07-26-2016, 04:36 PM | #1 |
Should I weld the rear bed cross seal?
What is the opinion on welding the rear crass seal to the bed sides? The original was tacked in place probably to keep the bed sides squire. it has three bolts holding it, should i weld it or not?
07-26-2016, 05:06 PM | #2 |
Re: Should I weld the rear bed cross seal?
you are correct; original was bolted and tacked to keep square
if your not doing a 100 point restoration, weld it solid if you want
cool, an ogre smiley Ogre's 58 Truk build how to put your truck year and build thread into your signature shop air compressor timer |
07-26-2016, 08:05 PM | #3 |
Thanks Ogre. just not sure if it needs it and it does make painting a bit tricky.
07-26-2016, 11:22 PM | #4 |
I welded mine solid, glad I did...Jim
my build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=459839 Jimbo's long bed step build:http://67-72chevytrucks.com/vboard/s...t=464626<br /> |
07-28-2016, 12:12 AM | #5 |
As stated, if not a restoration where you are planning on concourse showing, weld it in.
RUBBER DOWN AND HIT THE ROAD!!! 1940 Ford Dlx Coupe 1969 Mach1 |
07-28-2016, 05:06 PM | #6 |
The FAM says to weld it and shows where to weld. It says either gas or arc, so I would say that if you were restoring a TF for judged showing and you got the right judge who knows what he's looking for you would loose points for not having it welded. I've heard of show cars loosing points for things like this.
07-28-2016, 06:13 PM | #7 |
I found it a bit easier to cut and buff the bed sides one piece at a time laying flat, so we did not weld them to the cross member only bolted for final assembly
53 TuTone Extended Cab 350 4-Spd 3:08 (SOLD) 53 Chevy Moldy pearl green ZZ-4 4L60E 9" 3:25 55 GMC 1st Black Mll (ZZ4) ZZ6 TKO 600 5 sp 3:73 62 Solidaxle Corvette Roman Red (327 340hp 4spd 3:36) C4 & C5 suspension tube chassis LS 3 4L70E 65 Corvette Coupe 327 350hp 4spd 4:11 78 Black Silverado SWB (350/350) 5.3 & 4L60E 3:42 2000 S-Type 3.0 (wife cruiser) 2003 GMC SCSB 5.3 4L60E 3:42 |
07-29-2016, 02:24 PM | #8 |
Thanks everyone. I think based on location of the welds i can paint, cut and buff the outside pieces, then tack the cross in place and fix the paint on the seal section afterwards.
07-29-2016, 10:50 PM | #9 |
I welded mine and I liked how clean I was able to make the back by removing most of the bolts. I also used a rolled pan so that factored into why I welded mine.
Marc
…………...........__________ .................. ((__|__||___\____ ..;.;;.:;:;.,;..;((_(O))____ (_(O)) 1948 Chevy Truck - Finished SOLD!! 1953 Chevy Suburban "Family Truckster" Completed: Spring of 2021 http://67-72chevytrucks.com/vboard/s...d.php?t=605484 1994 4x4 Blazer - "Field Find" https://67-72chevytrucks.com/vboard/...ferrerid=30857 |
