08-11-2019, 09:56 AM | #1 |
Inner cab coating hard to reach places ?
How should I go about coating inner parts that you can not get to, to do scale rust like the inner panels under the cowl in the vent areas ?
08-11-2019, 11:20 AM | #2 |
Re: Inner cab coating hard to reach places ?
Cavity wax may work...
08-11-2019, 01:12 PM | #3 |
I bought this I have not used it yet.
Here's a link below. Link: https://www.eastwood.com/eastwood-in...z-aerosol.html . .
08-11-2019, 01:13 PM | #4 |
Thanks, is this what would be used on the inside of doors as well ?
08-15-2019, 08:29 PM | #5 |
Personally....I got on the inside of the door area and scuffed, cleaned and used a little touch up gun with some epoxy and coated it as best I could.
08-15-2019, 10:38 PM | #6 | |
So I would suggest / Clean what you can with power tools or (careful ) sand blasting. then/ What you can not reach use a product that will preserve it for?? a extended amount of time. These parts are 50+ years old. So I try to stay with the original plan. I study the problems and make sure the drain hole are working. My Plan is always build it so No one says (what was they thinking) .
08-16-2019, 05:08 AM | #7 |
Thanks for the tip on the drain holes I probably would have missed that.
08-16-2019, 07:35 AM | #8 |
Not everybody realizes that the doors have a drain, my son-in-law came over and said that his door was full of water and could he borrow my drill so he could drill a hole in the bottom of the door and let the water out I laugh My azz off before clueing him
Hand made A/C vent manifolds for 64-66 trucks adapts any aftermarket A/C to OEM vent |
