08-19-2017, 11:31 PM | #1 |
Pitting in block/combustion chamber
Pulled the head on my old 235 today due to a blown head gasket between #4 and #5. Was cleaning things up and noticed this pitting only on #5. What caused it and is it a issue?
08-20-2017, 06:35 AM | #2 |
Re: Pitting in block/combustion chamber
Cuased by a blown head gasket beeing run for a long time its time for the block to be re decked or replaced if the pits are too deep a new head gasket will never seal properly with the pitting tbere
08-20-2017, 08:45 AM | #3 |
it's been a long time but if i remember correctly the head gasket does not follow the cylinder - as in it's not a round opening. lay the gasket on the block and if it fits around that area you are good to go.
08-20-2017, 09:16 AM | #4 | |
08-20-2017, 09:43 AM | #5 |
Head gasket does not cover that area.....deck and align bore the block to see where you are...good luck.
08-20-2017, 10:04 AM | #6 |
you can see the same pattern on adjacent cylinders but I'd deck it for good measure but it may be ok as is....here's 235 head gasket..
08-20-2017, 10:32 AM | #7 |
08-20-2017, 10:37 AM | #8 |
Thanks for the input guys! The pitting is directly below where to combustion chamber in the head is, not on any head gasket sealing area.
Think im going to slap a new head gasket on it and see what it does. If it blows out the gasket again im only out a little labor and $25 in a gasket. Id prefer not to pull the motor at the moment. If it blows again then ill pull it and do the whole shootin match. Its in a old 1949 2 ton that im only going to put a couple hundred miles on a year. Like to not put alot of money into it. Another factor is that I believe that this motor was rebuilt not long before I purchased it. It has strong compression (155lbs) and I can still see crosshatching on cylinders. Last edited by amadioranch; 08-20-2017 at 03:56 PM. |
08-20-2017, 01:12 PM | #9 |
08-20-2017, 07:09 PM | #10 | |
bty i think you said "Head gasket does not cover that area.....deck and align bore the block to see where you are...good luck." did i miss something? |
08-20-2017, 09:10 PM | #11 |
Sorry was thinking about small block v8 if the gasket seals on a smooth part id let it ride
08-20-2017, 09:21 PM | #12 | |
I dont miss anything...you can.... |
08-21-2017, 07:59 AM | #13 | |
08-21-2017, 05:22 PM | #14 |
LOL!!!! OK...maybe I get a call from several machinist thanking me for the work....LOL!!!!!
08-21-2017, 07:39 PM | #15 |
Back on topic..... just saw 155 on the compression test. Is that in all cylinders? Might be worth throwing a head gasket at it. Then just keep an eye open for a cheap 235 to replace this one when/if the time comes and you can build it at your leisure.
08-22-2017, 10:29 AM | #16 |
Yep. Obvious blown head gasket. That pitting is actually caused by 'cavitation' from compressed coolant I would say.
Not to scare you. Be sure to check radius of head combustion chamber for cracks too. Probably more than half the 235 heads I magnafluxed had one there. If not to water yet they can be in future.
1969 c-10 Step Side Long Bed. I-6 250cid = = 1969 Pontiac GTO hard top. 400, 4-speed. |
09-03-2017, 12:55 AM | #17 |
So would it be a good practice to have the head checked before replacing the head gasket ? most likely the answer would be YES.....
