05-16-2017, 10:19 PM | #1 |
God forsaken dash pad grommets
Hi I'm installing a new dash pad and having a hell of a time installing the pictured grommets/fasteners. Any tips or help would be appreciated
05-16-2017, 10:41 PM | #2 |
Re: God forsaken dash pad grommets
I'm not sure who makes them but I have seen rubber grommets. They are easier to install than the plastic ones.
Current projects: 1966 Chevy Custom PS PB A/C BBW 283 v8 3 speed OD 1966 GMC Long Step 1966 GMC 3/4 ton Custom PS PB Sport trim 351 v6 1966 GMC 3/4 ton 4x4 Custom PB 305 v6 np435 1960 GMC Custom 1968 GMC 3/4 ton 4x4 Short Bed 1962 K20 Tow truck 1961 GMC Extended Suburban Panel and a few more |
05-16-2017, 10:48 PM | #3 |
Dash Pad ??? What year are you working on?
1955 GMC 250 8 Flatbed 1971 C30 157" 350 4spd 10' Flatbed 81 GMC K30 CnC 9' Flatbed 454 T400 89 GMC Jimmy Stock https://67-72chevytrucks.com/vboard/...d.php?t=810958 71 LT1 Convertible, 72 Coupe 69 CJ5, 75 CJ6, 67 M715, 72 M35A2 Bobbed, 95 XLC2 |
05-16-2017, 11:34 PM | #4 |
58
05-17-2017, 07:12 AM | #5 |
05-17-2017, 08:50 AM | #6 |
Yes firewall pad thanks!
05-17-2017, 09:48 AM | #7 |
http://67-72chevytrucks.com/vboard/s...d.php?t=436442 |
05-17-2017, 01:51 PM | #8 |
i have seen 2 different versions of this --- one is very soft and the other is a better version which is a hard plastic --- the hard plastic holds up much better - before you put the pad in -- mock it up with the fastners in place so you know right where they go -
line it all up and give the fastners a shot of wd-40 then push hard -- it should go in a bit easier , make sure all line up with the holes and dont forget any -- pulling it bk out may not be much fun.... good luck sir --let us know how it comes out . did it to my 57. |
05-17-2017, 06:06 PM | #9 |
I always use and awl, ice pick or tapered pin pinch to do alignments on everything requiring holes to be aligned. Was taught by an really old time machinist/engineer to do this everytime even when holes look good. It ensures hole are clear, smooths edges and assures correct alignment for the holes. Its funny now i'm the old time machinist/engineer.
05-17-2017, 09:44 PM | #10 |
Take an old screw driver. cut the end off so it is flat. Stick the driver in the end of the pad pin. Mark the depth then tack weld a washer just short of that depth so when you push the pad pin in it will not contact the tip of the pad pen. Worked perfect for me.
