09-17-2015, 12:46 PM | #1 |
66 C20 327, green original engine paint
09-17-2015, 03:02 PM | #2 |
Re: 66 C20 327, green original engine paint
The 292's were painted green as well. Thanks for sharing!
1966 Chevy C10 "Project Two Tone" http://67-72chevytrucks.com/vboard/s...d.php?t=596643 1964 GMC "Crustine" semi-build:http://67-72chevytrucks.com/vboard/s...d.php?t=665056 My youtube channel. Username "Military Chevy": https://www.youtube.com/channel/UC_h...fzpcUXyK_5-uiw |
09-17-2015, 08:14 PM | #3 |
Using the sample paint on the flywheel is your most accurate match to '66 327 green, other parts of the engine has been exposed to high heat, weathering and bleaching out( due to engine degreasers etc). IMO, Ford green is the closest match for the 292 and 327 in a ready to use rattle can. But if found someone who can match color with high temp paint,great, go for it. Member Sodly has a super low mileage 327, which appears to be closer to Ford Green than the lighter Alpine Green ( aka Detroit Diesel Green). http://www.ebay.com/itm/VHT-Paint-Hi...693832&vxp=mtr
09-17-2015, 08:36 PM | #4 |
The flywheel is the part I left with them to match. They are going to put the enamel in some spray cans. I've heard the ford green is the closest but I figured since I have the parts I might as well get EXACT matched up
09-17-2015, 08:50 PM | #5 |
Careful....Ford green takes away horse power.
09-17-2015, 08:53 PM | #6 |
09-17-2015, 10:07 PM | #7 |
Could you post a picture of the front end of each head after they are grease removed? I think I can just see it's there but the drivers side head could have like a "YH" in yellow grease pencil on the front of it indicating 327 turbo 400. Interestingly it may have something as Y_ as it also has the A.I.R. calif emission but no code appears to have ever been assigned in the GM books for that one. Cool to put that back on there when you have it all painted up again! Also were you able to see the codes on the firewall with assembly line grease pencil for the options like the turbo 400 tranny? My 327 turbo 400 donor parts truck had M49AG written just to the right of center upper firewall and before the drivers side washer hose cowl hole. Sometimes those marking are very faint but still readable in the right light.
'66 CST BBW swb fleet 327 fac ac '67 CST 4x4 swb 327 stepside project '72 Cheyenne K20 50k original '72 Cheyenne Super K20 project '73 Sierra swb 4x4 frame off in paint stage '74 Cheyenne Super swb w/16k actual '71 & 72 Cheyenne K10 4x4 swb's '70 426 HEMICUDA conv SHAKER 4 sp Dana 60 '60 Impala conv 327 PG fac ac loaded 3rd owner '72 GMC K2500 4x4 '59 Apache CST BBW fleetside swb 283 '73 ElCamino SS LS1 T56 true SS bucket tach '76 ElCamino SS 52k survivor '87 Grand National 41k True 2nd to last built in 1987. '86 K30 454 SRW fleetside CA since new '88 Trans Am GTA 39k bought new 2018 DEMON plum crazy @ 840HP! "Need for speed" |
09-17-2015, 10:32 PM | #8 |
Looks about right to me.
WANTED: * 60-66 Chevy and GMC FACTORY PHOTOGRAPHY (scans) of pickups and carryalls. Custom Camper Club-- Own a 65-66 Custom Camper? Join us at: http://67-72chevytrucks.com/vboard/g...hp?groupid=117 |
09-17-2015, 11:00 PM | #9 |
09-17-2015, 11:12 PM | #10 |
09-17-2015, 11:17 PM | #11 |
Nice. Appears one of the line guys added his own version of YEAH too to the lower sides of the block.
This was my St. Louis built truck with 327 engine and PG markings as were on the heads. My 327 TH block was junk when I tore it down to rebuild.
09-18-2015, 11:08 AM | #12 |
I was wondering what those letters between the YH were for haha. Sorry to hear the block wasn't any good.
05-07-2017, 01:45 PM | #13 |
Rollin' Old Skool
Digging this back up, but I'm not optimistic considering the thread never got updated. Was curious what paint color/match ended up being used?
_____________________________________________ Phillip My Build threads: 1966 Chevy C-10 "Black Betty" shortbed, fleetside, BBW, 327 V8/ Powerglide (under construction) http://67-72chevytrucks.com/vboard/s...ighlight=betty 1997 Chevy Tahoe, 2dr/2wd, mild custom (Daily driver) http://67-72chevytrucks.com/vboard/s...d.php?t=601142 Pics: '66 C-10 https://flic.kr/s/aHsjHWD4h9 '97 Tahoe https://flic.kr/s/aHsjGZ7wKP '93 C-1500 https://flic.kr/s/aHskxdpdnQ '88 S-10 Blazer https://flic.kr/s/aHsjYGx4Md Previous Rides: 1993 Chevy S-10 ext. cab, 4.3L, 4/5 drop (Sold) 1993 Chevy C-1500 short/step Retro-Rod (Sold) 1988 S-10 Blazer 2dr/2wd mild custom (Sold) |
05-09-2017, 11:08 AM | #14 |
05-09-2017, 11:23 AM | #15 |
That's awesome! I went with Duplicolor alpine green for one of my builds. Mine seems just a tad lighter.
05-09-2017, 11:42 AM | #16 |
05-09-2017, 11:47 AM | #17 |
That looks so good! I love seeing these small blocks in the factory colors other than the most popular engine orange.
Builds: Green Gus the 68 C10 ; Sullii the 72 1500 - Instagram: @dr.hewitt - C10 Concept/Development Photos: Master Thread |
05-09-2017, 04:11 PM | #18 |
Rollin' Old Skool
Thanks for the reply! It looks great. Do you have a paint code or anything showing what was used to achieve that color?
05-09-2017, 04:47 PM | #19 |
05-09-2017, 05:18 PM | #20 |
Should be a runner, I spy a retrofit roller lifter peekin' out!
Posted via Mobile Device |
05-09-2017, 06:15 PM | #21 |
WOW I guess all that oil preserved that green...looks really good...
1964 BBC 402 4x4 |
05-11-2017, 09:17 AM | #22 |
Thanks guys! Yeah wasn't quite happy with the numbers when I put all the stock parts together so ended up going double hump heads, corvette intake manifold, roller rockers and roller lifters
Since it was a custom paint mix I think it's just the company's codes on it, not a general code that would work anywhere. |
05-11-2017, 10:02 AM | #23 |
...just another truck junkie..
I was going to paint my 292 Alpine Green but after seeing this I am going to have to do some playing with Ford Green to compare.
Mike "Bear" Shea |
05-11-2017, 10:04 AM | #24 |
Rollin' Old Skool
Dang it! Getting ready to paint mine soon & have been researching for the correct shade of green. I was about to just pull the trigger on late 60's Buick green, until I saw this thread about yours. Would love to duplicate what you have color-wise. There's another thread on factory correct restorations where the 327 engine color has been discussed, & I'm sure many folks that want originality could benefit greatly from your engine color.
05-12-2017, 08:13 AM | #25 |
Rollin' Old Skool
Do you have, or can you get a pic of the paint can showing any codes/info?
