said the bell housing is bolted to the front cross member. It cannot move forward to my knowledge Any way I went today to buy a tranmission and driveshaft from a guy and ended up buying the whole truck so I will have everything I need to put the right 3 speed in it
