11-25-2017, 10:56 AM | #1 |
70+ ( Old Skool Club )
Hard Starting Problem.
After 2 years I finally got this 1992 Burb 4 x4 with the TBI 5.7 engine from an estate. The Burb sat for 3/4 years before I bought it. It runs and drives great but have one annoying issue. I've had a few GMT400's with the 5.7 TBI engine and they start within 5 seconds of turning the key. This Burb wont start on the first try after cranking for 15 or so seconds. On the second crank it fires up after 5 seconds. I've changed the plugs, fuel filter and it has tank of fresh gas, has no codes and runs smooth as silk once it starts. Oh yea it only has 156,000kms ( 96000 miles ) on it and has never pued anything as there is no hitch. Anyone got an idea what hard starting probem could be as its super annoying.
1972 C10 Custom/Deluxe 613 Highlander 406/700R4 1999 White Tahoe LS 4x2 with Z56 Police Package 1992 K1500 GMC Suburban Members I have personally met: MusicMan70 - HeavyD - ChewyChevy67 - StingRay -71SWB4x4 - 67 Burb - DeadheadNM - too much stuff - bc65 - das601 " Circumsatances Do Not Change Responsibility " " The Sky is not the Limit, Your Mind is." Marilyn Monroe .. RIP Charlie Watts 1941 - 2021 Last edited by Already Gone; 11-25-2017 at 11:57 AM. |
11-25-2017, 11:30 AM | #2 | |
Re: Hard Starting Problem.
Check out my thread below "intermittent hard starting / rough idle". I recieved some good advice in that thread. I replaced the Coolant Temp Sensor and only had 2 hard starts since (but I had some weird wiring too). $12 and about 10 minutes to replace that sensor. Hopefully that's all it will take for yours too |
11-25-2017, 11:58 AM | #3 | |
1972 C10 Custom/Deluxe 613 Highlander 406/700R4 1999 White Tahoe LS 4x2 with Z56 Police Package 1992 K1500 GMC Suburban Members I have personally met: MusicMan70 - HeavyD - ChewyChevy67 - StingRay -71SWB4x4 - 67 Burb - DeadheadNM - too much stuff - bc65 - das601 " Circumsatances Do Not Change Responsibility " " The Sky is not the Limit, Your Mind is." Marilyn Monroe .. RIP Charlie Watts 1941 - 2021 |
11-26-2017, 07:34 PM | #4 |
This is not going to help but I noticed you location. I live in Alabama so temps in the 20's are not very common. My 93 Suburban always starts perfectly. Never failed to fire right up.
We drove to Michigan a couple of years ago to do a show. Parked it in parking garage of the condo we rented left it overnight. Next morning temps were in the low teens, I think around 12 degrees. It did the same exact thing you described. It turned over and over and never even sputtered. Scared me because it always fired right up. Second time it fired right off and ran perfect. No problems after that but it warmed up a lot after that and never had another problem. Makes me wonder if temp has something to do with it? |
11-26-2017, 08:27 PM | #5 | |
11-27-2017, 12:31 PM | #6 |
checking the actual fuel pressure might be a good idea? but i dont know if these older chevys have ports for the fuel pressure.
one thing i used to see on s10s and astrovans is the hose going up from the fuel pump to the pressure hose inside the tank will split. so you lose a lot of pressure while its trying to start but once it gets going and the pump is running full time the vehicle will drive fine. easy way is if you can get a fuel gauge on the pressure line, key it on and once the fuel pump stops if the pressure drops down to zero really quickly thats probably the problem. a good working fuel pump should hold pressure or go down realllllllllly slowly |
12-02-2017, 11:05 PM | #7 |
Does it have the original distributor? Mine went bad. It was a hard starting problem that acted like the starter was bad. Maybe you can swap out for a known good one to test.
'94 K2500 Silverado 7.4 auto 4x4 |
12-03-2017, 01:07 PM | #8 | |
03-10-2018, 11:10 PM | #9 |
I had the fuel pump replaced and it is still doing the same thing. i'll try coolant sensor next.
03-12-2018, 07:27 AM | #10 |
Don't Crush em Restore em
Check the fuel pressure regulator, on that model I believe it is near the driver side valve cover, near the power brake booster. I have the same problem with my '98 crew cab 454, but mine is back next to the distributor and a real pain to change.
TexasJeff 2009 Silver with Linen Interior Cadillac DTS 1990 Red with White Top and Interior Ford Mustang GT convertible 1998 Red with Gray Interior, C3500 Chevy Crew Cab Dually |
03-12-2018, 08:54 AM | #11 |
The OPs truck is TBI, not even similar to the port fuel system on your 98 454
03-12-2018, 09:06 AM | #12 |
Since it runs great, I dont think you have an ignition issue. There is a check valve in the fuel pump. I don't think its bad either, since changing the pump didn't help.
Thes TBI trucks have a fuel pump relay. If the relay fails, there is a redundant circuit that passes through the oil pressure sending unit. However, it wont supply powor to the fuel pump until it sees oil pressure. Turn the key to "on" without starting the engine. Do you hear the fuel pump prime for a few seconds? If you dont. you have a relay problem If you do hear it run, then your relay is fine, and the extended crank is caused by another issue. |
03-12-2018, 11:45 AM | #13 | |
04-28-2018, 05:00 PM | #14 | |
04-29-2018, 08:35 AM | #15 |
That's good news. Thanks for posting back and letting us know.
