02-05-2019, 07:09 PM | #1 |
400 TH transmission & flex plate install, torque & thread locker?
Working on a 1971 402 / 400 TH Transmission. Anyone know the torque settings for:
Flex plate to crank flange (bolts include star washers) Transmission to engine block Torque converter to flex plate Also, where do you recommend using thread locker? Thank you
Tony 71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assm. guide "kit" for restoring it from ground up. With assys, the guide accts for 1000s of OEM identifications and part numbers, all written in short order. 700+ images include assm, illust., charts, and points of interest. Much of the info. applies to all 67-72 GM trucks, and to a lessor degree all 67-72 GM vehicles. My build thread, and more on the guide https://67-72chevytrucks.com/vboard/...d.php?t=730025 |
02-06-2019, 01:20 AM | #2 |
Re: 400 TH transmission & flex plate install, torque & thread locker?
Flex to crank 65 with a drop or 2 of loctite
convertor to flex 45 drop or 2 of the same trans to block 30-35, nothing needed, personally I always put in a stud on each side to help guide the trans into place then use a flange nut to tighten it down |
02-06-2019, 02:24 PM | #3 |
Awesome. I came across a thread, and what was mentioned adds up to your recommendations........Thank you.
