Old 11-02-2010, 09:43 PM   #1
markeb01
Senior Enthusiast
markeb01's Avatar
Headlight Alignment
I don’t know that I’ve ever seen a thread on headlight alignment, so thought I’d share some excellent results I had today with a recently acquired Hopkins (Hoppy) B4A Headlight Aimer Set.
Back in the 50’s and 60’s just about every gas station/service station had equipment to aim headlights inexpensively, and promoted the alignment service similar to lube and oil jobs. This convenience pretty much went away in the 1970’s with the demise of service stations. I never wanted to spend a ton of money having a shop or dealership do the alignment so I’ve always done my own. I simply used a coffee can that fit the lugs on the lamp, a carpenter square, and a level with varying degrees of success.
With months of dark winter driving approaching again I really wanted to align the headlights as accurately as possible. Many months ago I did a study of the various commercial alignment tools available on eBay, made a decision on what I wanted then kept checking for a kit at an affordable price. Including shipping I paid less than $50 for the set shown below. I was a bit concerned about buying an obsolete “high tech” device like this, especially a used model since I knew nothing about them, and assumed the seller probably wouldn’t either. I also “assumed” there was some type of laser beam electronics that shot between the mirrors or something, but as it turns out there’s very little “tech” involved. I’m sure there was a lot of expensive engineering that went into designing the set, and the kit produces accurate results, but almost feels like a child’s toy. Everything is plastic, with a couple of hinged mirrors freely swinging on plastic flaps, and a few dials to adjust the aimers. There are no electronics in the aimers, everything is set optically, or to sound even less tech “visually”.
Using the device is a simple 4 step process, although step 2 took me a while to figure out.
1. Set all three dials to zero.
2. Calibrate the aimers to account for the slope of the floor.
3. Attach to aimers to the headlights and set the horizontal alignment by adjusting the headlight bulbs until a set of split mirror images in both tools line up.
4. Set the vertical alignment by use of a bubble level in each tool.
That’s it. Once the floor slope has been dialed in, all four headlights can be aligned in less than a minute each. Obviously the headlight rims need to come off to adjust the headlights, but I forgot to take pictures until after I finished, and didn’t feel like taking them back off for the photos. The following pictures tell most of the story:
This is the kit and packaging:
Here are the two aimers. The one on the right has the small headlight adapter installed. All the adapters snap in place and are detached easily. The calibration adapter is only used to set the tool to account for the slope of the floor.
Another shot showing the difference in adapters.
A better breakdown of the various components.
Aimer B suctioned onto passenger headlight. Aimer B always mounts on the passenger side. Once you get this far, it’s simply a matter of turning the headlight adjusting screws on the truck until the bubble is level and the picture in the window is aligned on the other aimer. (The bubble isn’t showing level because the truck has been moved since the lights were aligned).
Here we see both aimers mounted on the low beam bulbs. The same drill is performed on the high beams.
This was where I started getting frustrated. This is actually a shot through the alignment window. Earlier in the process every time I tried to calibrate the floor slope I kept coming up with a picture like this, which showed nothing of value and couldn’t be aligned. The instruction booklet isn’t very clear on what is desired. I finally figured out the correct image is of the yellow and black stripes on each aimer facing one another. The aligned image is upside down and backwards from each other. Once I figured this out, the rest was easy.
This is the area that is intended to align.
And here is another shot through the alignment window of what good alignment looks like. In real life the lines appear perfectly straight, but I couldn’t capture this with the camera. This sets the horizontal. The vertical aim is completed by leveling the bubble on top of the aimer.
For those of us that drive these vintage trucks all year, good headlight aim will certainly enhance night driving. What I originally thought was a delicate fragile electronic device, is actually rather primitive and mechanical, very simple to use achieving professional results, and would be a nice addition to the tool collection.
Old 11-02-2010, 10:22 PM   #2
62 Bowtie
62 Bowtie's Avatar
Re: Headlight Alignment
Damm... I just line em up on the garage door
62 Bowtie is offline   Reply With Quote
Old 11-04-2010, 01:01 PM   #3
JimQ
JimQ's Avatar
I picked up a set of aimers just like that a few year back. Great tool to have.
BTW - Nice shop! That's the way to do it! Looks great!
Q
'64 K20 327
JimQ is offline   Reply With Quote
Old 11-04-2010, 02:31 PM   #4
willyp
willyp's Avatar
As always, great attention to detail and write up. Sweet garage too!
The price of cool aint cheap.
willyp is offline   Reply With Quote
Old 11-04-2010, 03:06 PM   #5
blackmopar
precisely what I was thinking - but I do appreciate this detailed write up - nice one MarkeB!
blackmopar is offline   Reply With Quote
Old 01-04-2015, 06:31 PM   #6
1963chev
1963chev's Avatar
Thanks For The Great Write Up AnD Your Truck Looks Great. From Your Experience Is The Tool A Tremendous Improvement Over The Blank wall Approach Or Can I Get It Close With The Truck Level and Lining The Lamps Up From About 10 Foot away From A Blank Wall? Any Tips? Thanks
1963chev is offline   Reply With Quote
Old 01-04-2015, 09:14 PM   #7
jayoldschool
Moderator
Nice work. I have the same compressor as you...
jayoldschool is offline   Reply With Quote
Old 01-04-2015, 09:55 PM   #8
markeb01
Senior Enthusiast
markeb01's Avatar
The factory 1960 method in essence was the garage door visual setup from 25 feet with a bunch of markings for centerline and headlight height at the front of the vehicle.
The problem being with the old sealed beam bulbs, it's hard to determine "exactly" where the hot spot in the center of the beam is located. The tool eliminates that problem and allows precision adjustment with a much tighter tolerance than available by any other method.
However I’ve swapped over to the H4 style separate reflector/bulb on the low beam bulbs (post #853 on my build thread):
http://67-72chevytrucks.com/vboard/s...444502&page=35
The new headlights deliver such a razor sharp cut off image the tool really isn't needed for those bulbs. If I had it to do all over again I’d swap out all 4 bulbs to the new design and save the cost of the tool. But since I already have the tool, and rarely use my high beams, I’m saving the cost of the conversion and keeping the alignment tool for dealing with the old style high beam lamps.
My Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=444502
Old 01-05-2015, 07:23 AM   #9
Mjminino
Yeah I will be putting a set of HID's in mine, basically using the same housing that you used Mark, but with HID bulbs and ballasts.
HID Kit
And then housings like yours or these
7" Housing
Mjminino is offline   Reply With Quote
Old 01-05-2015, 12:59 PM   #10
63burban
Chevy addict
Aligning the lights with this set up is one of the best things I ever did you my old vehicles.
I have the same device and it truly is an improvement over the garage door trick. You would not believe the difference.
63burban is offline   Reply With Quote
Old 01-13-2019, 11:00 AM   #11
Andy4639
Old member
Andy4639's Avatar
Thumbs up Re: Headlight Alignment
I know this is a old thread but wanted to take a minute and say thanks. I just bought one of these kits for less than $70.00 and your right up will help a bunch on the use of it. Thanks mine came with the instructions but don't know how good they will be.
I do have a question though, do you know what the second picture is and what it does.
again thanks for the write up and any info.
Seeing the USA in a 71
Upstate SC GM Truck Club
http://upstategmtrucks.com/
