Old 04-24-2012, 10:06 PM   #26
jfortvalley
Re: T56 Shifter Location Change
the only thing i would change being a transmission builder is when you assembled the trans you shoulda used Brand / Loctite
Remove
Product Line / Loctite 518 Anaerobic Gasket Maker
Remove
Catalog Quick Order:
Warnings
Sorry, you can only compare 10 items.
Would you like to replace your oldest item in the compare list?
Yes, add this item | No, view my current items
Loctite 518 gasket maker is a non-corrosive, anaerobic sealer designed primarily for use on aluminum, iron, and steel flanged mating surfaces. It's ideal for on-the-spot emergency repairs, or when a conventional gasket is out-of-stock. 518 gasket maker fills gaps of up to 0.050 in. and forms a flexible, solvent-resistant seal that will not tear or decay. Parts will disassemble easily even after extended service, and old gasket material can be removed with a putty knife.
Suggested applications include:
* Water pumps
* Thermostat housings
* Transmission pans
* Transmission case covers
* Transaxle casings
* O-ring replacement
Results 1-1 of 1
jfortvalley is offline   Reply With Quote
Old 04-24-2012, 10:07 PM   #27
jfortvalley
when you use regular rtv it changes the clearances (wider) but i dont think you will have any problems
Old 04-24-2012, 10:08 PM   #28
jfortvalley
really good job on the write up and the assembly
Old 04-25-2012, 10:06 PM   #29
TR65
TR65's Avatar
Thanks for the tip Jfort, and the kind words.
I have driven it daily now for about a year and a half, no leaks, no problems.
TR
1965 C10 SWB Fleet
Two owner
LS2 Swap Thread http://67-72chevytrucks.com/vboard/s...d.php?t=413880
TR65 is offline   Reply With Quote
Old 08-27-2012, 01:53 AM   #30
Critter
Future TOTM Winner
Critter's Avatar
Hey TR, what are your thoughts on this? I don't normally cut corners but this is tempting. In your opinion is this a viable option if you are careful or is it too risky?
http://www.performancetrucks.net/for...nstall-485277/
72 Chevy CST K5 HIGHLANDER BLAZER Getting a 6.0,NV4500,NP205,14BFF (Currently laying all over the place in little pieces)
72 Chevy swb step-side "LS" 6.0 Here's a build thread of sorts
2002 HD2500 Crew Cab, 8.1L Allison 4x4 Daily Driver
Check it out www.lsdyno.com
Critter is offline   Reply With Quote
Old 09-08-2012, 11:38 PM   #31
truckingsal3
Your kit seems complete but the accelerators may seem to be low in quality but nevertheless it is a good call. Good to see the output is great!
truckingsal3 is offline   Reply With Quote
Old 09-09-2012, 09:58 PM   #32
TR65
TR65's Avatar
Critter,
There was another thread that used this approach on our site recently. If I had it to do over I might try it that way. Seems reasonable and saves a lot of work.
Good luck,
TR
1965 C10 SWB Fleet
Two owner
Old 09-16-2012, 10:28 PM   #33
Critter
Future TOTM Winner
Critter's Avatar
Thanks TR. I am really itching to put a t56 in the step side from my signature. Maybe I will give it a try.
Old 12-05-2012, 01:34 PM   #34
hartandsoulcustoms
TR what year t-56 i need to use to put it behind a none ls i have 73 355 sb in a 68
need to know what parts need flywheel back to trans and i need it on a low cost buget
any info would be helpful thanks
and the work u did is just sweeeet i love it all i have to say TR ur the man
again thanks allan
hartandsoulcustoms is offline   Reply With Quote
Old 12-05-2012, 04:31 PM   #35
dznucks
dznucks's Avatar
I used an LT T56. It will bolt right up to the SBC cheaper than a LS will.
You need a special flywheel and the stock clutch kit. I used this flywheel...
Flywheel - CKGM-20010 $169 from American Powertrain.
Use a slave cylinder from a 1990 comaro. cheaper and better than stock, with the same stroke and bore size. I used a wilwood master cylinder, 260-3376. I followed the hydraulic clutch write up that I think TR did.
A stock auto-trans mount will work if your motor is in the V8 location.
dznucks is offline   Reply With Quote
Old 12-05-2012, 10:11 PM   #36
TR65
TR65's Avatar
Hey Allen,
Thanks for the kind words. I really love the T56, radical first four gears then two more for cruising and mpg's.
Sorry I don't know all the in's and out's of the various T56 flavors except that there are a lot of them.
Sounds like dznucks has the hot ticket.
Good luck with the conversion. If I can help otherwise, let me know.
TR
1965 C10 SWB Fleet
Two owner
Old 01-04-2013, 04:27 PM   #37
MalibuKasey
Artist
MalibuKasey's Avatar
This thread is awesome!!
Just so everyone knows.... Keisler has changed there shifter design. Im sure it will work fine but it looks completely different and no longer comes with the boot. Ill post pics later.
66 Chevy C10 283ci~cough~ SBW Fleet Buttercup '66
MalibuKasey is offline   Reply With Quote
Old 01-04-2013, 10:29 PM   #38
theastronaut
theastronaut's Avatar
Is it later yet?
theastronaut is offline   Reply With Quote
Old 02-17-2013, 08:13 PM   #39
MalibuKasey
Artist
Here's the new keisler setup.
Old 02-18-2013, 08:30 AM   #40
wraprail
wraprail's Avatar
Flywheel - CKGM-20010 $169 from American powertrain
Are you sure about this part #? $169 seems awful cheap
FWCV-11006 at $366 at american powertrain
wraprail is offline   Reply With Quote
Old 02-18-2013, 12:21 PM   #41
dznucks
dznucks's Avatar
Yes. I am positive. It is a custom made flywheel just for this application, Gen I SBC and LT T56. The prices may have gone up, but thats what my reciept says. There website is completely different now, they may not offer them anymore.
Old 02-25-2013, 06:19 PM   #42
weaintscared
weaintscared's Avatar
153T Billet Steel Conversion Flywheel for use with LT1 T56 Pull-Style Clutch, 2-piece crank seal, 1.700 depth, Neutral Balance 153T
LT1 T56
Description: 153T Billet Steel Conversion Flywheel for use with LT1 T56 Pull-Style Clutch, 2-piece crank seal, 1.700 depth, Neutral Balance 153T
Condition: NewPrice: $366.45
weaintscared is offline   Reply With Quote
Old 02-26-2013, 09:03 AM   #43
dznucks
dznucks's Avatar
Looks like you guys missed out.
I paid a total of $169 for my flywheel and that was with an additional $20 to lighten it.
Old 02-26-2013, 12:24 PM   #44
wraprail
wraprail's Avatar
Missed something cuz my McLeod was $515 with shipping and tax to my door. Centerforce makes one, price is about the same. Ram also makes one but it's aluminum and weighs only 18 pounds. A bit light in a 3000+ puckup in my opinion. You say you had yours lightened? Whats it weigh?
Old 02-07-2014, 11:35 AM   #45
LiLDrumKing3
Why do you need a special flywheel for the LT? Couldn't you use a stock flywheel out of a Camaro that had the t56?
Jeremy
1965 Chevy c10 Short Stepside
Check out my Build Thread
http://67-72chevytrucks.com/vboard/s...d.php?t=410658
LiLDrumKing3 is offline   Reply With Quote
Old 02-07-2014, 01:55 PM   #46
storm9c1
*** That's interesting ***
storm9c1's Avatar
If I read that correctly, the special flywheel is for a 2-piece rear main seal engine. If you were to have a 1-piece rear main seal engine (like the 1993-1997 LT1 for example), then I don't see why you couldn't use the Camaro flywheel (sans the fact that they may be a little weaker for a heavy truck).
Tom
Chevy by day...
1969 Chevy C30 Rollback Tow Truck -- 383 stroker, 4L80E
2011 Chevy Caprice PPV 9C3 6.0L
1995 Chevy Caprice 9C1
1994 Chevy Caprice 9C1 #3
1995 Chevy Caprice Wagon #2
1995 Chevy Impala SS
Mopar by night...
1969 Dodge Charger
1972 Chrysler Newport 2dr Hardtop (27K miles)
Plus others...
storm9c1 is offline   Reply With Quote
Old 02-07-2014, 03:54 PM   #47
swb85
On a budget like Fred Sanford
swb85's Avatar
I just finished putting a T56 behind my gen 1 383 with 2 piece rear seal. I used an LS T56 with a $200 adapter plate and $20 extended pilot bushing. Doing it this way allows you to retain all the gen 1 flywheel/clutch/bell/linkage. No silly expensive custom flywheel, much larger & less expensive clutch selection than the LT pull style.
Also, Keisler just went out of business in January.....so their shifter relocation is now extinct. There's another company I think that makes a "kit" to do it for about the same price ($400ish). I've only seen them on ebay. I did it much cheaper with some creativity and robbing some CTS-V tranny parts along with a custom shifter base, but it's not a bolt-in deal for sure.
'85 Silverado swb: 383 stroker, 10.5:1, vortec heads, 232/238 roller cam, RPM air gap, performer 750 carb, stainless longtubes, 3" duals/super 44's, T56/4.11 383ci build / exterior refresh thread
'98 Camaro z28: 370ci twin turbo 370ci build
'01 Tahoe LT 4x4: 5.3, longtubes/ory, magnaflow duals, custom tune....wife's DD
swb85 is offline   Reply With Quote
Old 02-07-2014, 04:07 PM   #48
LiLDrumKing3
Thanks guys for the replys. I guess I skipped over the 2 piece rear main seal part of the post. I believe I have a one piece rear main seal. Already got the Kiesler kit last fall, just in time. I guess I need to do a little more research and figure out exactly what I got so I know what all I need to order.
Jeremy
Old 02-07-2014, 11:38 PM   #49
66 C10 383
Can to share what parts you used and how you did this? I've got a T56 to put in my 66 and I wasn't going to get the $400 kit. I was just going to let the shifter come thru the floor where ever it came thru. But if you have a cheaper way of doing it ...
My tranny is still out so it's the ideal time to do this ...
Doug
Old Build Thread - 383/T56
http://www.67-72chevytrucks.com/vboa...d.php?t=540838
Updated Build Thread - Modern Relic - 66 C10 536 Dark Aqua
5.3/4L60E - BTR Stage IV Truck Cam - Vintage Air - Dakota Digital
http://67-72chevytrucks.com/vboard/s...d.php?t=778784
66 C10 383 is offline   Reply With Quote
Old 02-07-2014, 11:46 PM   #50
theastronaut
X2, I'm debating between a shifter relocation and some internal upgrades for my T56, or if I should go to a Magnum T56. Would love to see what you did!
