Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Racing and high performance (trucks haulin more than hay)
Old 09-03-2009, 10:43 AM   #1
Lugnut64052
Middle-aged Curmudgeon
Lugnut64052's Avatar
Warming up a 454
I'm collecting ideas for a "what if" scenario.
I have a chance to get an '87 1-ton, 454 tbi truck for essentially free if I want to drive it away. Been toying with the idea of installing the engine in my '72. I lurked over at 454ss.com for a while, looking for a baseline on a solid "roast the tires" buildup, but can't seem to find one.
If you guys were going to do this and keep the tbi, what mods would you make so that it'd run streetable strong?
Heads?
Cam?
Intake?
PROM?
All suggestions appreciated.
Bret
Check out the site's Truck Tech FAQ.
Be a site supporter.
My more-or-less pathetic build thread.
Board members I've met:
Longhorn Man
Dieselwrencher
jholley
big mike71
Lugnut64052 is offline   Reply With Quote
Old 09-03-2009, 07:26 PM   #2
ripdog28
ripdog28's Avatar
Re: Warming up a 454
no mod you do will be benefited from the TBI. anything you do may raise your power a bit but the TBI will hold it back unless you do some big mods to the TBI.
69 c-10 BBC
462ci, forged crank, H-beam rods, 10.5-1 KB forged pistons, Dart Iron Eagle 308cc, Straub Cam, Comp Cams chrome moly full rollers, Weiand Team G, Prosystems 950, TH400/3500 Dalenzie stall, Currie 9+ Detroit Locker w/31spline axles.3.5/6in drop. My Build.
ripdog28 is offline   Reply With Quote
Old 09-03-2009, 08:31 PM   #3
fiddy9apache
fiddy9apache's Avatar
throw the heads away, there junk unless you want a high tq low hp engine. tbi is nice but its not really great for making power, i would look at a nice intake and carb.
but you found a good big block complete big block with all the acc. for free so no matter what your ahead of the game.
so heres what i would buy...
good set of heads
team g intake
750 quick fuel carb
cam(2000-6500rpm range)
roller rockers
stall converter
gears
headers
if you find a set of factory square port, closed chamberd heads they will be so $$$ that its cheaper in some cases to buy some iron aftermarkets
fiddy9apache is offline   Reply With Quote
Old 09-08-2009, 10:27 PM   #4
Lugnut64052
Thanks guys.
I know the TBI has low power potential, but for a daily-driver it sure runs well.
Might be fun to go back to a carb on this one.
Bret
Longhorn Man
Dieselwrencher
jholley
big mike71
