Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Electrical
Old 01-29-2008, 07:37 AM   #26
magsnubby
magsnubby's Avatar
Re: 'cigar lighter' kill switch?
Originally Posted by ETsC10 View Post
...a kill switch made that looks like a cigar lighter and mounts in the dash.
Not a good idea. To obvious. Something along these lines would be much better...
http://autospeed.com.au/A_107975/cms/article.html
...or this one...
http://www.northridge4x4.com/proddet...rod=ORO-ADE-II
magsnubby is offline   Reply With Quote
Old 01-29-2008, 08:18 AM   #27
WorkinLonghorn
WorkinLonghorn's Avatar
I just read this thread,with references to google searches etc. and couldn't help imagining every crook in the country going " OK,remember to check the lighter if it doesn't start".
'69 GMC C2500 Custom Camper, 8 1/2' bed, New GM 350, NP 435 Close Ratio 4spd. Trans., 3.73 Dana-60 open.Camper and Trailer wiring, PS, PB, AC, tach , three gas tanks, 2nd owner, Work-Truck supreme. Best $300 I ever spent.
WorkinLonghorn is offline   Reply With Quote
Old 01-29-2008, 08:47 AM   #28
LUV2XCLR8
The LuvShack Garage
LUV2XCLR8's Avatar
I have an idea for mine, but alas I'm not going to list it here
Owner/Op: "TN Classic Transport Carriers"
The Toy: "Square Vette" 72 Hybrid Blazer
Toy Barn: "LuvShack" 40 x 60 x 20 Shop
Big Piggy: "Goliath" 07 Kodiak C4500
Lil Piggy:"Maddy" 88 Silverado 3500
Hauler: "Feathers" 14 Aluma 8218T
LUV2XCLR8 is offline   Reply With Quote
Old 01-29-2008, 08:57 AM   #29
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
I've seen an 80's toyota, that if you left the rear window defroster turned on, the engine wouldn't start. Not sure if it was stock... or even ententional... but it threw my buddy for quite a loop... for 2 days! It would crank, but no fire.
Also, in some of the new freight liners, there's a toggle switch with a label that says back up alarm... if you don't hit that momentarily on switch, the engine won't crank.
A couple interesting things there kinda on topic.
Old 01-29-2008, 10:29 AM   #30
myraley
myraley's Avatar
I thought the cigar lighter worked by completing the circuit in its normal position so the electricity just passed through to the ground and then breaking it (so there was no ground) when pushed in. And that was why it heated up. Am I wrong? How does a cigar lighter work?
myraley is offline   Reply With Quote
Old 01-29-2008, 11:13 AM   #31
Longhorn Man
if the power passed right through it to the ground, then it would be a dead short to ground, and either pop a fuse, or burn a wire. When a lighter is in it's normal 'rest' position, there is nothing going on electricly. When you press the button, you are heating the element with a controlled short to ground.
Take a AA battery, and tun a wire from the positice to the negative. The wire will get very hot very quick. This is hoe the cigar lighter works.
Old 01-29-2008, 12:09 PM   #32
myraley
myraley's Avatar
Ahh, I was completly wrong then. What I wanted to do was make it so the Neutral safety switch would work if the lighter was in the socket, but not if it was removed. I didnt want the lighter to have to be pressed in, though. Is there a way to make that work? Cause it would be like removing a fuse, only easier and more cool...
Old 01-30-2008, 05:42 AM   #33
sneakysnake
It's a catastrophic success.
sneakysnake's Avatar
The easiest way to use a lighter is to run a wire from the - side of the coil or points side to the center lug of your lighter, If the lighter is pushed id in it grounds the coil.
Now if you want to interupt power to an HEI or a safety switch use a relay, you may have to modify the lighters coil if the resistance is to great by soldering it.here is a simple diagram
sneakysnake is offline   Reply With Quote
Old 01-30-2008, 08:39 PM   #34
68C15
blood type; Retumbo
68C15's Avatar
I tried this last night and burned my fingers. now I can't do my job. it's all your fault Andy!!!!!! LOL
68C15 is offline   Reply With Quote
Old 01-31-2008, 06:47 AM   #35
Longhorn Man
LOL!!!!
Old 01-31-2008, 07:51 AM   #36
nyncompute
nyncompute's Avatar
I saw a post from another forum where the fella modified the lighter socket to hold a pushbutton on/off switch. Push in the lighter..on!, push it again..well you get the picture.
1972 K-10 SWB Cheyenne
nyncompute is offline   Reply With Quote
Old 02-05-2008, 07:55 AM   #37
ETsC10
Hand Crafted C-10
ETsC10's Avatar
Well, my talented friend Joe has taken on the challenge! He's currently designing one for an early 70's Cutlass and we're taking tons of pics along the way. I'll post a separate thread when it's done.
Well, didn't do a separate post but here ya go...worked right well IMHO
ETsC10 is offline   Reply With Quote
Old 02-05-2008, 08:00 AM   #38
ETsC10
Hand Crafted C-10
ETsC10's Avatar
Oh, and BTW...the car was basically in for a complete wiring clean up. The Kill Switch was an afterthought.
Amazing what some patience can accomplish!
Old 02-05-2008, 08:50 AM   #39
Mtrhd329
you can wire up your cigarette lighter so that it remains functional and the vehicle still will not start unless you push it in. And if you are really anal about the security of you vehicle you can wire one side of the relay coil to a 12V switched source like say the headlights or the brake lights so you have to engage those for the cigarette lighter let the truck start.
You need two relays and wire as follows
Relay 1:
85- to relay 2 post 87
86- to 12V switched Accessory (headlights, taillights)
87- to key side of starter wire
87a- not used
30- to starter side of starter wire
Relay 2:
85- to key side of starter
86- Ground
87-to relay 1 post 85
**NOTE*** you have to cut the 12V wire to the cigarette lighter and run those two connections to the next two posts.
87a- to truck side of 12V cig wire
30- to cig lighter side of 12V wire.
This has been used many times in some installs I have done for people and worked fine. If you guys have any questions or need me to clarify lemme know.
Mtrhd329
Mtrhd329 is offline   Reply With Quote
Old 12-27-2011, 08:02 PM   #40
Pac06
This sounds like an interesting idea, but I have a question. What do you do with #86 terminal on relay #1 if your not going to use another switching source (headlights or brake lights)? Where does that #86 terminal hook up if you just want to use the cigarette lighter?
Pac06 is offline   Reply With Quote
Old 12-27-2011, 09:23 PM   #41
fixit-p
fixit-p's Avatar
Any switched ignition source would work.
1965 GMC shortwide big window
1969 Chevy C20 long (for now)
2005 Silverado 2500HD Crew Cab
Originally posted by:Abraham Lincoln "The trouble with quotes on the Internet is that it is nearly impossible to discern if they are genuine."
fixit-p is offline   Reply With Quote
Old 12-27-2011, 11:22 PM   #42
sapper4
Try this link: http://www.dlcparts.com/images/BoschGuide.pdf
On page 15 or 16 gives good examples of how to use a cigarette lighter, but has a lot more ideas as well. They all use relays, which is the best way by far.
sapper4 is offline   Reply With Quote
Old 12-28-2011, 12:19 AM   #43
Pac06
I followed exactly the "STARTER DISABLE/CIGARETTE LIGHTER OPERATIVE" schematic on page #16. Can't get it to work, not able to energize the relays. Need to get an explanation of what exactly is going on when lighter is pushed in.
Old 12-28-2011, 12:42 AM   #44
sapper4
The cigarette lighter essentially grounds a hot wire. It has a hot wire and a ground. When you push the lighter in, it grounds the hot wire and the power burns the coil in the lighter. The lighter acts like a circuit breaker and pops out before it burns your harness up.
The illustration on page 16 shows the use of two relays and putting a relay between your starter wire.
Old 12-28-2011, 12:54 AM   #45
fixit-p
fixit-p's Avatar
If you followed the top diagram it wont work because the diagram itself is flawed.
Relay #2 either (depending on its state) supplies power to the cig lighter or ground to the #1 relay.
The 85 and 86 terminals are the coil terminals (control side of relay) for the relay to change state you need power to terminal 86 and 85 needs to be grounded.
But if you look at the diagram, terminal 86 on relay #1 jumps directly to terminal 86 of relay #2, terminal 85 on relay #2 goes to ground and terminal 85 on relay #1 goes to terminal 87 on relay #2. In this configuration neither relay has power at anytime to the control circuit.
The fix is to connect the jumper that goes from relay #1 to relay #2 (86 terminals) to terminal 30 on relay #1 that way when you turn the key to start, both relay control circuits get power, relay #2 is already grounded so it switches from supplying power to the cig lighter to providing ground to relay #1 (as long as cig circuit is complete (lighter pushed in)).
Once relay #1 gets its ground and power at the same time, terminals 30 and 87 close and starter engages.
Old 12-28-2011, 02:20 AM   #46
fixit-p
fixit-p's Avatar
This diagram shows the flaw (arrow)
This one shows the correction.
Old 12-28-2011, 02:28 AM   #47
sapper4
great explanation. Thanks for the clarity!
Old 12-28-2011, 06:48 PM   #48
Pac06
Thank you fix-it!!! Worked perfectly after correcting the flaw. I'm over in the east bay what part of the bay are you from? Thanks again!!
Old 12-29-2011, 12:27 PM   #49
motornut
78K & 79C Jimmys
motornut's Avatar
Originally Posted by old Rusty C10 View Post
all ya gotta do is to tap into the hot side of the coil and run it to a hidden toggle switch when someone tries to start it no spark
done this before,not hard and it will flood before they figure it out
John
1978 GMCJimmy4X4-350/203
1979 GMCJimmy4X2-305/350
motornut is offline   Reply With Quote
Old 12-29-2011, 12:57 PM   #50
fixit-p
fixit-p's Avatar
Cool glad it worked for you Pac, I'm practically right next door to you in the Hayward/Castro Valley area.
