09-15-2018, 08:17 PM | #1 |
Gas tank options, and questions
So I have done whole lot of reading and searching, and I think I have decided on a Boyd's rear frame mount tank, but I'm a little confused in the in tank fuel pump options, ohm's, watts, size in general.. I also have seen a few pics of guys using the side marker light as a fill door, also the tail light, any insight on this? I am rebuilding a 68 swb fleetside with a 5.3 in it. Thanks
09-15-2018, 09:08 PM | #2 |
Post Whore
Re: Gas tank options, and questions
well...your in the wrong section... maybe a mod will move it for you...
but... the ohms of the sender must match your gauge as far as the pump goes as long as itll produce at least 58-60psi youll be good to go... the aeromotive 340 pump he sells is sufficient... I have no idea what watts has to do with it.. where you put your filler is up to your imagination...installing it in the marker or taillight hole will take a lot of fab work..
09-15-2018, 09:21 PM | #3 |
Ok thanks
