06-19-2018, 09:07 PM | #1 |
Need to fuze hei?
Converting to hei dist. Wiring to unfuzed spot on panel. Do i need an inline fuze ? If so, what size? Thanks.
"You are not forgotten" USMC 75-79 (Aviation Ordnance Tech- F-4 Phantom) 1959 H-D Panhead. Owned since 1978. Currently with son in Lawton, OK. 1968 Chevy Custom SWB pick up. Fleetside. Lowered 4/6. Totally refurbished. 1966 Pontiac GTO. 4 speed. Saved original 389. Now has slightly built 455 engine. 355 rear gears. Very fun to drive ! |
06-19-2018, 10:09 PM | #2 |
Re: Need to fuze hei?
The normal place it is powered from on the firewall connector is unfused. So, you do not need to fuse it. You can fuse it if you like and it won't hurt anything. A 5 to 10 amp fuse will be plenty.
06-20-2018, 02:19 PM | #3 |
Msgt USAF Ret
I don't think the factory ever fused the HEI but it is thought that the voltage surges possible with the external regulator could lead to failure of the module in the distributor.
VetteVet metallic green 67 stepside 74 corvette convertible 1965 Harley sportster 1995 Harley wide glide Growing old is hell, but it beats the alternative. |
