10-19-2010, 05:19 PM | #1 |
air bags again
Could I install my bags and just use individual schraeder valves for the time being until I set up a bag system? I really want to run bags but since I wont be running the whole set up should I just go with springs till I get the whole package?
Posted via Mobile Device |
10-19-2010, 05:50 PM | #2 |
Registered Cruiser
Re: air bags again
You can do that, that's how mine is set up for now.
10-19-2010, 06:00 PM | #3 |
Nothing to see here.....
Re: air bags again
like jnj said, it's quite acceptable to run schraders. to get the same fill in each bag, get a good digital tire pressure gauge, and viola!!
Doug THANK YOU to our American Soldiers & Veterans - POW MIA "You will NEVER be forgotten". The democracy will cease to exist when you take away from those who are willing to work and give to those who would not. Thomas Jefferson |
10-19-2010, 06:33 PM | #4 |
Re: air bags again
Cool, I was thinking there would less of a chance for a leak since there is less plumbing.
10-19-2010, 07:16 PM | #5 |
Re: air bags again
install all of your fittings with the proper Loctite, wrap a piece of rubber heater hose around the air tubes when they pass through metal, and you should have a tight, reliable system....
10-19-2010, 08:51 PM | #6 |
low n' slo
Re: air bags again
ive used loctite on my setup and no leaks. whichever you feel comfortable using, both should work fine.
tcb-1, is that your new ride in the avatar?
67 1/2 ton Suburban - Project DRGNWGN. Build thread -_--_--_ _________ _--_-_ -/____|__|__\__ ,.,,,.,.,,.,|_O _______ O_] |
10-21-2010, 09:12 PM | #7 |
Re: air bags again
why yes it is!! still GM too!
10-21-2010, 09:26 PM | #8 |
Re: air bags again
I just use teflon tape, at least 3 full wraps and no leaks
69 chevy stepside (project) 2006 Silverado Z71 Ext. cab 2005 Saturn VUE (wifes dd) |
10-21-2010, 10:57 PM | #9 |
Re: air bags again
thanks for the help guys. I may consider just bagging the rear for the time being till I can afford my ultimate bag set up. I bought the truck undriveable. It's tore down to the frame so just trying to get my rolling chassis built and hopefully be able to drive it next summer!
