09-08-2017, 03:33 PM | #1 |
Retro-Fit Hyd Rollers
So since I have not seen much in the way of comparisons on these I would be seeking advice from seasoned engine builders.
Now that most cam manufactures are supplying us with the new tech on these I would be looking for insight if there would be any failures from specific manufactures or better inherent designs coming from one or the other. I would like to get more out of my next complete rebuild if I go this route. I know I can just get an update vortec block yet may be keeping the gen 1 and playing sneaky! |
09-08-2017, 04:07 PM | #2 |
Re: Retro-Fit Hyd Rollers
I'm an engines guy but have never fiddled with rollers. However, I have seen some nice dyno tests done by the guys at Hot Rod Magazine on their Engine Masters youtube show: Roller cams, head swaps, header tests and so on. Much of it on the classic small block.
(Very) Slow-Going Build Thread: Stock 1970 Short Step with Stock 1970 LT-1 http://67-72chevytrucks.com/vboard/s...d.php?t=567340 |
09-09-2017, 10:21 AM | #3 |
Registered Truck Offender
$ for $ your WAY better off stepping up to a 1986+ block with factory roller (unless your getting greedy and wanting 450-500HP. The cost to do a retro-fit hydraulic roller is topping $1200+ with cam, lifters, springs, retainers, pushrods and rockers. And I think we are going to see that continue to increase as the beloved old school SBC gives way to the LS of this mellimium.
VS around $400 re-cam a factory roller block with new GM lifters. Given the better oil seal of the 1-piece crank (and plenty of availability of those in the aftermarket now) the economical hydraulic roller package,, I have a hard time not going there for any street motor.
Still playin with trucks, even at my age! When you're dead, it's only a problem for the people around you, because you don't know you're dead. .....It's kinda the same when your STUPID. I just did my taxes and reviewed my SS statement. Thanks to the current administration it looks like I will only have to work till noon on the day of my funeral. |
09-09-2017, 12:24 PM | #4 | |
Vortec L31 is still Gen 1
James 1971 Blazer 350/SM465/NP205 1966 Chevelle 468/TH400 2009 Corvette Z06 built LS7 Last edited by 81turbota; 09-09-2017 at 12:45 PM. |
09-09-2017, 02:53 PM | #5 |
Bang for the buck, plus the adaptability to make it a FI later down the road is what gets me going on that L31 option.
You guys just summed up all the Youtube I did last night. Yeah they are going the way of the dodo bird, yet I will keep that old motor for a swap on special occasions. |
09-09-2017, 08:27 PM | #6 |
In all reality dollar for dollar when it comes to roller and fuel injection an LS swap is the cheapest option. You will make more power cheaper and have a much better fuel injection system. The spider injection on the vortec engines kinda sucked. Tuneability and making power weren't strong points by any stretch. Vortec heads are lift limited and even if they are machined to accommodate a bigger cam they still don't flow enough air to justify the money spent on machining.
Owner of North Point Car Care in Dundalk Md. We specialize in custom exhaust on both modern and classic vehicles. We are a full service auto shop from classics to modern vehicles. Feel free to contact me with questions. I will give a 10% discount to any board member. |
09-10-2017, 02:28 AM | #7 |
I looked pretty good at some threads on converting the LS to th 67-72 body style. Yeah its more power and reliability but the conversion kits and everything you have to change like the little stuff is a pita for me right now.
I like the idea of finding a good L31 core and spending some money good heads and proper cam to make a few ponies and have something reliable. Ok with the LS swap I love my boss's 05 with a 5.3 4l60E combo, but it fell on its face stock after 5 grand in a 3/4 ton. It was great for around town. |
09-10-2017, 10:13 AM | #8 |
There was a really nice cheap Vortec build-up in Car Craft a couple of years ago on refreshing a junkyard motor. Even at high mileage it showed little wear and they claimed it took $500 to rebuild it (in reality more like $1000 taking into account the parts they had already lying around).
EDIT: Here's the link to the Car Craft article: http://www.hotrod.com/articles/how-t...l-block-chevy/
(Very) Slow-Going Build Thread: Stock 1970 Short Step with Stock 1970 LT-1 http://67-72chevytrucks.com/vboard/s...d.php?t=567340 Last edited by mattfranklin; 09-10-2017 at 10:19 AM. |
09-10-2017, 11:33 AM | #9 |
dupe
James 1971 Blazer 350/SM465/NP205 1966 Chevelle 468/TH400 2009 Corvette Z06 built LS7 |
09-10-2017, 11:33 AM | #10 |
Forgot to mention - if you go the L31 route make sure your block has the fuel pump pushrod drilled and the cam you get has the eccentric. Some do some don't. Mine doesn't but I prefer electric pumps.
Cable guy, I agree the LS engine is superior. But I don't think it qualifies in the dollar for dollar comparison because so much more needs to be changed. The L31 spider injection is junk, I was suggesting to throw a carburetor on there. Besides a vortec specific intake manifold and a hardened distributor gear (which you can take off the vortec unit), all accessories, exhaust, flywheels, starters etc will swap over to the L31. If I was starting with an i6 or had a larger swap budget the LS is an excellent option.
09-10-2017, 06:05 PM | #11 | |
To do a LS swap for the same money I have to buy a used LS engine, much more work getting it installed and working right and what have I gained? While I would like an LS I would have to spend close to twice as much as to end up with a new engine and performance wise no appreciable gain. Nothing against the LS but the gains just don't justify another $1,500 to $2,000. |
09-10-2017, 11:19 PM | #12 | |
Chris '63 k15 long step Vortec 7.4 - L29 Blackbear tune, Five 0 Motorsports injectors, Chris Straub Cam, NV4500, divorced 205 52" front and 63" rear spring swap D44 / 14bff - disc axles Milemarker 9K and 10.5K hydraulic winches 63" & B52 Spring Install http://67-72chevytrucks.com/vboard/s...ng+swap+thread NV4500 Reverse Build Thread http://67-72chevytrucks.com/vboard/s...=reverse+build L29 - 7.4 Vortec Build http://67-72chevytrucks.com/vboard/s...&highlight=L29 |
09-11-2017, 05:02 PM | #13 | |
Now over-built, and durability with the most on pump gas is leading me into full bore engine thermodynamics, and design. Which could not be a bad thing cause I always over think things out. |
09-12-2017, 11:27 PM | #14 |
Just make sure you get good ones, I ended up getting Isky ones made by Johnson. I had Lunati ones (most likely Morels) sounded like a sewing machine in my engine.
09-12-2017, 11:45 PM | #15 |
Interesting. You're saying the Isky rollers are quieter?
09-13-2017, 07:37 AM | #16 |
I have the L31 in my 66 and it is not as cheap as you may think. If I had to do it over the LS swap would have been less money for a better motor. I bought the new L31 with tax it was $2200, the intake was $328, carb $420, distributor $330, flexplate $55, cam $280 then ad another couple of hundred for plugs wires coil ect and its now over $3800. Not to mention what I spent to have a 700R4 built. The 5.3 sitting on the floor for the 65 was a 31000 mile take out with the 4L60 for $1750 the mount kit was $70 and the wiring kit was $750 with the base tune in the computer. Thats about $2600 and includes the trans and it is EFI. The rest like headers and exhaust is a wash between the two so that for me is 2 grand less for engine and trans for the 65 verses the 66. I will be 60 on my next birthday and love my old school stuff but the gen1 stuff has for me past its time.
Jimmy
60 to 66 Chevy and GMC window decals http://67-72chevytrucks.com/vboard/s...d.php?t=661131 Good friends, good food and a hotrod what else do you need? 1966 BBW long fleet Daily driver 1965 BBW short fleet Sold and going to a good home 1965 Suburban 2003 3500 Duramax 2005 Ultra Classic |
09-13-2017, 01:45 PM | #17 | |
Are we talking rollers here from you guys? |
09-13-2017, 02:02 PM | #18 | |
I have thought about this and will be using a good amount of components from my current SB. The insight here is very point on and appreciated. Costs are what I am fighting with some performance/mileage gains. I know if I skimp on the wrong things I will come up a failure and that is not an option. |
09-13-2017, 03:39 PM | #19 | |
Sure there will be some extra money spent, there always is. But no where near $1,700 in my case. |
09-20-2017, 04:38 PM | #20 | |
Talk about luck! |
