11-04-2008, 01:02 AM | #1 |
can you mount rack and pinion to stock crossmember?
Just wondering if this is possible.
Blazer Project |
11-04-2008, 01:37 AM | #2 |
Re: can you mount rack and pinion to stock crossmember?
Possible, but a lot of work to get it set-up properly.
www.PorterbuiltFabrication.com Phone: 480-297-2621 E-mail: sales@pbfab.com Find us on FaceBook under Porterbuilt Fabrication Specializing in Chassis and Suspension Components for your Classic Chevrolet Truck. We offer components from the following manufacturers: Porterbuilt Accuair Ridetech (Air Ride Technologies) Air Lift Wilwood Intro Unisteer ECE Gotta Show Air Lift Borgeson CPP Supporting this forum since 2003! |
11-04-2008, 09:19 PM | #3 |
Nate, can you elaborate?
CHEVY ONLY |
11-05-2008, 01:09 AM | #4 |
The most difficult part is locating a rack with the proper inner to inner pivot dimensions, that can be easily mounted in the proper location. If I recall correctly the inner to inner tie-rod pivots on the factory drag-link is 24". Mustang, and a few other racks can be purchased with this same inner tie rod length (The mustang being the most common, and the most affordable). The only problem is that when the rack pivots are located in their proper position (X, Y, Z coordinates) it puts the rack mounts in the u-bolts and crossmember. There's ways to do it... it just becomes involved.
I looked into doing this mod a long time ago, and ended up going another route.
11-05-2008, 01:19 AM | #5 |
thanks for the info
CHEVY ONLY |
11-05-2008, 09:46 AM | #6 |
11-05-2008, 09:55 AM | #7 |
Good enough for cloning . . ..... .
11-05-2008, 11:28 AM | #8 |
11-05-2008, 11:34 AM | #9 |
sheesh, here you guys go turning another thread into a Nate-worshiping, man-crush thread
CHEVY ONLY |
11-05-2008, 01:02 PM | #10 |
No worship or man-crush here.
67SWB-B.B.RetroRod 64SWB-Recycle 89CCDually-Driver/Tow Truck 99CCSWB Driver All Fleetsides @rattlecankustoms in IG Building a small, high rpm engine with the perfect bore, stroke and rod ratio is very impressive. It's like a highly skilled Morrocan sword fighter with a Damascus Steel Scimitar..... Cubic inches is like Indiana Jones with a cheap pistol. Last edited by SCOTI; 11-05-2008 at 01:02 PM. |
11-05-2008, 11:16 PM | #11 |
Cant you just weld on a tab or something to the crossmember and attach it that way?
Blazer Project |
11-05-2008, 11:31 PM | #12 |
i tried to get on here before you edited and added "or man-crush" just poking fun...... gottwake, believe the problem is not the actual mounts, but the fact when you have the rack where it needs to be, the lower control arm u-bolts cause interference, so you will have to modify how the lower control arms attach to the cross member
CHEVY ONLY Last edited by joe231; 11-05-2008 at 11:32 PM. |
11-05-2008, 11:33 PM | #13 | |
11-05-2008, 11:44 PM | #14 |
CHEVY ONLY |
11-06-2008, 10:42 AM | #15 |
Fair enough Joe 231. All hopes crushed, in a single response...
Blazer Project Last edited by gottwake; 11-06-2008 at 10:42 AM. |
11-06-2008, 11:13 AM | #16 |
I don't think anyone is saying it can't be done....anything is possible cause you know, It is only metal Not to the point of doing the rack yet, but fellow board member Scotts62 is planning a rack and pinion on his '62 with a '73-up stock cross member and custom frame......
CHEVY ONLY |
11-06-2008, 11:25 AM | #17 |
One day...
Yep im going to work on it gottwake if that makes you feel better about trying it
11-06-2008, 01:37 PM | #18 |
Sweet. You can practice on mine if you want?? Your not too far away...I actually used to live in Ardmore, OK
Blazer Project Last edited by gottwake; 11-06-2008 at 01:38 PM. |
11-06-2008, 05:23 PM | #19 |
CHEVY ONLY |
11-06-2008, 06:21 PM | #20 |
Epoxy Primer Friendly
I did mine like stated and it works perfectly fine. see my build thread
11-06-2008, 09:11 PM | #21 | |
One day...
Heck yeah put a stamp on it and send it on over! |
11-07-2008, 12:08 AM | #22 |
Camaro thunder...man that is bad a$$. How did you do that? What R&P is that out of?? Take some close ups for us!!!
Blazer Project |
11-07-2008, 01:36 AM | #23 |
CHEVY ONLY |
11-07-2008, 12:57 PM | #24 |
One day...
x3
11-07-2008, 02:02 PM | #25 |
I will as soon as I can.
Really busy getting both trucks ready for the show on Nov. 15th. |
