09-17-2008, 11:31 AM | #1 |
The wire to nowhere
Please help ID this wire. it originates at the steering column on the gear shifter indicator (red thing) and ran back under dash with the turn signal switch wires and has a clip socket with a bulb attached????? I found that it is not really going to anything powered when replacing the switch the other day. Any help is appreciated!
09-17-2008, 11:36 AM | #2 |
Its Topless Season!!!!
Re: The wire to nowhere
the bulb end goes into one of your light sockets behind the dash cluster..if I am not mistaken
09-17-2008, 11:46 AM | #3 |
Inline 69
09-17-2008, 12:19 PM | #4 |
Resident Curmudgeon
That's not a wire, it's a fiber optic cable. The bulb/clip goes into your dash. When the lights are on, the dash illuminates and the fiber optic (Fibre if you prefer) cable radiates the light to the gearshift indicator to illuminate it.
Currently on or near the homestead: 67 Chevy SWB 2WD stepside 350/3 on tree (Pat's) 67 GMC SWB 2WD Fleet 402/auto (Brian's under construction) 67 Chevy 3/4 ton 2WD 402/auto (Business Hauler) 67 Chevy 1 ton dually 2WD 396/4 speed (Former business hauler, Needs TLC) 68 Chevy 1/2 ton Suburban 2WD 250 six/3 on tree (Brian's Needs TLC) 70 Chevy 3/4 ton 4WD 350/4 speed (Pat's - Disguised as a 68 GMC) 71 Chevy SWB stepside (Crushed by tree - parts donor) 72 Chevy 3/4 ton 4WD (Parts donor) 72 Chevy 3/4 ton 4WD Suburban (Parts Donor) 72 GMC 3/4 ton 4WD 292 six/4 speed (Mine - Disguised as a 67 GMC) 81 GMC 4WD Dually Dump Body 350/4 speed (Business Hauler) 82 Camaro Z/28 355/Super T-10 (Pat's toy) 93 Caprice 9C1 (Brian's Cop Car) 02 Toyota Camry (Reliable but a souless steel and plastic hulk) 2011 2SS RS Camaro M6 Factory Hurst Shifter Maybe I need to sell some of this crap Yet another Bozo with a sawz-all Last edited by CPNE; 09-17-2008 at 12:20 PM. |
09-23-2008, 03:00 PM | #5 |
CPNE nailed it on the head, and it works, too! Thanks.
09-23-2008, 03:57 PM | #6 |
Always on the hunt...
Here is what it looks like outside the column...
09-23-2008, 04:22 PM | #7 |
Mel,
Do the tilt-wheels have a similar fiber-optic light? My tilt shift-indicator does not light-up. |
09-23-2008, 04:24 PM | #8 |
Resident Curmudgeon
no, they are wired electrically. I "think" its an extra gray wire coming out of the column
Currently on or near the homestead: 67 Chevy SWB 2WD stepside 350/3 on tree (Pat's) 67 GMC SWB 2WD Fleet 402/auto (Brian's under construction) 67 Chevy 3/4 ton 2WD 402/auto (Business Hauler) 67 Chevy 1 ton dually 2WD 396/4 speed (Former business hauler, Needs TLC) 68 Chevy 1/2 ton Suburban 2WD 250 six/3 on tree (Brian's Needs TLC) 70 Chevy 3/4 ton 4WD 350/4 speed (Pat's - Disguised as a 68 GMC) 71 Chevy SWB stepside (Crushed by tree - parts donor) 72 Chevy 3/4 ton 4WD (Parts donor) 72 Chevy 3/4 ton 4WD Suburban (Parts Donor) 72 GMC 3/4 ton 4WD 292 six/4 speed (Mine - Disguised as a 67 GMC) 81 GMC 4WD Dually Dump Body 350/4 speed (Business Hauler) 82 Camaro Z/28 355/Super T-10 (Pat's toy) 93 Caprice 9C1 (Brian's Cop Car) 02 Toyota Camry (Reliable but a souless steel and plastic hulk) 2011 2SS RS Camaro M6 Factory Hurst Shifter Maybe I need to sell some of this crap Yet another Bozo with a sawz-all |
09-23-2008, 04:28 PM | #9 |
No, the tilts used an actual bulb/socket under the indicator/gear selector lens for illumination, should be a single grey wire (not stuck together with turn sig. wires) running out wire harness cover on bottom side of column tube.
09-23-2008, 04:34 PM | #10 |
member #16
The grey shift indicator wire plugs in the cluster feed on the fuse panel.
john http://67-72chevytrucks.com/vboard/showgroups.php board vendors http://www.flickr.com/photos/1745471...7602865984234/ |
09-23-2008, 04:37 PM | #11 |
I'M TRUCK CRAZY!
so looking at that pic (correct me if i am wrong) that illuminates the red gear selector tab thing???
I have a 3 on the tree column and an auto/tilt column so I have never seen that. |
09-23-2008, 04:38 PM | #12 |
I'M TRUCK CRAZY!
i was slow....
the first pic w/ the wire sitting on the package. |
09-23-2008, 05:11 PM | #13 |
And here is a factory truck tilt with the GREY wire coming out of the harness cover on the bottom side of the column tube.
09-23-2008, 06:02 PM | #14 |
Found my grey wire plugged in above the cluster fuse. Where is the bulb and what needs disassembled to change it?
09-23-2008, 07:25 PM | #15 |
Dan, the bulb/socket is attached to the top of the turn signal switch. To get at the bulb just: remove the two screws holding the shift indicator housing to top of column, now lift indicator housing/indicator lens from top of column. Now you should see a small green cap (sometimes faded) over the top of a metal cap, this metal cap basically directs the bulbs light right at the shift indicator lens, remove the plastic cap and then the metal one and you should now see the bulb. Mel
09-24-2008, 05:50 PM | #16 |
Moderator
I removed mine to replace the bulb, and did not see another cover or cap...is something missing? I traced the grey wire, and it looks like PO did not know where to connect it as it is spliced into another wire, and the space on the fuse block is not being used.
09-24-2008, 07:42 PM | #17 |
Scott, there should be a small metal cylinder with a rounded end on it that covers the bulb and allows a tiny bit of light out of a rectangular port near the end of the rounded end. On top of the metal cover is a green half-sphere cover that gives the light the right color. The PO probably had trouble fitting the metal cover back over the bulb/receptacle and just put the PRNDL cover back on.
09-24-2008, 08:47 PM | #18 |
Some more pics for id'ing the missing parts... I agree with dan about the parts being left out by someone who had it apart, I come across this often. Mel
09-24-2008, 09:59 PM | #19 |
Great info. and photos Mel!!!!
Dan |
09-25-2008, 02:29 AM | #20 |
Moderator
Thanks for the pics Mel...it is missing those 2 pieces...do you know where I can get them? Thanks!
09-25-2008, 05:55 AM | #21 |
"THE GREEN GOBLIN"
I have the same problem my wire is not plugged in anywhere ! This info is great !!!
Petey-pablo
"THE GREEN GOBLIN" 1972 Cheyenne 10 Short Fleet Side Front 2.5inch Spindles with 2inch Springs Rear 4inch drop Springs. 454BBC TH400,Posi 1971 Cheyenne 10 Long Fleet Side 454BBC TH350,Posi Sold Drive it like you stole it! Petey-pablo@sbcglobal.net |
09-25-2008, 09:38 AM | #22 |
Maybe this should go to the FAQ in a few days? This info is hard to find when you need it most. Plugging into the cluster fuse would never have occurred to me.
'70 GMC C1500 LWB Power disc brakes. WooHoo! Posi 6 Lug Dana 60 |
10-24-2008, 01:44 PM | #23 |
To all,
Does anyone know where to get the fiber optic tube for a 72 non-tilt auto column? Any help will be greatly appreciated! Monty |
04-26-2018, 06:34 PM | #24 |
Here's a silly question. How far in does the indicator pointer with tilt slide in? I don't know if i'm missing pieces or what. For some reason it doesn't look right to me. Thanks
04-26-2018, 06:35 PM | #25 |
Look at post #6 for a part number.
"Work hard, use your vacation days." 1970 C15 GMC Long Bed 1986 C20 Scottsdale 1983 K2500 Sierra Classic Suburban 6.2 Instagram: C10sofOC Last edited by demian5; 04-26-2018 at 06:41 PM. |
