12-14-2018, 07:40 PM | #1 |
Old member
Cold & rainy
I decided to look at the brakes on my 71 today. I've had some minor issues with them so I figured today was as good as any to look at them.
The pedal had way more play than I like so I got to looking at it. It had some play in the pin that hooks to the master cylinder rod. I started by taking the booster loose from the bracket and placed 2 washers on the bottom 2 bolts and 1 washer on the top 2. This took the play out of it completely. I didn't get to drive it yet it's pouring down raining so that will happen later. I then decided to paint the master cylinder so I cleaned it up good then used the black caliper paint. Man what a big difference it made. I may paint the top red but I think it would be worthless after putting the hold downs on a few times.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
12-14-2018, 09:21 PM | #2 |
Re: Cold & rainy
Nice! Can you step me through the process with your master cylinder? Did you remove it?
I just put a whole new booster, MC and prop valve assembly on mine and the MC showed rust after only a few days. It'd be great if I could clean mine up like that.
-Jim 71 Chevrolet C20 94 GMC Yukon 4x4 |
12-14-2018, 09:49 PM | #3 | |
Old member
Re: Cold & rainy
I then just wired brushed it down good with a big brush and a small one. I got it as clean as possible then wiped it down with brake cleanner. Let it dry good and then brushed on the paint. I didn't take it loose but if you want it want hurt a thing.
12-14-2018, 10:05 PM | #4 |
Re: Cold & rainy
Right on. Thanks for the info
12-14-2018, 10:28 PM | #5 |
Old member
Re: Cold & rainy
This stuff is thick so put it on thin. I did 2-3 coats. I'm thinking about doing the top in red also.
12-15-2018, 12:32 AM | #6 |
Re: Cold & rainy
looks good, just the little things
12-15-2018, 09:15 AM | #7 |
Old member
Re: Cold & rainy
That's correct, it's amazing how such small details can make such a huge impression on the over all look.
I'm retiring at the end of this year and plan on a one a week detail of my 71.
12-17-2018, 01:20 PM | #8 |
Re: Cold & rainy
One more question, Andy: when you cleaned and painted did you do this with the MC lid on or did you remove the lid and mask it some other way?
Thanks, Jim
12-17-2018, 08:47 PM | #9 |
Old member
Re: Cold & rainy
I took the keepers off and just let the top sit there.
