05-20-2018, 09:56 AM | #1 |
turbo 350 slip yoke ?
getting a little ting noise sometimes from going from park to drive ,vice versa and checked everything and saw the slip yoke has some side to to side play. DO you grease the inside of slip yoke or do I need a new yoke
05-21-2018, 11:06 AM | #2 | |
Active Member
Re: turbo 350 slip yoke ?
The drive shaft u-joints also may be making the ping sound. They will make a ping or clicking sound like that when shifting from reverse to drive or like yours, from park to drive.
68 GMC 250/3 speed Saginaw p/b p/s 69 Chevy 350/350 currently in pieces still lookin for a cab 06 Trailblazer I just want a vehicle that I can work on, that won't talk to me, leave error msgs or keep track of how I drive... |
05-21-2018, 05:43 PM | #3 |
It sounds like you need a new tail shaft bushing. They do wear out. You just remove the tailshaft housing (4 bolts) and drive the bushing out with a drift if I remember correctly. I'm surprised it isn't leaking more if you have side to side play.
76 Chevy K20 76 GMC K15 77 Chevy C10 77 Chevy K10 |
05-21-2018, 07:19 PM | #4 |
Active Member
Yeah, meant to say bushing not a bearing.
Regarding lubing the slip yoke. IIRC there's a special lube that you can use on the slip yoke but not sure which one it is. One other thing you want to check is see if there are any wear grooves on the slip yoke. A transmission shop once told me they could sleeve one of mine that had a groove but I decided to buy a new one.
05-22-2018, 08:38 AM | #5 |
thanks I forgot to mention it does leak alittle I just wondered about the grease inside as I saw alot of clunk issues like this on u tube but all were newer trucks.
