09-14-2020, 11:02 PM | #26 |
Re: 66 cluster/gauges questions before reinstalling
Thanks the test I ran with the 12v energizer took the needle from the left to the middle only. Is that normal? Or should it go all the way to the right?
09-14-2020, 11:16 PM | #27 |
Thanks Ray, I retrofitted it and from what I can tell its moving to 3/4 of the way then settles at the half mark. This seem right?
09-15-2020, 05:48 PM | #28 |
I got this in the mail today with some parts I ordered, tells me how to read the ammeter. Half way would mean normal so if a voltmeter is no different I think I have a working customized gauge.
09-15-2020, 06:55 PM | #29 | |||
As you've already noticed, the 12v reading is right about mid-scale on your customized gauge so the key on / engine off battery voltage should be pretty close to that (maybe just a tick higher). You could use a couple of 1.5v batteries (like AA or AAA cells) connected in series with the 12v battery to bring the test voltage up to 15v. That would give you a reference point for the maximum voltage you should see under normal operating conditions. |
09-15-2020, 07:20 PM | #30 |
Thanks so much Ray, at least I know now I can continue on with the restoration on the cluster. I'll try out adding 2 more AAs to the mix to see how far that needle goes. Ive never paid attention to that gauge before which I guess was the right call since it wasnt working right anyway before. But from here Ill watch and see with key on / engine off that at least the half way mark is what I should consider good.
