Old 01-20-2015, 09:22 PM   #1
Dale99
SP heat shield for vette ram horns?
I have put the corvette ramhorn manifolds on my jimmy. Im having problems with misfires down at the sp, and its melting my wires. So I would like to get some heat shields. I see these are for 62-65, but I cant seem to find shields for that early of year. Will ones from say 67-70 work with zero or little modifications?
2008 Sierra k3500 LMM
1994 s10 blazer 4x4
1991 Camaro Vert Rusted in Half RIP
1972 Jimmy 4x4 L05,4L60E,np205http://67-72chevytrucks.com/vboard/s...d.php?t=546364
1967 C10 L6/3tree(dads truck)
Dale99 is offline   Reply With Quote
Old 01-20-2015, 10:13 PM   #2
geezer#99
geezer#99's Avatar
Re: SP heat shield for vette ram horns?
Instead of heat shields, run your plug wires up from below like corvettes did with ram's.
Old 01-21-2015, 08:09 AM   #3
Dale99
They are melting where they connect to the plug, not mid wire from laying on the manifold.
Old 01-21-2015, 10:33 AM   #4
geezer#99
geezer#99's Avatar
Then you need better boots to handle the heat or cut back the heat produced by the manifolds.
If you're jetted a bit lean and your timing is retarded you'll have excessive heat in your exhaust.
Old 01-21-2015, 11:18 AM   #5
Lee H
Lee H's Avatar
I think your looking for the stock style shields, small zinc plated tin shields that bolt to the block. GM used them on most cars and trucks of the era. They are a must to "help" protect the boots fron the heat of the cast manifolds. I know GMCPauls, Classic Heartbeat, Classic Industeries, ZIP Corvette, Paragon, etal carry them. If you have trouble finding them I'll look up and post the correct ones later today.
1972 C10 SWB, Air, PS, PB, 350/350THM. Second owner.
1965 Corvette roadster, 44K miles, 327/365 SHP, 4 speed, side exhaust, knockoffs, teak, second owner (bought in 1970), Have ALL numbers matching components.
My frame off restoration thread: http://67-72chevytrucks.com/vboard/s...d.php?t=556703
Lee H is offline   Reply With Quote
Old 01-21-2015, 11:32 AM   #6
Lee H
Lee H's Avatar
Found an old picture.
Old 01-21-2015, 12:02 PM   #7
octanejunkie
octanejunkie's Avatar
A properly routed set of wires with silicone boots won't melt unless you are putting off a ton of heat. The shields can be more trouble than they're worth.
Déjà vu. It's that feeling you get when you hit your thumb with the hammer a second time
'59 Chevy 3100 Stepside
octanejunkie is offline   Reply With Quote
Old 01-21-2015, 12:34 PM   #8
jimbosprint
jimbosprint's Avatar
I have a brand new set of shields like that I can send you if cover the shipping cost.
jimbosprint is offline   Reply With Quote
Old 01-21-2015, 02:01 PM   #9
Dale99
geezer, I'm Fuel injected.
Lee, that sounds like what I had found for "newer" models. But didnt list it for 62-65 vettes. If they are all kinda universal or can be easly modded to work, then I will get some.
Octane, I agree. Thats why I didnt put them on at first.
Jimbo, will send pm.
Old 01-21-2015, 04:59 PM   #10
truckster
truckster's Avatar
There's nothing too special about them. They're designed to fit any SBC under the manifold, so pretty much any set should work.
truckster is offline   Reply With Quote
Old 01-21-2015, 05:00 PM   #11
storm9c1
*** That's interesting ***
storm9c1's Avatar
Lots of options on eBay. Good quality sleeves work pretty well.
http://www.ebay.com/sch/items/?_nkw=spark+plug+shield
Since I am a LT1 guy, I use the LT1 style heat shields on all SBC engines, LT1 or not.
http://www.ebay.com/itm/370423800370
I run ramhorns on a 383 -- towing heavy loads. Using a good set of MSD wires routed under the manifold (stock style), the boots haven't melted yet. The LT1 heat shields won't fit the MSD wires due to how huge the boot is.
As mentioned, be sure to check your timing -- if retarded, will produce excessive heat. Same goes with running lean, I've have to upgrade jets on Holley carbs and metering rods on Eddy carbs to properly solve these types of problems in the past.
Tom
Chevy by day...
1969 Chevy C30 Rollback Tow Truck -- 383 stroker, 4L80E
2011 Chevy Caprice PPV 9C3 6.0L
1995 Chevy Caprice 9C1
1994 Chevy Caprice 9C1 #3
1995 Chevy Caprice Wagon #2
1995 Chevy Impala SS
Mopar by night...
1969 Dodge Charger
1972 Chrysler Newport 2dr Hardtop (27K miles)
Plus others...
storm9c1 is offline   Reply With Quote
Old 01-21-2015, 05:49 PM   #12
Domer
Domer's Avatar
Try the Accel Ceramic wire boots. I run them on my Vortec 454. They are awesome.
http://www.summitracing.com/parts/ac...rview/make/gmc
Domer is offline   Reply With Quote
Old 01-21-2015, 06:39 PM   #13
Dale99
truckster, thanks I was hoping to hear they were quite universal
storm, I was debating on the fabric covers, Ive actually used 2 of them to protect my starter wire on my Camaro. The LT1 covers wont work since I am running strait boot, but I had never seen them before. Interesting.
Domer, I refuse to use anything with the word accel on it, to many bad experiences before.
Old 01-21-2015, 07:03 PM   #14
storm9c1
storm9c1's Avatar
Oh OK. Straight boots might be part of your problem. I recommend angle boots with ramhorns. There are lots of wire kits that come with high-temp silicone angle boots. A high quality Corvette set for under-manifold routing should have silicone angle boots and seems to be the way to go. Something to consider if you keep having problems.
Tom
Chevy by day...
Mopar by night...
1969 Dodge Charger
Plus others...
