08-01-2018, 11:04 PM | #1 |
Oil bath air filters
Can someone tell me if oil bath air filters are any good? Are they effective and are they recommended? Thanks
08-02-2018, 01:25 AM | #2 |
Post Whore
Re: Oil bath air filters
even though they used them more many years its a old technology....paper is much improved over oil bath
08-02-2018, 09:05 AM | #3 |
That depends. In very dusty environments the oil bath filter will perform better. For most applications a paper filter is going to be a better choice.
I have sworn upon the altar of God, eternal hostility against every form of tyranny over the mind of man. - Thomas Jefferson |
08-02-2018, 12:55 PM | #4 |
I tried them years ago. Yeah, they let more air through with less restriction.
But.... It's too easy to a) let them go dry between cleaning/re-oiling and b) put way too much oil in them. Now you have an oil leak from your air filter housing and potentially a problem with surface coating oily residue on and inside of anything between your air filter and your throttle body/carb ( Think MAF, IAT, MAP and other expensive parts that monitor air flow, volume, temperature, pressure, etc. ). It's also kind of a pain to have to remove, clean, dry and re-oil the darn things. So, I use paper these days! -klb
67 C10 fleet fuel injected '70 402, 700r4, 3.73 posi 07 335 sport turbo 6sp 94 Trans Am GT LT1 6sp posi -- sold after 22yrs 99 540 sport V8 6sp -- sold 73 240z L24 4sp -- given to friend 68 C10 step 350/350 3.73 open -- sold |
08-02-2018, 05:50 PM | #5 |
I'm not sure if they make a air filter for my 68 w/o it being oil bath. I think there's an offset on it.
08-02-2018, 09:39 PM | #6 |
Active Member
If you want to keep the stock look and haven't done any mods then hang on to it even if you do change to paper filter as mentioned above. The paper filters are just more convenient to use even if you have to buy a housing for it.
My 68 GMC has a 250 six and it had an oil bath filter. I removed it and replaced it with a paper filter but didn't hang on to the old oil one. Wish I had just for nostalgia. Also, the housings for the single throat carb looks anemic.
68 GMC 250/3 speed Saginaw p/b p/s 69 Chevy 350/350 currently in pieces still lookin for a cab 06 Trailblazer I just want a vehicle that I can work on, that won't talk to me, leave error msgs or keep track of how I drive... |
08-03-2018, 12:57 PM | #7 | |
Sorry. Sometimes, I just need to remember exactly where I am.
-klb Quote:
08-04-2018, 07:03 PM | #8 |
I can get one for $40. Is it worth it? Can I put a paper filter in it instead of oil?
08-04-2018, 08:27 PM | #9 |
Post Whore
Recently I've looked at quite a few oil bath filters...mostly for v8s....i dont think there is a paper filter that will "fit" a oil bath breather without some modifications...and oil bath filters tend to be on the small side diameter wise....ive seen a few larger ones in my searching....im still contemplating getting one and "making" it work....
08-05-2018, 06:02 PM | #10 |
Ok, thanks. I'll probably should get this one then.
08-12-2018, 04:08 AM | #11 |
And what about the good old K&N technology, is it a thing of the past?
