Old 05-13-2019, 12:16 PM   #1
rmneder
transfer case mounts.
Hello everyone,
Is there a trick to getting the transfer case mounts on? I can't seem to get it. I had my transfer case out to change the seals in the adapter and while pulling it atf got all over the mounts. I took them off to clean the area up and now can't get them back on. The mounts are polyurethane and still like new. I'm sure they're the right ones because they were on there fine before. The crazy thing is I put them on a few years ago and now can't get it. Thanks in advance for any help.
rmneder is offline   Reply With Quote
Old 05-13-2019, 07:21 PM   #2
Bones72Super
Bones72Super's Avatar
Re: transfer case mounts.
The mounts on the passenger frame rail or on the crossmember?
WTB 71-72 Original paint Medium Red hood
Bones72Super is offline   Reply With Quote
Old 05-14-2019, 09:24 AM   #3
gmc684x4
Here is the tcase mount out of the shop manual
gmc684x4 is offline   Reply With Quote
Old 05-14-2019, 09:30 AM   #4
gmc684x4
here it is in pic
Old 05-14-2019, 11:25 AM   #5
rmneder
It's the crossmember mounts. What I'm having trouble with is the crossmember has a big lip around the bolt holes that the mounts seat into. I can't get the mounts to seat properly on the crossmember. It's hard to explain unless you've seen it. When I get home from work I'll take a picture.
Old 05-15-2019, 11:41 AM   #6
rmneder
Okay, I figured out the problem. I'm stupid. The mounts have a plastic insert in them that go through the bolt holes. When I remove the mounts from the crossmember they pulled out of the mounts and remained in the crossmember. It looked like they were part of the crossmember itself. When I tried to reinstall the mounts I was trying to get them reseated on the plastic inserts and there was no way that was happening. So problem solved. I feel really dumb and was going to let this thread drift off into obscurity but decided to bite the bullet and confess.
Copyright ©2000 - 2020, vBulletin Solutions Inc.
