Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Paint & Bodywork
Old 07-21-2017, 08:45 PM   #1
71meangreenc10
Its a Truck Thing......
71meangreenc10's Avatar
Base Coat/Clear Coat or Single Stage
Will be painting the Blazer soon and I am still undecided on the product. I've shot BC/CC before and it is not that bad. Have not shot Single Stage yet.
Thoughts from those that have......
Smitty
71 C10 283/3SPD Full Resto
71 GMC 1500 Sierra Grande http://67-72chevytrucks.com/vboard/s...d.php?t=518599
70 C10 Suburban Former military GSA truck.
72 Chevy Blazer 4X4, Sloppy Jo, Mountain Climber. Wife says no more trucks. http://67-72chevytrucks.com/vboard/s...d.php?t=707378
72 GMC 1 Ton Motor Home, wife said no more trucks until she saw this one. Gen 3 6.0/4L80E 4.10 http://67-72chevytrucks.com/vboard/s...d.php?t=761110
68 GMC Suburban was 3/4 ton, now 1/2.Wife shook her head
71 C30 Wrecker
71 C20 Scott-Bilt As weird as it gets..BB Cheyenne AC Truck
68 GMC Long Stepside. They keep following me home
71 C20 Longhorn/Ole Yellor
69 C30 Former Motor Home, Flat Bed time
71meangreenc10 is offline   Reply With Quote
Old 07-21-2017, 08:48 PM   #2
ApacheIvan
ApacheIvan's Avatar
Re: Base Coat/Clear Coat or Single Stage
Subscribed. Interested as well.
Dale - ApacheIvan
1972 Chevy Custom/20 Custom Camper Highlander
http://67-72chevytrucks.com/vboard/s...d.php?t=740479
Original Owner
** Do you have a 1972 Plaid Pickup?**
ApacheIvan is offline   Reply With Quote
Old 07-21-2017, 10:05 PM   #3
68c10airstream
68c10airstream's Avatar
BC/CC is obviously a must for metallic colors to do it properly. Single stage is cheaper overall and is great for a solid color. Personally i like the added depth using clear coat but it costs more, longer painting times can equal more debris in the paint. I haven't painted very much through the years but these are my thoughts. Good luck and i hope others chime in because this is what these guys do for work.
68c10airstream is offline   Reply With Quote
Old 07-21-2017, 10:57 PM   #4
71meangreenc10
I also noticed the color of primers can add depth to a color.
Smitty
71 C30 Wrecker
Old 07-21-2017, 11:03 PM   #5
Foot Stomper
Foot Stomper's Avatar
The color of your primer makes a difference if you are spraying low hide paint. Buy high hide paint, it takes less paint. If you can see primer through your paint, you haven't put enough on...thus, buy high hide paint.
You could spray it in single stage and then clear it while it's open. This will give you more DOI (depth of image) and give you a finish that you can buff.
So when is this "Old enough to know better" supposed to kick in?
My 1959 GMC build thread http://67-72chevytrucks.com/vboard/s...d.php?t=686989
Foot Stomper is offline   Reply With Quote
Old 07-21-2017, 11:23 PM   #6
71meangreenc10
How do you know the difference in the two? Is it on the label or does the person making the mix know?
The Green I shot on my GMC looked lighter on grey primer, shot it over black and it was much darker. The clear then took it to another level.
Smitty
71 C30 Wrecker
Old 07-22-2017, 10:47 AM   #7
sevt_chevelle
Lost amongst the CORN
sevt_chevelle's Avatar
Smitty
Its called experience, and often times cheap paint. PPG's value brand "OMNI" is thinner then PPG's good DBC. Often times due to poor coverage one spends more in OMNI getting it to cover then you could have spent just buying DBC.
Some times its just the color. But if you are allowing the primer color to dictate the final color its simply because you are NOT using enough coats.
I've had GM's Indigo Blue in DBC take 9 coats before achieving proper coverage.
Currently working on How To Videos and custom metal
70 Chevelle gettin Sliced and Diced Anything But STOCK
70 Chevelle SS455 not a typo its a BUICK BABY
49 and 72 Chevy Trucks restored to original...close to it
Drommer Stor....Norwegian for Dream Big
http://s969.photobucket.com/albums/a...lle/?start=all
https://www.flickr.com/photos/47922830@N03/
Pictures of my work and projects
sevt_chevelle is offline   Reply With Quote
Old 07-22-2017, 11:07 AM   #8
Flying Hamster
Flying Hamster's Avatar
Depends on color as well. Black and dark colors look better in a single stage because BC/CC gets those white reflections/highlights out in the sun. A single stage doesn't do that.
2006 Sierra RCSB V6 5 Speed RWD.
Flying Hamster is offline   Reply With Quote
Old 07-22-2017, 11:53 AM   #9
71meangreenc10
Could have been the color on my truck. I used two different panels and used the same process and the coverage was 180 different. Didn't use a HF gun either on the paint.
Smitty
71 C30 Wrecker
Old 07-22-2017, 11:55 AM   #10
71meangreenc10
I guess I could go either way with Orange.
Smitty
71 C30 Wrecker
Old 07-22-2017, 12:00 PM   #11
Foot Stomper
Single stage sure does have highlights in the sun. Some colors look like a Christmas or Easter candy that you want to lick!
I think you might be confusing metallic colors with bc/cc? You can't get metallic in single stage but obviously can in bc/cc. Metallic and pearls are used almost 100% these days on modern cars with the exception of the recent Mopar products in their orange, green and blues they are coming out with. Most red's and whites have traditionally been solids for many years, but not all of them. The Cadillac white pearl is an example of one that is not a solid.
