Old 03-12-2016, 10:39 PM   #51
brushbuggy
brushbuggy's Avatar
Re: 70 suburban build
I am amazed at how you can get so much done in so little time. Your work ethic is to be greatly admired. Keep up the great work. Is that a 64 Bonniville taillight I see in the garage?
Thanks,I enjoy doing this stuff. Yes it is I did a 5.3 4l50 swap in it.
brushbuggy is offline   Reply With Quote
Old 03-12-2016, 10:41 PM   #52
brushbuggy
brushbuggy's Avatar
Originally Posted by 72MARIO View Post
Why did you recess the sending unit into the tank that low ? Was the 2001 module assembly not deep enough to reach he bottom of the tank ?
The body is only 1" above the tank ,so I recessed it to clear the floor.
Old 03-12-2016, 10:46 PM   #53
brushbuggy
brushbuggy's Avatar
I sold the burb to a guy that just had to have it, but I did find a 69 pickup to replace it.
Old 03-17-2016, 12:19 AM   #54
71_Burb
Whats the plan for the truck ? do you remember how much you took off the drive shaft and roughly the cost ? I have a complete 2000 silverado ext cab im going to pull for my Burb
Appreciate any info ..
Dave
71_Burb is offline   Reply With Quote
Old 03-17-2016, 03:21 AM   #55
brushbuggy
brushbuggy's Avatar
Dave
I picked up a 03 5.3 4l60e with harness and pcm $700 for the 69. about 1.5" off the drive shaft , the machine shop changed the u joints and carrier bearing for $250.
