Old 06-16-2018, 06:59 PM   #1
Red66C10
Front Spindle Question (66 C10)
I have a set of 82-92 Camaro Wilwood aluminum hubs, 12" rotors and Wilwood calipers that I purchased for $1k new. I sold my camaro and want to know if they will fit my 1966 C10 if I swap spindles to the camaro spindles and use these brakes?
Any info is appreciated.
Red66C10 is offline   Reply With Quote
Old 06-16-2018, 11:04 PM   #2
Bentbolt
Re: Front Spindle Question (66 C10)
I think the Camaro (trailer park special) model has a strut on top and control arm on bottom. So I don't think the spindle swap would be just a bolt together.
Bentbolt is offline   Reply With Quote
Old 06-17-2018, 03:26 PM   #3
Red66C10
I can fab it to work if it is doable. I just hate to sell these and buy new again
Old 06-19-2018, 05:44 PM   #4
68Stepbed
68Stepbed's Avatar
It may be "doable", but there's no advantage. Everything on the Camaro platform is designed for the weight and chassis dynamics of that particular car. The truck stuff is heavy duty for a reason. C10 trucks utilize narrower frame rails with longer control arms, so the ball joints and spindles actually take alot more load than "car" spindles. Therefore, the spindle/hub assembly won't handle the stress the truck chassis will put on it, which means you'll be spending more money down the road constantly replacing spindles and hubs and possibly fixing sheetmetal that the loose wheel tore up.
Matt
68 C10 stepside, LS1/700R4, TCI Engineering suspension system
68Stepbed is offline   Reply With Quote
