Old 05-25-2018, 06:52 AM   #426
copper98
Re: What did you do yo your truck today??
Got it back with new ATK 315hp crate engine installed.
copper98 is offline   Reply With Quote
Old 06-16-2018, 09:40 PM   #427
Cruisin'
Cool Re: What did you do yo your truck today??
Had the stripes put on the hood!
Still one or two things yet to do.
#worktruck
Cruisin' is offline   Reply With Quote
Old 06-17-2018, 07:37 AM   #428
Looks good!
Old 06-17-2018, 08:17 AM   #429
DZL1
One day.....
DZL1's Avatar
#worktruck
Stripes look cool! Truck condition looks great. Any more pics?
DZL1.
Bertha build thread:
http://67-72chevytrucks.com/vboard/s...d.php?t=733306
'72 C10 short bed. Bessie (traded)
'93 C3500 CC Dually. Bertha (traded)
‘96 C1500 ECSB. Black Beauty
'89 C1500 RCSB LS swap. Black Bean
'06 Silverado CCSB Ghost (Wifes Truck)
'12 GMC Terrain V6. Titanium Bling (Wife’s Daily)
‘14 Chevrolet Cruze. Raspberry (Daughters Ride)
'99 Jeep Wrangler. Road Hog (Sons Ride)
DZL1 is offline   Reply With Quote
Old 06-23-2018, 12:32 AM   #430
Cruisin'
Thank you.
Here are a couple more...
Not a lot left to do to it now.... Heading towards 7000 miles since mid January....
Old 06-23-2018, 08:55 AM   #431
DZL1
One day.....
DZL1's Avatar
Looks like it just came out of factory!! Awesome job keeping it that way ����
DZL1.
Old 06-24-2018, 03:18 PM   #432
diveplane
Smile Re: What did you do yo your truck today??
belter of a truck well done keeping her mostly authentic
diveplane is offline   Reply With Quote
Old 07-16-2018, 10:02 AM   #433
MaritimeDragRacing
MaritimeDragRacing's Avatar
Can't believe the distributor cap died on my truck just sitting home in the driveway but thanks to Canadian Tire being open on Sunday and a drive there from a family member we were mobile again within an hour. After the swap to a new cap and rotor I tested the old cap and found ZERO continuity between the coil wire post and the button inside that sits on the rotor. Never saw anything like that before....
http://www.maritimedragracing.com
Atlantic Canada’s #1 source for Drag Racing News, Race Results, Schedules and Track Information.
MaritimeDragRacing is offline   Reply With Quote
Old 07-16-2018, 01:24 PM   #434
abig84
abig84's Avatar
Got to do the good old loose tilt column repair. Did it when I first got the truck 9 years ago. Doesn't look like I put lock tite on it last time
abig84 is offline   Reply With Quote
Old 08-24-2018, 01:34 AM   #435
AirAssault3187
I finally had time to get the thing running. Did a TBI to Carb swap. Been crazy busy so today was the day . Drove it around the block so I’m happy haha.
AirAssault3187 is offline   Reply With Quote
Old 08-24-2018, 05:51 AM   #436
Cruisin'
Thumbs up Re: What did you do yo your truck today??
Thank you. 😎🖒
Old 08-24-2018, 07:33 AM   #437
I painted the grille. Paint was fading off and needed freshening up. I got new lights and lenses since those were all dulled out and lights far from clear. I used the same charcoal color I put on the wheels. I wanted the grille to still look factory while matching the wheels. I was originally trying to match wheels to grille but came out darker. I like the grille a touch darker, kinda like the W/T grille but lighter. Last fall I put a new third brake light and tail lamps in to freshen up the rear.
Before. Can't tell how bad the paint is faded off, but dull and aged looking for sure:
Freshened up. A minor thing, but all lenses on truck now are clear and fresh:
Just keeping 'er alive with a touch of pride
Old 12-05-2018, 10:09 PM   #438
mikelom
Picked up a set of used firestone tires from my friend's garage and installed them on my truck. Got an alignment also.
mikelom is offline   Reply With Quote
Old 01-07-2019, 02:56 AM   #439
hb32
hb32's Avatar
Pre fitted the roll pan before paint.
Life is too short to drive a boring vehicle.
hb32 is offline   Reply With Quote
Old 01-15-2019, 02:20 PM   #440
hb32
hb32's Avatar
Roll pan installed and body moulding removed.
Old 04-15-2019, 09:05 AM   #441
shifty
Questionable
shifty's Avatar
Phase 1 of front-end work done this weekend. Grilled pulled apart, buffed/polished/waxed, lights replaced with 'Eagle Eye' OEM style replacements off Amazon. Might be able to see again while driving after dark now.
Picked up a brand front and rear bumper off Craigslist for $150 total last week also, looked up model numbers on Summit and Amazon - normally $750-$850 for same bumpers there.
Now waiting on replacement rub strip for front bumper and hoping to score a pre-painted green grille and filler piece that sits between grille and bumper before going there.
Some before/after action:
If I've got anything up for grabs, it'll be here: 7-hole gauge cluster for a 67-72 p/u FREE (link)
I can't check the forum daily. If I don't reply to you within 24 hours, drop me a PM! I'm (hopefully) still alive and will reply faster to a PM.
shifty is offline   Reply With Quote
Old 11-25-2019, 09:06 PM   #442
mikelom
Replaced the rear shocks and installed the Firestone Destination AT's that I got from 4wheelonline.
Old 11-30-2019, 10:18 PM   #443
j_ramirez11
j_ramirez11's Avatar
Installed new carpet.
j_ramirez11 is offline   Reply With Quote
Old 01-11-2021, 11:54 PM   #444
Just call me Sean
Just call me Sean's Avatar
Changed the brakes and one rotor the other day and noticed the upper control arm bushings are worn out on the drivers side. Then I noticed the control arm is also rusted by one bushing and needs to be replaced entirely. Then I noticed one of the bolts is missing the offset washer which is causing it to move around even more. Picked some up at the junkyard.
Originally Posted by Early Cuyler
Fights begin, fingerprints are took, days is lost, bail is made, court dates are ignored, cycle is repeated.
Just call me Sean is offline   Reply With Quote
Old 01-12-2021, 07:53 AM   #445
70GMCer
70GMCer's Avatar
upgraded my 97 Sierra to the nbs truck brake master cylinder. No more soft pedal going to the floor. Now I have a good brake pedal & shorter stops
1997 GMC Sierra Ext
1965 Mustang
70GMCer is offline   Reply With Quote
Old 01-13-2021, 02:20 AM   #446
1971 GMC SHORTY
1971 GMC SHORTY's Avatar
Put Rear Air Bags Air Compressor 5 Gallon Tank For Later Train Horns And Some Rear Ridge 20” Light bar
1966 GMC K25 V6 351E Original Utility Truck
2000 C3500 Hot Rod Utility Truck
2003 ROAD KING 100th 124ci 6 Speed
145CI M/P Pro Street FXR
2002 FXDP
2007 2500HD DURAMAX. DD
Studio Teamsters / Mechanic
Retired GM Master Tech 20 Years
Retired Ford Tech 15 Years
1971 GMC SHORTY is offline   Reply With Quote
Old 01-16-2021, 12:16 AM   #447
Just call me Sean
Re: What did you do to your truck today??
I picked up the new control arm to go with the bolts:
Old 01-17-2021, 12:03 AM   #448
1971 GMC SHORTY
Got air Bags Air Compressor and air Tank next up Train Horns mounted Everything Were Spare Went Fab all Brackets
2002 FXDP
Old 01-17-2021, 12:29 AM   #449
Just call me Sean
You replacing the springs with bags or doing helper bags?
Old 01-17-2021, 12:39 AM   #450
Just call me Sean
Changed the control arm. The bushings weren't even that bad. The movement from the missing washer distorted the control arm. As usual found another bad part while working on it. The pitman arm is loose on the shaft and the nut is all the way tight. I think it's the shaft not the arm.
