07-11-2010, 12:28 AM | #126 |
Re: 53 BURBAN barn find
Insane, Looks great Chizzler.......Very clean.
07-12-2010, 11:56 AM | #127 |
Just found this Chizz. Nice!!!
07-13-2010, 10:14 PM | #128 |
SAVING ONE TRUCK AT A TIME
Here are a few pics from last night.we worked from 7:00 till 1:00 in the morning.we got the rolling chassie all mocked up. Only a few minor details to deal with. we made the step notches longer to fit the frame better. should be bringing it back this week.scored some steel 15x5 black smoothies at a local swap meet for $60 bucks. Going to get some tires put on this week for fitment. sorry about the bad pics.
53-suburban (99% done) 40-pick up (99.9% done) 12-cc lb dually D-max (dd) 61-crew cab D-max "PAY LESS FOR WHAT YOU NEED PAY MORE FOR WHAT YOU WANT" 53 BURBAN BARN FIND:http://67-72chevytrucks.com/vboard/s...d.php?t=404091 1940 PROJECT MOON SHINE:http://67-72chevytrucks.com/vboard/s...d.php?t=551088 1961 CREW MAX: http://67-72chevytrucks.com/vboard/s....php?p=6957999 |
07-13-2010, 10:17 PM | #129 |
Looking good.
My AD Truck Build Thread 52 GMC one day laying on the running boards 2004 Chevy Crewcab. 3/5 and notched |
07-17-2010, 06:51 PM | #130 |
well here is the rolling chassie.got home about two hours ago.tell me what you think.right know running boards are about 2.5" off the ground.it can go lower but we will need to clearance the back wheel wells a little.
07-17-2010, 08:03 PM | #131 |
07-17-2010, 09:19 PM | #132 |
Running board will be on the ground.we also will need to clearance the top ball joints.they lock up before laying out.
07-17-2010, 09:38 PM | #133 |
I think it looks great and deserves a phrase that I retired decades ago. RAD!
'20 Silverado Trail Boss ~ '17 Tahoe ~ '79 K15 Sierra Grande ~ '76 Blazer 2wd ~ '71 Cheyenne swb ~ '55 Pontiac Safari ~'50 3100 bagged ~ '80 Wife ~ Late model kids
07-18-2010, 01:52 AM | #134 |
Boom! Can't wait to see this puppy in person.
07-18-2010, 02:19 AM | #135 |
Thanks frizzle,leevon.tryin to get as much done as i can.the guy i worked on the chassie with was awesome.fast and precise.next week it will be going back out to his shop to mock up motor and tranny.next will be all the other stuff(fuel,brakes,steering.wiring) thanks for the support.
07-27-2010, 01:20 AM | #136 |
Worked on the air bags this weekend.back dosnt have enough lift.firestone 9000.going to need taller bags or run 2" cups.
07-27-2010, 01:22 AM | #137 |
07-27-2010, 01:47 AM | #138 |
I will call you this week. I need some other stuff.thanks
08-17-2010, 01:35 AM | #139 |
Sorry guys. Been real busy with work.will post some pics later this week.got the motor mocked up with sb 350 and 700r4.been working on tunneling the floor and replacing the floor pans.going to use a 70 mustang tank behind the rear axle.also got a ididit column and cpp booster coming.
08-23-2010, 05:09 PM | #140 |
anyone have any pics of any aftermarket radiators.looking to order one very soon.wondering what size and how well it fit.thanks.
08-23-2010, 05:47 PM | #141 |
we (Scott's) are a dealer for US radiator. I'm sure Justin will give you a smoking deal on one.
Give me an idea of what you are looking for (aluminum, steel, 2-4 core?) and I'll be sure to get you a quote.
Jeff Savaglio Scott's Hotrods Oxnard CA 93030 |
08-23-2010, 06:25 PM | #142 |
A standard 4 core brass radiator retail is $430. The all aluminum 2 core is $370
I'm sure Justin will do 10% so the brass 4 core would run $387, the aluminum 2 core would run $333. Give us a call!
08-23-2010, 08:16 PM | #143 |
thanks jeph.i will talk to justin this week.
08-23-2010, 08:23 PM | #144 |
i like it
08-23-2010, 09:10 PM | #145 |
Hit is up and you will get a great package.Danny I am leaving for a show this wed I will
not be back till next tue in the shop.Call me up and I will take care of you. Justin |
08-23-2010, 09:35 PM | #146 |
thanks justin.i will call you next week.work is kickin my a** right know.
08-28-2010, 10:50 PM | #147 |
Well guys here are some new pics.got most of the sheet metal in for the floor.got the wheel tubs in.built the tranny hump.using a 70 mustang tank and relocated the filler to the rear corner.found some bad patch work on the rear wheel opening.still working on it.mocked up the motor and tranny and finalized the motor mounts.got the new column and brake booster setup.more to come.thanks for lookin.
08-28-2010, 10:51 PM | #148 |
Few more.
09-01-2010, 06:34 PM | #149 |
Doin' it live!
In the photo of the rear wheel opening, is that a patch you had to do up at the top? I see a faint outline of what looks like a patch panel. Reason I ask is I have one in the almost the exact spot on the same side. Was kind of wondering if that is common problem on these beasts.
-Panelrodder 1953 GMC Panel truck - 'Curly' 1961 Chevy Suburban - 'Larry' - Sold 2005 Harley Sportster - 'Shemp' |
09-01-2010, 07:33 PM | #150 |
Because they have sliding side windows this is a very common spot for rust.if you look under the window you will see drain tubes that allow the water to go down.i will be using one piece windows to solve this problem.we made the patch panel by using small pieces.
