Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Paint & Bodywork
Old 03-05-2011, 08:15 AM   #1
chrismoore701
chrismoore701's Avatar
stripping paint
Hey I just wanted to check my method of stripping. I am stripping my tailgate and decided to use my angle grinder with one of those cup wire wheels. It is doing a great job, not even scratching the steel. I plan to go over it again with a DA to rough it up before paint. This works so good that I am nervous I am doing something wrong. I have attached some links of what I am using. I need some opinions
http://cgi.ebay.com/SEARS-CRAFTSMAN-...item415749dc95
http://cgi.ebay.com/NEW-CRAFTSMAN-WI...item1c199e1e5d
Chris
_______________________________
1979 Chevy Stepside SPORT
2018 Chevy Silverado, 39 years apart
My build 2008-2016. http://m.imgur.com/a/bURrE
chrismoore701 is offline   Reply With Quote
Old 03-05-2011, 11:32 AM   #2
cdowns
cdowns's Avatar
Re: stripping paint
you might think you dont have scratches only paint will tell the truth
i personally use wire cups and brushes as a last resort as i dont like theembeded flying wires in my skin
Old 03-05-2011, 11:58 AM   #3
belowme51
belowme51's Avatar
Re: stripping paint
soda blasting is the best way to get it done. If the money isnt there for a shop to do this for you than wire wheel will work fine, just very messy and as cdowns said the fun of the wires breaking off and sticking in your skin. I usually get my exterior panels soda blased and after words will prep the metal with 80 or 120 grit on an orbital before applying any etching primer or sealers.
belowme51 is offline   Reply With Quote
Old 03-05-2011, 12:30 PM   #4
stich626
Re: stripping paint
soda blasting..
never..
stich626 is offline   Reply With Quote
Old 03-05-2011, 04:09 PM   #5
Bugeyev8
Bugeyev8's Avatar
Re: stripping paint
Originally Posted by stich626 View Post
soda blasting..
never..
X2...bad bad news...
Bugeyev8 is offline   Reply With Quote
Old 03-05-2011, 05:58 PM   #6
treveiger
treveiger's Avatar
Re: stripping paint
soda blasting is never good as you never get it competely cleaned. so x3 on that one. blasting is the best way for getting as much as possible but you have to use the right media.
1969 Chevy c20(Miss Hackjob)
treveiger is offline   Reply With Quote
Old 03-05-2011, 08:38 PM   #7
sevt_chevelle
Lost amongst the CORN
sevt_chevelle's Avatar
Re: stripping paint
X4 on soda blasting.
Currently working on How To Videos and custom metal
70 Chevelle gettin Sliced and Diced Anything But STOCK
70 Chevelle SS455 not a typo its a BUICK BABY
49 and 72 Chevy Trucks restored to original...close to it
Drommer Stor....Norwegian for Dream Big
http://s969.photobucket.com/albums/a...lle/?start=all
https://www.flickr.com/photos/47922830@N03/
Pictures of my work and projects
sevt_chevelle is offline   Reply With Quote
Old 03-05-2011, 10:06 PM   #8
JasonBird
'67 C-10 LWB Driver
JasonBird's Avatar
Re: stripping paint
i really like the corse 3m scotch brite whells in a drill. it's pretty tedious but it cleans it off nice and won't overheat.
'67 C-10 LWB - My Build Thread
'67 C-20 LWB - My Donor/ Parts truck - SOLD!
'92 GMC SAFARI VAN - My Parts Go Getter
'06 KIA SPORTAGE EX - My Commuter
"All of this crap better make a truck!" - my wife Sue.
Proud U.S.M.C. Dad!
JasonBird is offline   Reply With Quote
Old 03-05-2011, 10:18 PM   #9
VA72C10
VA72C10
VA72C10's Avatar
Re: stripping paint
I use the discs in my grinder that look like corral. Not sure of their official name, but I never have an issue with heat and it takes it right down to bare metal.
Old 03-05-2011, 10:21 PM   #10
chrismoore701
Re: stripping paint
soda blasting is not an option, funds are too tight. I have tried just about everything I have in my garage. DA, sand blaster the black discs in the drill, I think they are the brite wells mentioned above, and 80 grit on a 6" low speed sander, that works great on large flat panels, but this angle grinder with the cup wheel seems to beat them all, and I don't mind the occasional wire bur stuck in my gut. So if there are no other negative effects from using it, I will continue. Funny story however. I was using a regular wire wheel when rebuilding my dads corvette. I got a wire stuck in my alkalies tendon, shoved over 75% into my foot. was almost unable to walk then I saw what the problem was, a pair of pliers and instant pain relief. so be careful, you never know where those wires will end up.
Chris
Old 03-06-2011, 12:06 PM   #11
68gmsee
Active Member
68gmsee's Avatar
Re: stripping paint
I've done the grinder/wire wheel thing for badly rusted areas also. I also used a bronze wire wheel on the bed floor which I later primed and painted with rustoleum. Since it was the bed floor, I didn't have to worry about scratches but I really didn't notice any detrimental scratches. I get more with the sanding discs from what I've experienced.
68gmsee is offline   Reply With Quote
Old 03-06-2011, 12:20 PM   #12
pat 70/71
pat 70/71's Avatar
Re: stripping paint
Chris make sure when you remove the paint to metal you condition the metal& use a good etching primer on each panel. the wire wheel works ok for removing paint. use eye protection for sure. keep the rpms low. when I did my truck I only stripped what I could finish that day hope this helps cheers, Pat
pat 70/71 is offline   Reply With Quote
Old 03-06-2011, 04:50 PM   #13
gixxerpymp
Re: stripping paint
"Clean & strip" discs are what I use..
gixxerpymp is offline   Reply With Quote
Old 03-06-2011, 05:08 PM   #14
VA72C10
VA72C10
VA72C10's Avatar
Re: stripping paint
Those are what I use....except I found some that are blue and really work well....have to find the company again online as they were 1/2 price of the name brand ones and have actually lasted longer!!!
Old 03-06-2011, 05:11 PM   #15
CEE1NG_RED
Re: stripping paint
VA72C10...LMK what the brand is called when you find it.
- 1967 Chevrolet C/10 SWB fleetside (New Project).
- 1969 Chevrolet C/10 SWB fleetside (SOLD)
- 2000 Ford Mustang 232 (DD)
- 2003 Ford SVT Cobra "Terminator" 281 (Once in a blue moon driver/weekend driver)
CEE1NG_RED is offline   Reply With Quote
Old 03-06-2011, 05:27 PM   #16
Bugeyev8
Bugeyev8's Avatar
Re: stripping paint
I use 80 grit on my National Detroit DA, It sounds like coarse grit but it really is not, it works great 1 hr to strip the hood and 2 hrs for the doors inside and out, makes lots of noise and dust but works great and will not damage metal and a whole roll of disks is 40$ for the good 3m ones and that will do an entire truck
the next step in prep is to wipe it down with wax and grease remover and lay some high build epoxy down, I over reduce the first coat to get in all the surface imperfections and then spray it as directed and then do 2-3coats , then guide coat and block then if I sand through I re prime and block again.....then primer sealer wet sand with 400-600 depending on paint specs and ready to go
Old 03-06-2011, 10:13 PM   #17
chrismoore701
Re: stripping paint
Sounds like a plan, when I use the wire cup, I have a high speed angle grinder, it seems to polish the metal, I don't see any scratches. as for the rest of the steps, I have heard a few dozen different ways to paint. here is how I do it.
1) focus on obvious damage,
a) cut and weld,
b) or strip paint, scratch with 26 and bondo
2) strip rest of panel, will not use chemicals any more, bad luck
3) scratch with 80 - 180 for primer
4) wipe with prep solve
5) paint 1 - 2 coats of epoxy primer,
6) paint with 2-3 coats of 2K high build same night as epoxy
7) sand
8) guide coat and wet sand
9) let sit and move to another body panel
10) once all panels are done, paint color
your thoughts
Chris
Old 03-08-2011, 05:35 PM   #18
kieth
kieth's Avatar
Re: stripping paint
the soda blasting is not a bad thing, it just isn't always done correctly, One has to completely flood the work after blasting, neutralize with vinegar, flood again, but it is too expensive a media to use in small sandblast units, I just walnut shell blasted my 66 gmc, it took 5 hours and 12 bags of walnut hulls, sure beat the heck out of sanding , grinding, chemical stripping, etc.
here is a link: ps the walnut shells cost .27 cents per lb and we used 600 lbs, wish I would have known they are reusable we would have cut this amt in half. It really does a good job.........The trick is 150 to 185 CFM 60 to
90psi.
http://kieth.smugmug.com/Trucks/66-G...07426574_ogvuC
kieth is offline   Reply With Quote
Old 03-08-2011, 07:44 PM   #19
morgan71
Re: stripping paint
90psi.
Hey just wondering if you knew of anyone in the Tulsa area that I could hire to do this to my 72 gmc. It is completely apart with the bed and cab mounted on dolly's with caster. Thanks
morgan71 is offline   Reply With Quote
Old 03-09-2011, 09:34 AM   #20
Shane
Shane's Avatar
Re: stripping paint
...The trick is 150 to 185 CFM 60 to 90psi.
Where the heck did you find a compressor that flowed 150-185 cfm @ ANY psi?
Shane is offline   Reply With Quote
Old 03-09-2011, 07:24 PM   #21
BLACK AND BLUE 67-72
Firefighter
BLACK AND BLUE 67-72's Avatar
Talking Re: stripping paint
Easy Ingersoll Rand makes them so does Multi Quip #A2!! They are a big industrial compressor mounted on it's own trailer. I have used one that had a Ford V8 with one side compressing the air and the other running the engine!! Pretty sweet set up!!!!!!!!!
'72 Chevy SWB 350 Auto
'67 GMC LWB 350 4 speed
'70 Chevy 4x4 Stepside 350 Auto
Yellville, Ar. USA
BLACK AND BLUE 67-72 is offline   Reply With Quote
Old 03-09-2011, 10:04 PM   #22
powerdriver 1958
Kid's Mechanic
powerdriver 1958's Avatar
Re: stripping paint
Thats funny , I did the same . I drug a 185 ingersoll home on the weekends . Had to borrow an air dryer because of the moisture .But after tweaking the regulator it worked fine .
powerdriver 1958 is offline   Reply With Quote
Old 03-09-2011, 10:33 PM   #23
Restrorob
The One And Only !!!
Restrorob's Avatar
Re: stripping paint
Glad I found this thread, We have a 210 cfm GrimmerSchmidt tow-behind compressor and a 50 gal pressure blaster with dryer in our rental fleet. Can you run walnut shells through a sand blaster ? If so what size tip is needed ?
I've used it with sand blasting trailers just don't know about using walnut shells.....
93 Jeep XJ
88 Buick La Sabra
Toys;
88 TA-GTA in the works....
97 GMC Ext. Cab
Old 03-10-2011, 01:02 PM   #24
chas350
Re: stripping paint
http://www.lehighvalleyabrasives.com...scs/Categories
"I'll Procrastinate Tomorrow"
quote by LEEVON
71 K10 long fleet (sons truck) new 370hp 355, sm465 np205, 3.73's 33's
70 K20 long fleet
98 G3500 work van
chas350 is offline   Reply With Quote
Old 03-16-2011, 07:52 PM   #25
chillware
Re: stripping paint
Great thread guys, thanks for the info!
My build thread: '66 Chevy
chillware is offline   Reply With Quote
