02-07-2012, 01:00 PM | #1 |
NOS 69-70 Chevy truck grill COMPLETE
I have up for sale a NOS complete grill assembly(outer,inner,head bezels,etc) The only thing I added to it not NOS original are the correct style after market turn signal assemblies. It is NEW in GM box. It has been stored correctly so that the point is not all worn and damaged. $1650 SHIPPED obo
Will be shipped via fed x ground insured and signature required. |
02-07-2012, 01:09 PM | #2 |
Re: NOS 69-70 Chevy truck grill COMPLETE
That is PURDY!!!
'72 C to K20 "Cannibalizer" http://67-72chevytrucks.com/vboard/s...32#post8653432 '85 K30 "Big Nassy" '06 3500 Duramax ...tow truck '06 Silverado SS...DD '06 C1500 WT...DD '07 Classic C1500 WT...DD Built & sold cause can't keep 'em all: '72 Blazer "The Bucket" http://67-72chevytrucks.com/vboard/s...d.php?t=433190 '55 Chevy straight axle gasser https://www.trifive.com/forums/showthread.php?t=173938 '69 Pro Street Chevelle http://www.chevelles.com/forums/showthread.php?t=332541 '86 M1031 CUCV http://67-72chevytrucks.com/vboard/s...d.php?t=553619 |
02-07-2012, 01:36 PM | #3 |
VA72C10
I have a question......, the bezels...am I wrong or shouldn't they be black? Just don't want any issues when you sell this. Nice looking piece ready to put on....riveting those end pieces is a pain!
I edited about the grille...you can see the raised portions on it in the picture but according to others that could be NOS since gm started making them all look like 70's at some point just like the aftermarket does.....
Looking for a 67-72 swb or blazer project in or around VA. Last edited by VA72C10; 02-07-2012 at 09:13 PM. |
02-07-2012, 01:57 PM | #4 |
The center is flat egg crate no number on it. Bezels are just anodized aluminum no color.
02-07-2012, 02:35 PM | #5 |
Still Learning
Super nice!
02-07-2012, 02:43 PM | #6 |
Jonathan is correct, the head light bezels should be black! that is a nice grille!
02-07-2012, 03:34 PM | #7 |
Still Learning
I have a question too. Did you rivet this piece on or was installed when you bought it? I have a NOS grill too and it doesn't have this piece. Thanks and TTT for you.
02-07-2012, 03:39 PM | #8 |
Gorgeous!!! Boy, would I like one like that.
As stated above, original bezels are black. They are also steel, not aluminum. The bezels could, however, be NOS and what GM supplied originally with this unit if it was produced in 1971 or later since I doubt they kept making bezels from steel after the 71s came out with aluminum bezels. |
02-07-2012, 08:13 PM | #9 |
update the 2nd back brace on the drivers side that is the support for the honey comb is CRACKED on the back side. Once installed you will never see it but it is damaged. So with the news I have dropped price to 1350 obo. 2nd pic from bottom you can see the brace has a fine crack in it right ion the middle. It is such a fine break I looked at this many times and never noticed it!!
07-09-2012, 12:11 AM | #10 |
Just a Member
still available?
72 C-10 Cheyenne 350/350 ALL ORIGINAL 81,158 miles (1st) 69 7/8 ton(s & l) 66 327 short block rebuild.325 hp(2nd) 70 C-20 88 350 long block rebuild .040 bore. forged crank GM ZZ4 Hot Cam 1.5 roller rockers.375hp Aluminum TH400(3rd) 71 SWB frame off with 68 body. POSI PayPal: remimartin257@aol.com Business Inquires: 812 801 5111 "Help me, help you" that's my motto Members met... BuildinA68, jessewebb, daddymoo2, 70STOVEBOLT, irishfan77, feller, fine69, chevytruckguy70, jamie72, Nohatch, 2112, drtydog |
07-09-2012, 02:15 AM | #11 |
"Junkyard Dog"
Somebody buy this before I mortgage the house!! It would be perfect for my 69 car hauler resto.
72 C-10 Cheyenne Super LWB, Vortec 427,TH700, 3.73 posi, tach, tilt, AM-FM,Frame off in process. http://s289.photobucket.com/albums/l...t=7eae161e.pbw 88 Monte Carlo SS bought new only 10k miles. 73 Chevelle SS 454 had since high school. 74 Camaro Z28 350 AT numbers matching, Black on Black. 73 El Camino SS 350 4sp. 70 Chevelle SS 396 4sp, number matching with LS6 454 69 Chevy C30 Car Hauler 86 K20 383 4sp 4" lift frame off restoration. http://s289.photobucket.com/albums/l...t=1b1082d3.pbw |
07-09-2012, 01:24 PM | #12 |
I am curious abou this as well. I have an NOS outer and it does not have that piece, only 4 holes on each end.
70 C/10 SWB 402/TH400/3.73 "The Needy Beast" 200,000 Mile Club Disc Brake Club Owner installed options: Front Sway Bar Power Steering Power Brakes Cigar Lighter Courtesy Lights Deluxe Side Markers Wiper Delay Power windows Power Locks Coming soon: EFI 2015 Silverado 1500 LS 4.3/6L80/3.23 |
07-09-2012, 01:49 PM | #13 |
Moderator
The metal brackets do not come pre-installed. Just as the inner grill does not come pre-installed. They are all separate parts with different part numbers. I had to rivet the bracket on my NOS grille.
2018 Chevy Crew Cab 2006 Impala SS 1965 Plymouth Sport Fury 1970 Chevy Longhorn
70 Longhorn CST Build Adding an AM/FM Decal |
07-09-2012, 01:53 PM | #14 |
Ah, thank you for the clarification on the bracket. I have an NOS outer and an NOS inner now. Are the rivets for those end brackets anything special or just regular ole aluminum rivets?
07-09-2012, 02:27 PM | #15 |
Moderator
I used a combintation of aluminum rivets and stainless steel capped rivet bolts. I can't remember which ones went where. My grille is in storage. I'd have to check for you.
07-09-2012, 05:13 PM | #16 |
I used the rivet screws. In my opinion, they are the only way to go. I don't believe the originals were pop rivets. Here's an eBay link to them: http://www.ebay.com/itm/Chevy-grille...sories&vxp=mtr
07-09-2012, 05:36 PM | #17 | |
Moderator
07-09-2012, 05:39 PM | #18 | |
08-26-2012, 04:06 PM | #19 |
Is this grill still available? Interested, just bought a 71 and want the 70 front end.
Posted via Mobile Device |
08-26-2012, 04:59 PM | #20 |
Hey MikeCofield ....
Very nice and ttt for you
A husband can be right...or...A husband can be happy. 67-72 Chevy and GMC Trucks...The Classic Truck for the Classic Folk. 1970 CST Two tone green, 402BB, 400 Automatic, Tach, Buckets, AC, AM-FM, Tilt, GM CB, GM 8 Tract, LWB, etc JOHN 17:3...The better side of "LIFE" Remember: Everyday is a good day...Some are just gooder! |
08-26-2012, 09:02 PM | #21 |
sorry this one is already gone have one more may sell in the future ....70cst thanks for the bump
08-26-2012, 09:06 PM | #22 |
Beautiful to see.
- Jim - My Daily Driver is a 1969 Chevrolet Custom/20 Fleetside 350/TH400/Eaton H052 4.10 and its Project thread is here http://67-72chevytrucks.com/vboard/s...d.php?t=456911 |
